airbag light on?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hamNswiss on rye, Jul 26, 2011.
  1. Dec 23, 2011 at 2:54 PM
    #61
    TheHansen
    TheHansen Well-Known Member
    Mattapoisett, MA
    05 DC Sport
    dtrl mod Fog light mod Bed lights Under hood lights Rear window decals tint matched front windows Rear dif breather mod weathertech floor mats Bed mat Scan gauge 5100's and 885's lean spacer 1.5 in aal, 1" block and OME rear shocks Dynomax muffler (weld in) Truxedo lo pro qt bed cover Devil horn Emblem Plasti dip badges plasti dip radio plasti dip ac control all pro rear bumper with side pieces All pro front bumper All pro bolt on sliders illuminated 4x4 switch JBA long tube headers URD o2 Sim
    I had an airbag light on my 05 that i fixed last summer. Have you jumped the terminals on the obd2 terminal to get the codes yet?
    I had code 13 and 31. My problem was i had a bad crash detection sensor in the front bumper. When i took it off the connections were corroded. 85$ for a new one (i think) and the light has been off for month since.
  2. Dec 24, 2011 at 6:48 PM
    #62
    HILOTOY
    HILOTOY HILOTOY
    From Big Island
    05 trd 4wd off road,tow pack
    Thanks for the replies:)...................one more thing to check. I didn't jump the terminal, got the SG2 and I keep getting all clear- no codes. :confused: Might put a pic of the grandkids over the light:D
  3. Dec 24, 2011 at 11:42 PM
    #63
    surferkid
    surferkid Zombie Killer
    San Marcos, CA
    07 SR5 4x4 2.7 5spd
    camper, thule board racks, wet okole seat covers, AFE dry filter, smittybilt light bar
    the sg2 wont pick up the code you need an actual scanner with srs data cause i tried two different code readers and computers and then finally went back to my college shop and checked out their snap-on modis (gizztastic by the way) in order to pull my code
  4. Dec 25, 2011 at 9:45 AM
    #64
    TheHansen
    Mattapoisett, MA
    05 DC Sport
    If you jump terminals 4 and 9 with a wire or paper clip or something. and turn the key to on you will notice a lot of lights flashing (abs,cruise ect). The airbag light will flash in a way to tell you the code. For example if the code is "13" it will flash once, pause, then flash three times in a row, then pause again. If their aren't any other codes it will just keep repeating.
    Once you have your code go here. And scroll to the code and it will tell you what's wrong/ what to do to find out what is wrong.
  5. Jan 2, 2012 at 2:59 PM
    #65
    HILOTOY
    HILOTOY HILOTOY
    From Big Island
    Thanks:D...............will try that when I get pissed with that light....
    HAPPY NEW YEAR TO ALL
  6. Jan 5, 2012 at 3:12 PM
    #66
    dgoza
    dgoza New Member
    David
    Texas
    05 Tacoma 4x4 4Dr
    My airbag warning light came on solid around 67,000 miles on my 2005 4DR 4WD V6. I changed my plugs (following the advice I found on this forum) about 3 months ago and after that my airbag light started coming on infrequently. As soon as the extended warranty ran out last month, the light stayed on. I also paid $507 to the local Toyota dealer to get it fixed. I just got my two front wheel bearings replaced (under the extended warranty) and I have had to replace other major parts that just stopped working. If Toyota knows Tacomas are having all these problems, why are they not fixing these things?? I have never had a Taco truck that gave me this much trouble and has cost me this much money to keep on the road.I don't dog my truck and keep my truck maintained. I have always had Toyotas but now I am thinking seriously about switching to GMC.
  7. Jan 25, 2012 at 1:47 PM
    #67
    pgiroua
    pgiroua Geaux Tigers
    Royce
    Cypress, TX
    07 PreRunner SR5
    Fog Lights "a la Caribe Style", 20% Tint, csjumper2003's LED's (dome, map lights, park lights), Sylvania ZXE headlights and fog lights, Tonnopro Bed Cover, DTRL on any time mod by piercedtiger, Maxtrac Spindles, Bilstein 5100's (front and back), OME 883 Coils, All Pro Standard Leaf Pack
    Very nice first post. Speaking from experience, I wouldn't go GM...
  8. Feb 2, 2012 at 9:09 AM
    #68
    mknipp
    mknipp Well-Known Member
    My airbag light just came on last night. 2007 4x4 AC, only 62k miles. I'm going to try to read the codes myself (never done it before) but seems so many people are having this issue that toyota should do something. Thanks to this forum, i will probably try the repair myself to save money. It's absurd they want $400 for this repair, it's like they are preying on the fact that it's a safety issue so they know people will pay for the fix. How does the clock spring go bad? It's not a wearable part?
  9. Feb 28, 2012 at 2:51 PM
    #69
    bkthompson6
    bkthompson6 Well-Known Member
    Brandon
    Oregon
    Ok, so my SRS light is on. (Feel like an idiot saying this) When i was installing my CB radio i was checking wires with a test light and accidentally checked one of the SRS wires. Which I'm guessing grounded out the system. There is no broken wires or anything like that. To me it sounds like something just needs reset, like a computer or something. The local stealership told me that they had to run a whole new wiring harness for around a thousand dollars. :eek: On myairbags.com they reset airbag modules for fairly cheap. Does anybody know if this should fix it? If i do the paperclip method of reading the code it should tell me exactly whats wrong right? Thanks for any and all replies!
  10. Feb 28, 2012 at 3:01 PM
    #70
    bkthompson6
    Brandon
    Oregon
    Another thought.... I was reading up on the paperclip DTC reading, and it states you can clear DTC codes as well, think this would work?
  11. Feb 28, 2012 at 6:32 PM
    #71
    bkthompson6
    Brandon
    Oregon
    anybody????
  12. Feb 29, 2012 at 6:32 AM
    #72
    fbconvert
    fbconvert Well-Known Member
    Brian
    Seacoast, NH
    2005 Tacoma Double Cab TRD Sport
    If all you did was ground the SRS wire I would attempt to reset the module yourself. I have sent my module to Myairbags.com and they do a fine job. I was recently in an accident and my bags worked flawlessly so I am speaking out of experience. But they remove hard errors from your module and if you have not been in an accident I would not suspect you have any hard errors. I am not sure how much you have read in these SRS Forums but one of the major downfalls to the 2nd gen Tacoma is the clock spring. When it fails your light turns on. I am in the process of sending my clock spring to myairbags.com with in a week or so to get it repaired since I have this issue. Just something else you might have to consider.
    Anyways there are two ways to read DTC error codes. the obvious one is with an OBDII Scan tool with the appropriate software. This is not a typical option for most but if you have access to one and know how to use it then you are in good shape.
    The other option is using a jumper (like a paper clip) to connect specific wires that will make the airbag light blink the error code.
    Check out this link. (Note: The SST Wire or Special Service Tool Wire they mention on the first page is just a wire that can be plugged into the harness to connect the specified circuits. like a paper clip)
    Follow the instruction on how to read your error code. Then go here to determine what the code means.
    In that first link it also gives instructions on how to reset the module. I would actually suggest trying that first. If that doesn't work then I would begin trouble shooting.
    Let me know if this is any help. I am learning as I go too so take whatever I say with a grain of salt because I am by no means an expert.
    Good Luck!
  13. Mar 7, 2012 at 3:52 PM
    #73
    CSCHOL
    CSCHOL Well-Known Member
    Chad
    W. Michigan
    ‘23 TRD OR
    Stocker
    DETROIT — Toyota Motor Corp said on Wednesday it is recalling more than 681,000 cars and trucks in the U.S. market to address potential problems.
    The Japanese automaker said it will recall about 495,000 Tacoma pickup trucks from model years 2005 to 2009 to replace a part in the steering wheel. It is also recalling about 70,500 Camry mid-sized cars and 116,000 Venza crossover vehicles from model years 2009 to 2011 to replace a stop lamp switch.
    Toyota said it is not aware of any accidents or injuries in either case.
    For the Tacoma, Toyota will replace the steering wheel spiral cable assembly because friction may occur over time involving that part, which may result in the driver's side airbag being deactivated and not deploying in an accident.
    For the Camry and Venza, silicon grease during assembly may lead to increased electrical resistance that can cause the vehicle not to start or the shift lever not to move from the "park" position, Toyota said.
    Both fixes will take about 30 minutes, the company said. Owners of the affected Tacomas will be notified in early April, while the others will be alerted as soon as Toyota has the necessary replacement parts.
  14. Mar 7, 2012 at 9:25 PM
    #74
    ilovetacos
    ilovetacos Well-Known Member
    Gavin
    Sacramento/Woodland
    2006 TRD Sport 4x4 DC
    Sold!
    Mine is covered :taco:
  15. Mar 8, 2012 at 8:11 AM
    #75
    Dirt Ferguson
    Dirt Ferguson Well-Known Member
    Daniel
    Napa Valley
    15 MGM DCSB TRD Sport
    KING 2.5 EXT, Total Chaos UCA, SCS F5, Katzkin
    Me too, hallelujah!!! Good move by Toyota. It's about time. So happy to not have to stare at that light anymore.
  16. Mar 9, 2012 at 9:25 AM
    #76
    undecided
    undecided Well-Known Member
    Adam
    San Diego, CA
    06 TRD Sport 4X4
    CAI, CB radio, Double Din Stereo, Aero Exhaust, Softopper, BHLM, KODE Push Button Start, Bruteforce Fab Rear bumper, Weathertechs
    My light has been on for almost a year now... I cant wait to get this done! :woot:
  17. Mar 9, 2012 at 9:48 AM
    #77
    undecided
    Adam
    San Diego, CA
    06 TRD Sport 4X4
    My ex had an 07. Hers came on within a year and a half of having the truck. She had it fixed by the stealership for $500 and change. Mine came on about a year after hers and I kinda just shrugged it off. I am glad Toyota is acknowledging a major safety issue and a faulty part that seems to be failing in more than just the Taco.
  18. Mar 12, 2012 at 6:57 PM
    #78
    stmpjmpr
    stmpjmpr Well-Known Member
    Jimmy
    So Orange County, Ca
    2014 Tacoma Sport MGM 4X4
    sweet. my light has been on for a very long time. cant wait for this recall. This one will not be ignored like the others.
  19. Mar 15, 2012 at 10:36 AM
    #79
    Tacozoid
    Tacozoid Well-Known Member
    Terry
    Katy Texas
    White Tacoma Pre-runner
    Billsteins,Texas tint. Blue Dash mod. Console mod. in Blue, Customized grille
    Mine came on about 7 months ago. I am waiting to find out more on a possible recall. 05-09 models. Mine is an 06. I can be it's the COCK spring!
  20. May 21, 2012 at 3:29 PM
    #80
    dgoza
    dgoza New Member
    David
    Texas
    05 Tacoma 4x4 4Dr
    I talked to one of the people at Toyota Customer Satisfaction last week about the Clock Spring cable recall. I had already gotten mine replaced at the dealer last fall for around $500 and now Toyota sends me a letter telling me there will be a future recall on this. So, I called them. The lady I talked to very patiently listened while I politely ragged on about the dog truck I had bought (this was not the first major repair I have had to do to my 05 truck with only 73,000 miles on it). I was polite but I think she knew I was very,very PO'd. When I asked her why something had not been done about this before, she gave me the extremely irritating line about "If nobody tells them about the problem, they can't fix it", even though as you guys have indicated, they have known about this for a few years. She said I would probably get my money back if I ever get the actual recall letter and then I take my truck back to the dealership and have them verify the recall was done (= more $$$$$$), and if I produced enough evidence that I was still breathing, and if I have documented proof that I had actually paid for the repair, and if I have proof that I had actually been born, and if I get proof that the truck in question truly is mine (why did they send me a letter if it is not my truck??) and if I send them a whole lot of other ridiculous-keep me busy paperwork (like my bank statement- really??). :confused::mad:
    Suggestions anyone?????
