Air scoop on engine hood
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SafetyPete, Aug 27, 2022.
  1. Aug 27, 2022 at 12:16 PM
    SafetyPete
    SafetyPete [OP] New Member
    Pete
    2006 Blue Tacoma TRD 4 door
    I have a 2006 Tacoma TRD, when I take a close look at the air scoop on the engine hood i don't think it actually works. does anyone know if they (Toyota) has put these in place for looks only?
  2. Aug 27, 2022 at 12:17 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Just for looks.
  3. Aug 27, 2022 at 12:17 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Yes, they are for looks only.
  4. Aug 27, 2022 at 12:18 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    It's only for looks, it's dammed in the back, you can of course do as I've done and removed the dam and open it up keeps under hood temps a little lower and much cooler in low speed offroading but it's certainly no intake.
    IvanhoeTaco and SafetyPete[OP] like this.
  5. Aug 27, 2022 at 12:22 PM
    SafetyPete
    Pete
    thank you very much you all. Now I can take it apart and paint it without a worry.
    Key-Rei likes this.
  6. Aug 27, 2022 at 12:47 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    I disagree. I misplaced my dyno test printout but the extra 40hp my skeewp confirmed to provide will allow me to get a 2nd gear scratch.
    Key-Rei likes this.
  7. Aug 27, 2022 at 12:51 PM
    IvanhoeTaco
    IvanhoeTaco Well-Known Member
    Eastern NC
    2005 Supercharged Converted Prerunner
    Total Chaos 3.5 LT, King Coilovers, 35x11.5r17 on Falcon T2, ADV 4 inch fiberglass, 4.88 gears, FJ cruiser transfer case, 4 runner front diff, Cab mount relocate, archive hangers, shackles, king 2.5x14 rear shocks, icon rxt leaf springs, king hydro bumps
    Haha! The ole, "couldnt print your alignment sheet because our printer is down"
    And of course on a dyno the skewp is working more!
  8. Aug 27, 2022 at 1:22 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
  9. Aug 27, 2022 at 10:50 PM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
