Air conditioning and temperature questions
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TheReal_amocaT, Sep 18, 2017.
  1. Sep 18, 2017 at 8:05 AM
    TheReal_amocaT
    TheReal_amocaT [OP] Well-Known Member
    Okay, so I still need to do a little more digging and cleaning but figured I would throw this out there before getting too meticulous on the cleaning.
    A few days ago I went on a little adventure and ended up pretty covered in mud by the end after all of the rain we had here in Texas. I have since noticed that my air conditioning is no longer as cold as it was (especially at idle, it cycles from cold to as hot as ambient air). I noticed that the issue is not really present while driving although it is possible it is not as cold as it was before. I ended up sitting on the blacktop waiting in a line at idle with AC going since it was 95F + outside. I noticed the AC was doing this cycling issue again and was struggling to keep it even remotely cool inside. I also noticed eventually that my engine temp was higher than average (although didn't ever pass the last bar on the gauge). If I revved the engine to around 1500 RPM I could get the AC to blow cooler while sitting still. I have not noticed this issue in stop and go traffic, only while sitting idle for extended periods (min 3-5 mins and up).
    I have tidied up most of the vehicle from mud, but am wondering if there is another place I am missing that is being insulated by a layer. I plan to remove skid and clean under well later today, but I have done a fairly thorough wash so far to remove as much as possible.
    Any thoughts on possible problem? The main fan is spinning when the vehicle is running (and spinning faster when AC is on) so I don't think that is the issue.
    I have not checked the AC lines for leaks, so that's a possibility I suppose if the compressor just isn't getting enough power at idle to compress the R134A if it is low. Only thing that bothers me about this is the temp gauge that was running a tad high meaning that the problem was not only with AC compression system
    Any other thoughts?
  2. Sep 18, 2017 at 8:07 AM
    TheReal_amocaT
    Forgot to mention, I do have climate control in the vehicle, and I have tried lowering fan and turning temp colder and vise-versa with minimal difference.
  3. Sep 18, 2017 at 8:33 AM
    Broccoli
    Broccoli Well-Known Member
    Airdrie Alberta
    2016 trd sport blazing blue,
    Seems like you have a engine cooling issue and something up with the ac. Id take it to the dealer. Not once in 40k has my truck needle gauge gotten over the halfway mark. So i would start there.
  4. Sep 18, 2017 at 8:34 AM
    TheReal_amocaT
    That was the plan, I just wanted to make sure I removed any possible mud that may be hidden that they could find and complain about prior to going in :)
    I only have around 25K on it hah.
  5. Sep 18, 2017 at 8:39 AM
    pinochle
    pinochle GC8 Fanatic
    NNJ
    2018 TRDOR DCSB 4x4 6MT
    NFab Nerf Steps, Bakflip MX4, Profile 5500K HIDs, Kicker Tweeters, Toyota Bed Mat, XPEL Ultimate Paint Protection, Borla S-Type Catback Exhaust, ME-SO Customs Gasshole, ME-SO Customs Total Tails Stage 1, ME-SO Customs Ultimate LED Turn Signals V4, HELLA Supertones, OVTuned 2.0, 2LO Mod, 16x8 0mm Enkei RPT1 Wheels in Titanium Gold, Diode Dynamics SS3 Pro Foglights, K&N Cabin Air Filter, HPS Intake Hose, Amsoil Gear Lubes in 6MT, front and rear differentials, XPEL Prime XR Plus Tint, TRD Engine Air Filter, Pioneer Head Unit, 275/75R16 Falken Wildpeak A/T3W Tires, RallyArmor UR Flaps
    Anything blocking the radiator or condensor?
    Is your cabin air filter full of dust?
    Boghog1 and TheReal_amocaT[OP] like this.
  6. Sep 18, 2017 at 8:49 AM
    Broccoli
    Airdrie Alberta
    Cabin air is behind the glovebox if your curious. Access from inside the cab.
  7. Sep 18, 2017 at 10:06 AM
    TheReal_amocaT
    Good thought, I should check and make sure the filter is not clogged. Although they did "give" me a replacement filter last service that I installed myself since I left my glovebox locked haha.
  8. Jun 12, 2019 at 3:25 PM
    Drogen
    Drogen Floppy bass
    Demitri
    Dallas, TX
    2014 Sport 4x4
    Lift & 33s
    Ever get a solution to this? Having same issue minus engine temp. Recharged ac (didn't really need much, was nowhere near out) still air isn't cold while idling and not much colder while driving.
  9. Jun 12, 2019 at 6:10 PM
    TacoMamba35
    TacoMamba35 Well-Known Member
    PNW
    2021 Tacoma TRD OR DCSB 3.5
    There's a TSB for this. T-SB 0063-18 covers 2016-2018 model years.
