Airbag light is on
Discussion in 'Technical Chat' started by cctd, Jun 21, 2010.
  1. Jun 21, 2010 at 8:06 PM
    cctd
    cctd [OP] Member
    tx
    03 PreRunner SR5 V6
    Hello, I have a 03 v6 double cab Tacoma with 80K miles. This truck has been pampered for 7 years. all of the sudden the SRS light came on today. I've read some others post mention about the connection under the seat but I did not see anything under the seat. Can anyone here know how to reset it. Thanks in advance.
  2. Jun 21, 2010 at 8:09 PM
    747 function > form
    1st Gen.
    With something this important, I'd go to the dealer.
  3. Jun 21, 2010 at 8:09 PM
    Brunes
    Brunes abides.
    Rotorhead
    Have you recently done any electrical or body work?? Any interior stuff??
    If you have not- It is entirely possible that (after 7 years) you just have a sensor that has gone bad.
    If you've looked for plugs under the seats, you can pull a wiring diagram/FSM and try to find where the other sensors are and see if there are any obvious problems...but with out the computer it's hard to diagnose something like this. Dealerships are equipped for it.
  4. Jun 21, 2010 at 8:09 PM
    PhilipRoth
    PhilipRoth Well-Known Member
    Az
    06 Tacoma
    King shocks!
    Same happened to me about a month ago. I took it to toyota, plugged the computer in and a coil in the airbag on the steering wheel came disconected. Costed me 430 bucks to fix it
  5. Jul 1, 2010 at 1:17 PM
    cctd
    cctd [OP] Member
    tx
    03 PreRunner SR5 V6
    Well. I took it to a dealer today for diagnostic ($105.00). They told me have to replace the air bag assy sensor first and it will cost me total price part and labor for $834.50. After that if the light still on they will check something else and it will cost more. I really think that is a ridiculous just for the airbag light. it will not effect the performance of the truck or anything else except the airbag won't deploy. what do you guys think? please give me advice if you know the way around it.
    Thanks
  6. Jul 1, 2010 at 1:32 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    I would replace clock spring in steering wheel first. Cheap and easy, in 99% of cases this is it.
  7. Jul 1, 2010 at 1:42 PM
    cctd
    cctd [OP] Member
    tx
    03 PreRunner SR5 V6
    Thanks Blue T. how and where do I get that part for replacement?
  8. Jul 1, 2010 at 1:45 PM
    BlueT
    NorthEast
    hold on looking the part up
    Your truck is 2003 right
    V6
    manual ? Auto?
  9. Jul 1, 2010 at 1:59 PM
    BlueT
    NorthEast
  10. Jul 1, 2010 at 3:29 PM
    cctd
    cctd [OP] Member
    tx
    03 PreRunner SR5 V6
    Thanks Blue T. Do you think this can be done by DIY? or it has be done by the dealer? by the way mine is auto V6.
  11. Jul 2, 2010 at 9:21 AM
    BlueT
    NorthEast
    Definitely, at least you can inspect by yourself. Just make sure you disconnect battery first and give 20 minute pause before you are unbolting the steering wheel with airbag (that allows all the capacitors in electronics to loose charge)
  12. Jul 3, 2010 at 7:22 AM
    cctd
    cctd [OP] Member
    tx
    03 PreRunner SR5 V6
    Thanks Blue T. I found the part but nobody has a picture of the part so I can look at . Does it look like a cake or something per PDF file? and it's over $200. How do I know it bad or good?
  13. Jul 3, 2010 at 8:54 AM
    BlueT
    NorthEast
    Take a look at fsm there are troubleshooting steps for that spiral cable. In short what you need to check is electrical continuity. Between plugs on that cable. Remove it first inspect
    Here is the link from pirate
    http://www.pirate4x4.com/forum/showthread.php?t=697181
  14. Sep 8, 2011 at 1:45 PM
    Nelz1
    Nelz1 Well-Known Member
    Boston
    07 Tacoma DC TRD
    Bilstein 5100 leveled bed panels fabricated, bed d rings, fog light mod.
    Do you know if once the clockspring repair is made and installed if the airbag will turn of --or do you need the trouble code reset by a computer??
    Thanks-
  15. Sep 29, 2011 at 1:58 PM
    Nelz1
    Boston
    07 Tacoma DC TRD
    Thought I would answer my own question----The Air bag light will go out on its own after the repair is made.
    Holzcman80 likes this.
  16. Oct 1, 2011 at 6:37 AM
    Loadout66
    Loadout66 New Member
    AZ.
    99 Taco,v6;4wd;2.5" lift.
    2.5 inch lift.Donahoe coilovers in front,Downey leaf springs in rear,4 Runner buckets and console inside,5100 Bilstiens in rear.
    great info as my light came on one cold morning up north.
