Airbag light on but no code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by manethon, Apr 21, 2018.
  1. Apr 21, 2018 at 8:56 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    Hey guys,
    I have tried multiple obd2 scanners with different iPhone and android apps without getting a single code. The airbag light is on and i cant get this thing to pass a safety due to it. I tried a hand held scanner from Cnd tire $350 dollar unit that said it could pick up SRS codes but yet nothing on that either. Any input ?
    would these wifi/blue tooth OBD2 readers + apps pick up air bag codes?
  2. Apr 21, 2018 at 9:11 PM
    go2cnavy
    go2cnavy Well-Known Member
    ‘17 OR DCLB. VF Tuned, 5.29s, Dobinson’s MRR
    OVTuned w/ 5.29s 2” lift on Dobinson’s MRR paired with ICON RXT leaf packs. SCS RAY 10s Toyo Open Country AT III 285/70R17
    Slide your seat forward and/or check for something between the seat and the airbag panel.
  3. Apr 21, 2018 at 9:12 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    sorry what do you mean
  4. Apr 21, 2018 at 9:13 PM
    go2cnavy
    My airbag light comes if I slide my driver’s seat all the way back. Something to do with the position of the seat in relation to the side airbag panel.
  5. Apr 21, 2018 at 9:14 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    i should have said mines a 2007,
    doesnt have that side air bag
  6. Apr 21, 2018 at 9:19 PM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  7. Apr 21, 2018 at 9:21 PM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    Thats a fact eh.... ok.
    Sucks!
  8. Apr 21, 2018 at 9:22 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Duck tape over the idiot light? Get a better scanner or, dare me to say...dealer?
  9. Apr 21, 2018 at 9:42 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Try turning on your key, wiggle/ push on all the wire connectors at the module under the passenger seat. Periodically check the dash to see if the light goes out. Toyota also has a recal on certain year trucks so it might be part of that too
  10. Apr 21, 2018 at 10:28 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    What does that even mean? What is an "airbag panel"?
  11. Apr 21, 2018 at 10:30 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    No. There are no devices that tell the system what position the seat is in.
    It sound more like you have a loose connection or a damaged wire harness.
    Torspd likes this.
  12. Apr 21, 2018 at 10:34 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    2007. It could be a defective spiral cable in the steering wheel. As stated above there is a recall for that.
    Go here: https://www.toyota.com/recall and enter your VIN ( Vehicle Identification Number ).
    Torspd likes this.
  13. Apr 22, 2018 at 5:10 AM
    L J
    L J Well-Known Member
    Illinois
    07 4X4 SR5 TRD Sport DCLB
    this^ I had the spiral cable go bad and the airbag light came on. Also the horn stopped working.
  14. Apr 22, 2018 at 6:46 AM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    My vin is not included.
    I am trying to get the code so i can escalate to Corp Toyota without having them pull the code. They had a "booked" rate for assessment of $129.
  15. Apr 22, 2018 at 6:47 AM
    manethon
    manethon [OP] TTAS
    Steven
    Unknow
    Many
    My horn is fine,
    My seats have been removed on multi accounts, all plugs are double check and triple checked.
    The panel below the stereo also is double checked and the air bag ON botton is perfect there as well.
    I read there is some one to jump the fuse some place and the code will read out on the dash ? sounds sketchy to me
  16. Apr 22, 2018 at 7:28 AM
    Bebop
    Bebop Old fashion cowboy
    Nick
    Castle rock Colorado
    2012 Toyota Tacoma baja
    6inch lift sitting on bilstein coilovers. Lexus is300 studs in front to keep stock wheels, general grabber red letters, nfab front bumper.
    You need a scanner that can read airbag and body module codes. A simple obd code reader won’t read air bag codes
  17. Apr 22, 2018 at 7:41 AM
    BrokenMech
    BrokenMech Well-Known Member
    Upstate, NY
    2019 4Runner TRD Pro
    I had the airbag light come on in my 14. Took it to the dealer and they reset it.
    Can’t remember how much it cost but it was fast and simple and hasn’t given me trouble since.
  18. Mar 19, 2021 at 1:17 PM
    Kimbob
    Kimbob New Member
    Silver Tacoma TRD
    Bluedriver scanner pulled codes on everything .... my front airbag sensor was bad... behind front bumper just below headlight ... look for yellow cable/sensor...
    deanosaurus and Torspd like this.
