Air Pressure Sensor Light ON
Discussion in 'Wheels & Tires' started by Rockstar Junkie, Aug 15, 2008.
  1. Aug 15, 2008 at 9:57 AM
    Rockstar Junkie
    Rockstar Junkie [OP] Well-Known Member
    Springville,UT
    06 4x4 TRD Sport
    So I got new wheels and tires the other day. Went with bigger tires. The light is on. How do I get the light to go off. Does the computer need to re programmed for a different air pressure?
  2. Aug 15, 2008 at 10:00 AM
    mudslingin44
    mudslingin44 Well-Known Member
    west palm beach, fl
    07 tacoma double cab trd 4x4
    6 in pro comp coilover-35 in pro comp extreme mudders
    did they change out the valve stems?they have special valve stems on old rims
  3. Aug 15, 2008 at 10:01 AM
    Rockstar Junkie
    Springville,UT
    06 4x4 TRD Sport
    Yes, they put the sensors in the new wheels!
  4. Aug 15, 2008 at 10:02 AM
    mudslingin44
    west palm beach, fl
    there is a reset button under the steering wheel down low
  5. Aug 15, 2008 at 10:04 AM
    Rockstar Junkie
    Springville,UT
    06 4x4 TRD Sport
    is there any special routine of things you need to do?
  6. Aug 15, 2008 at 10:07 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    just push the button under the steering wheel. if that doesnt reset it.....check the spare and then reset it.
  7. Aug 15, 2008 at 10:08 AM
    Rockstar Junkie
    Springville,UT
    06 4x4 TRD Sport
    ill give it a try.... thanks guys
