Air conditioning not as cold as before...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by buddahead Steve, Sep 18, 2021.
  1. Sep 18, 2021 at 5:11 PM
    buddahead Steve
    buddahead Steve [OP] Well-Known Member
    2009 Mica Pre-runner 2.7, 5sp
    OK... now that the heat has passed, I thought I'd ask... my air isn't as cold as before, I mean even with the acess cab, it's not a huge space to cool, and it seems that in years pass, I never ran it full on, it would just get too cold, but this year, there were days that it was more comfortable to just open the freakin window.
    Do these units need to be recharged or ???
    Thanks
    Sweaty BuddhaHead Steve
    tacotoe and TXpro4X4 like this.
  2. Sep 18, 2021 at 9:59 PM
    RoastyToastyMan
    RoastyToastyMan Well-Known Member
    Jayme
    2010 White Tacoma TRD Offroad
    When was the last time you changed the cabin filter? A clogged filter can restrict airflow. The A/C system is a closed systems and shouldn't need a recharge unless there is a leak. If nobody has check your system in a while it might not be a bad idea to take it to someone and have it tested.
    tacotoe and buddahead Steve[OP] like this.
  3. Sep 18, 2021 at 10:08 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Mine needed a recharge Steve. Had no leaks just needed some more refrigerant.
    If you do it yourself add it slowly tell the passenger right vent gets cold again. Also don't use the leak sealer type. Just refrigerant!
    :cheers:
    Also change cabin filter of you haven't lately. Your system will love you
  4. Sep 18, 2021 at 10:13 PM
    Bishop84
    Bishop84 Well-Known Member
    AC systems lose charge over the years regarless of condition.
    Likely all you need is a recharge, but it would be good to have it tested for leaks just in case.
    Typically when the A/C is low on charge it will blow cooler on the drivers side and warm on the passenger side.
    buddahead Steve[OP] likes this.
  5. Sep 19, 2021 at 6:04 AM
    Haole Toy
    Haole Toy Well-Known Member
    Mauna Kea, AZ
    '21 SR 4x4
    My dealership did mine for under $200 including replacing the valves.
  6. Sep 19, 2021 at 6:08 AM
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    It couldn't hurt to clean the condenser that is located in front of the radiator. Use a degreaser or simple green solution.
  7. Sep 19, 2021 at 7:06 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I would vacuum the system and recharge by weight and add a little dye. Then your all set for finding a leak if need be.
  8. Oct 2, 2021 at 3:08 PM
    buddahead Steve
    ouch...
  9. Oct 2, 2021 at 3:17 PM
    Haole Toy
    Mauna Kea, AZ
    '21 SR 4x4
    I thought it was fair since it came with a dealership warranty...no backyard braddah doing the work. At least I know it works.
    tacotoe likes this.
  10. Oct 2, 2021 at 3:20 PM
    Mastiffsrule
    Mastiffsrule Well-known member, but no one cares.
    Scott
    2021 Taco XP Predator
    $200 is not bad if they have to add Freon. 1lb Freon usually $40-70 alone. All good ideas. Clean condenser, filter, recharge system.
  11. Oct 2, 2021 at 3:24 PM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Recharge, filter change, and possibly check the fan speed switch. Theres a controlling piece that sometimes needs to be replaced under the dash
  12. Oct 2, 2021 at 3:28 PM
    buddahead Steve
    Thanks EVERYONE... so I'm looking up how to do the cabin filter and front condenser, things I never knew it existed ;-) I'm gonna have the system checked.
    I have a great wrench that I go to here in Seattle (if this independant guy gets a shout out from "Click & Clack brothers of Car Talk", who you gonna call? ;-)
    peace/be safe
  13. Oct 2, 2021 at 5:12 PM
    spitdog
    https://www.tacomaworld.com/threads/new-ac-condenser-replacement-tips.495755/page-2
  14. Oct 2, 2021 at 5:47 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    o_O A 12oz can of R134A is 7 bucks.
    Regnar, maineah, winkel and 1 other person like this.
  15. Oct 3, 2021 at 5:15 AM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    This is exactly what I did earlier this summer and it made a significant difference. I didn’t have a leak but I’d lost some charge, system presumably hasn’t been recharged ever. It was low by weight, about 25%.
  16. Oct 3, 2021 at 5:55 AM
    mistermanny
    mistermanny Well-Known Member
    Jalisco, Mexico
    05 AC 4x4 2.7 5spd
    OME 883/Nitros
    Tons of youtube vids on topping off your AC.
    Added a can earlier this year, wife is happy now :)
  17. Oct 3, 2021 at 6:06 AM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    I put this chit on everything.
    Seriously, I clean condenser and inside coils on my home AC, the radiator fins on my motorcycles and of course the ac condenser, radiator fins and the aux tranny cooler on the Tacoma. The first time I did the Tacoma the temp at the vent was 5 degrees cooler. I try and clean everything once a year except for the dirt bikes.
    Also, from what I've read here on TW, stay away from those do-it-youself recharge kits. The consensus is that they can or may create adverse if not serious results.
  18. Oct 3, 2021 at 6:19 AM
    Tacman19
    Tacman19 Well-Known Member
    Dave
    Mid Missouri
    19 Tacoma SOLD
    As many as I can fabricate
    If the ratchet brothers endorsed them, it's a good shop. My favorite line is "if they have a sign that lights up at night, they're probably legit" LOL.
    Zim
  19. Oct 3, 2021 at 5:12 PM
    Mastiffsrule
    Scott
    $7 + wholesale mark up + retail mark up + parts department mark up + dealer mark up + service department mark up + stocking mark up + disposal fee = $70 :rofl:
    CurtB[QUOTED] likes this.
  20. Oct 3, 2021 at 6:06 PM
    Tacman19
    Dave
    Mid Missouri
    19 Tacoma SOLD
    FIY....
    Generally speaking an air conditioning system is designed to accommodate up to a 20 degree difference between the outside air and inside air while still keeping around a 55% humidity level which is comfortable.
    So if it's 95* outside....well do the math..LOL.
    If you don't have a buddy with a set of gages, I think firestone still does a AC check for For $50. I was doing evac and recharge for $175 some years ago. Probably $200 by now. Parts stores have recharge canisters for $25 and come with a small gage. You might just need a little bump. Honest opinion most folks overcharge their systems and that will cause problems on the gaskets and "O" rings. I'd use a professional if you have the resources.
    Zim
