AIR PRESSURE SENSORS
Discussion in 'Wheels & Tires' started by craigmoore, Sep 15, 2011.
  1. Sep 15, 2011 at 8:25 PM
    craigmoore
    craigmoore [OP] New Member
    Chad
    WV
    tacoma trd off-road
    DO HAVE TO GET NEW SENSORS WITH NEW WHEELS OR DO HAVE TO DRIVE AROUND WITH THE WARNING LIGHT ON.
  2. Sep 15, 2011 at 8:42 PM
    extremachn1
    extremachn1 I am an asshole, deal with it!
    Turd Furgison
    Tucson, AZ
    BAD ASS SUPERCHARGED BEAST
    TRD S/C, TRD quick shifter, AFE CAI, Magnaflow cat back exhaust, Fox racing shocks, TC UCA, All-pro expo leafs, Bestop soft top, Wet Okole black seat covers, Scan gauge II.
    No, tire pressure sensors are not required just like all CAPS LOCK IS NOT REQUIRED.
    ALL THAT HAPPENS IS THE TPMS LIGHT STAYS ON AND ANNOYS YOU LIKE SOMEONE TYPING IN CAPITALS FOR THIER ENTIRE POST!!!
  3. Sep 16, 2011 at 5:37 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    THE AFTERMARKET WHEELS YOU BUY ARE LIKELY COMPATIBLE WITH THE STOCK TOYOTA TPMS SENSORS
  4. Sep 16, 2011 at 5:47 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    OR YOU CAN BUY RIM BANDS OR MAKE THE PIPE BOMB
  5. Sep 16, 2011 at 5:51 AM
    TexasTacoma37
    THATS TRUE JUDY I HAVE THE BANDS AND HAVE HAD NO PROBLEMS WITH THEM
  6. Sep 16, 2011 at 6:33 AM
    river rat 69
    river rat 69 Well-Known Member
    Jim
    Orlando, Fla., Green side of the grass
    007, trd, sr5, fmf.
    NO Chrome,3" NFab's steps,TRD skid,Wet okie's.011 grill, k&n,5100's,All this comes right off when the old lady says let's go get a NEW ONE!!!
    Flat black over the light:cool: Jim
  7. Sep 16, 2011 at 7:36 AM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    From what I have read:
    sensors from Steel Toyota wheels will fit most aftermarket steel wheels.
    sensors from aluminum Toyota wheels will fit most aftermarket aluminum wheels.
    I just replaced my aluminum off-road rims with ATX and the sensors swapped with on problem.
  8. Feb 26, 2015 at 1:36 PM
    egres
    egres Well-Known Member
    DELCO PA
    13 singel cab - 2WD - manual - 17K before tax:)
    Bench-seat covers $180 (Can't believe its not leather),Bed Liner $375 (Bed rug), Roof rack $180 (Rhino-rack 2500 Series, plus DK clamps and pads), Modified Bed extender $85 (Extend-A-Truck 944 Truck Bed Extender), Hood lift assist $80 (RedlineTuning), Hood light $53 (tacomaworld.com âtacodaneâ), Hitch receiver $120 (Curt Manufacturing 13323 Class III Receiver), T connector for trailer $43 (CURT Manufacturing 55513 T-Connector), Manuel tailgate lock $30 (gatekeeper tailgate lock), Tailgate assist $28 (Sachs SG329900EZ Lift Support), Tailgate lock $67 (Pop & Lock Tailgate Lock Tailgate Lock PL5301), Spare tire lock $12 (Trimax ST30 Trimaflex Spare Tire Cable Lock), Hardwired battery float charger $20 (Schumacher SE-1-12S-CA Fully Automatic Onboard Battery Charger - 1.5 Amps) , Vin # Glass etching $33 (vinguard.org), Easy oil drain plug $30 (Fumoto Engine Oil Drain Valve), Floor mats $80 (Husky Liners 2-Piece Front Liner 2-Piece Front Liner), out of space :)
    I bought 4 new stock rims for winter tires, need 4 sensors. OEM # is 4260704010. Can anybody conferm that "interchange Part Number: PMV108J" will work on my 2013 5 lug. thank you.
  9. Feb 26, 2015 at 1:43 PM
    4OYOTER
    4OYOTER Well-Known Member
    Alan
    Cedar Park, TX
    4Runner
    I would recommend a 7002 Redi-sensor. They are $45.99 each at Costco.
  10. Feb 26, 2015 at 5:01 PM
    egres
    DELCO PA
    So sensors are interchangeable, more or less?
    Does pressure monitoring system has separate fuse? (if I don't buy sensors)
  11. Feb 26, 2015 at 5:31 PM
    4OYOTER
    Alan
    Cedar Park, TX
    4Runner
    Not all sensors are interchangeable. They operate at different frequencies. Our Tacomas are 315 mhz. No fuses that I know of
  12. Mar 1, 2015 at 11:45 AM
    spiralout462
    spiralout462 Well-Known Member
    Eastern Shore VA
    2015 4x4 dclb
    Icon suspension '15 toyota nav TRD FJ SE anthracite wheels Weathertechs Trd pro pieces
    Pipe Bomb for the win! Still relevant after all these years.
  13. Mar 2, 2015 at 5:21 AM
    egres
    DELCO PA
    Someone told me that in oppressed states that heavy-handedly push for mandatory “safety” equipment like ABS that doesn’t work, that adds to the price of the truck almost two fold. So :) in those states, it’s mandatory by law to put sensor in tires if your truck is equipped with low air warning system.
    Legally, you can’t just put regular air valve stem.
  14. Mar 2, 2015 at 8:49 AM
    spiralout462
    Eastern Shore VA
    2015 4x4 dclb
    It's pretty sad that it has come to this! :(
    We must protect ourselves from ourselves!
  15. Mar 2, 2015 at 2:34 PM
    egres
    DELCO PA
    Does sensors continuously transmit or does it so often? Apparently battery lasts 5 years, if it transmits continually it will run down quick… I would think…
