Airbag Light on 99 Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chive On Tacomas, Feb 5, 2014.
  1. Feb 5, 2014 at 9:52 PM
    Chive On Tacomas
    Chive On Tacomas [OP] New Member
    Oregon
    99 tacoma SR5 and 01 4 runner SR5
    My Airbag warning light is on I was wondering what could cause this. Is this something I should just take and have checked at dealership or is this a common problem?
  2. Feb 6, 2014 at 10:11 PM
    JayDub
    JayDub Well-Known Member
    Jay
    Pendleton, SC
    06 Tacoma DCSB 4x4
  3. Feb 8, 2014 at 11:36 AM
    Greensystemsgo
    Greensystemsgo 1 owner with clean car fox.
    Dirty Nickers
    Peoria, AZ
    18 year old black taco...
    Bone Stock.
    take it to dealership or a qualified shop.
    many, many, many thigns can be wrong. clock spring, connectors, switches, crash sensors, seat sensors, wiring, etc etc etc. get it done right. its expensive but alot cheaper then hospital bills.
  4. Feb 8, 2014 at 11:40 AM
    99nmtaco
    99nmtaco Well-Known Member
    Patrick
    NM / VA
    2001 4 Runner
    ADS racing shocks ext travel front, ADS FJC piggyback shocks rear, Addicted Offroad front plate bumper, 4xinnovations rock sliders and rear plate bumper, SCS Stealth 6s
    Mine did this a couple months ago. Turned out it was the wires going to my seatbelt connector on my drivers side. One wire had stripped because of how it sits against the seat and the metal clip holder for the belt. Just electrical taped it and its been fine since. It was making contact with the metal and shorting it out I guess.
  5. Feb 8, 2014 at 3:53 PM
    Zer0
    Zer0 Well-Known Member
    SGV, California
    99 PreRunner
    I had this damn issue not too long ago. And it came about right after I installed an alarm and head unit. OBD-II reader will not reset the airbag light -I've tried it. At first, I thought it was because I started my vehicle with the airbag plug disconnected from the passenger airbag switch. That wasnt the problem in my case.
    Turns out....The airbag wires that go into the Airbag brain, located under the ashtray, were getting pinched. When I installed back my center trim after installing the head unit, the 12v Cigerette wires were smashed down against a few airbag harnesses. Anything harness in your vehicle with yellow loom is related to the airbag. Be careful and try not to disturb or smash these wires. Smashing the wires can cause the ECU to read low current in these airbag wires which will cause the light to come on. Might be different in your case but this is what happened to me! Hope this helps good luck!
  6. Feb 9, 2014 at 6:01 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Mine is on too after installing a new headunit and starting and driving around with airbag stuff unplugged. I'll check to see if I pinched something.
    Here's a comment from a link to resetting the light without a scan tool, though.
    "Typically, when you see the SRS light staying on all the time like this it usually has to do with a malfunction or corrosion in the SRS ECU/computer. In the diagnostic check box under the hood place a jumper wire in the terminals TC and E1. Then turn ignition key on and monitor the SRS light and see if it flashes at all. Let me know what you find. "
    http://www.justanswer.com/toyota/6610e-1995-toyota-tacoma-140-000-miles-air-bag-light.html
  7. Jun 13, 2014 at 10:01 AM
    ElTacoma
    ElTacoma Well-Known Member
    San Luis Obispo
    2011 tacoma wheels, spidertrax 1.5" lug-centric spacers, magnaflow exhaust, magnaflow cat
    This may sound dumb, but can airbags go off spontaneously if this light is on? I suppose anythings possible
  8. Oct 15, 2018 at 10:07 AM
    Newbie62
    Newbie62 Member
    Rusty
    1999 Toyota Tacoma Prerunner
    My 99 Taco SRS light was constantly blinking slowly, It was throwing 2 codes that I don't have access to now but the way I fixed it was with the ignition off, unplug the 3 connectors on the SRS module under the ash tray and reconnected them and the light went away !
    woodpost and Funkensour like this.
  9. Aug 22, 2022 at 5:28 PM
    woodpost
    woodpost Member
    Cupertino, CA
    '99 4x4 SR5 TRD
    yep, this worked for me too. PHEW.
  10. Aug 22, 2022 at 6:25 PM
    noodles93
    noodles93 Well-Known Member
    Charleston, SC
    1999 Tacoma Prerunner 2.7
    Pull the codes and see? Mine was throwing a b1100 the entire assembly was shot. Found a new computer on ebay ~$60 from a part out threw it in works great.
