Alabama thread!
Discussion in 'Alabama' started by Davtopgun, May 18, 2009.
  1. Feb 5, 2021 at 11:23 AM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    If it is leaking it will blow oil out the breather and cycle on and off, mine would cycle about every 60 to 120 seconds
  2. Feb 5, 2021 at 12:06 PM
    BamaTaco56
    BamaTaco56 Well-Known Member
    Trey
    This is why they are coined “air leaker”
  3. Feb 5, 2021 at 12:16 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    never had an issue with either one of mine. I doubt his is the seal. he probably just overfilled it.
  4. Feb 5, 2021 at 12:30 PM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    I flipped on my compressor, no short cycles. Only cycled after a few engages/disengages. Left the air on for about five minutes. Flipped the locker on only in 2wd if that makes a difference for this test.
  5. Feb 5, 2021 at 12:31 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I've seen too many people on TW complain about diff fluid coming out of their breather only to find out it they over filled it. I got water in my diff when i went to coppinger and water/oil was coming out diff breather cause it was overfilled. Ever since ARB went to the new seals i haven't seen one person have the issue that Jeff described. Jeff hasnt had an issue with his either that i know of. Maybe his could be different but that's why i said i doubt it.
  6. Feb 5, 2021 at 12:33 PM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    If the air locker is disengaged and no air being given to the system would a bad seal still make the fluid rise enough? I haven’t engaged my front locker or compressor for probably two weeks
    I first noticed it after getting an oil change/alignment right after I regeared. I thought they were just sloppy with the engine oil. That doesn’t help the timeline though.
  7. Feb 5, 2021 at 12:37 PM
    BamaTaco56
    Trey
    interesting. I haven’t seen those issues. Oil does expand when it gets hot, but that’s just a long way to go.
    I have seen several folks have issues with even the new ARB seals though. It’s still one of the best / strongest lockers out there though.
  8. Feb 5, 2021 at 12:40 PM
    BamaTaco56
    Trey
    If no air is in the system, a bad seal would be out of the equation I would think.
    Dayman Karate[QUOTED] likes this.
  9. Feb 5, 2021 at 12:42 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    https://www.tacomaworld.com/threads/the-5-29-mega-thread.557305/page-143#post-23919964
    https://www.tacomaworld.com/threads...st-gen-edition.138573/page-9619#post-22658230
    https://www.tacomaworld.com/threads/leaking-front-diff-breather-causes.523253/
    Read these threads. Seems to be a common problem slightly over filled
    Dayman Karate likes this.
  10. Feb 5, 2021 at 12:46 PM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    I reallllly don’t want to take that damn thing out again haha I’m going to start with draining it a bit, because I was paranoid I wasn’t filling it enough the first time
  11. Feb 5, 2021 at 12:48 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Let some diff fluid out and and see if that helps. If it doesnt might be a seal if you locked the diff anytime before you noticed it.
  12. Feb 5, 2021 at 1:58 PM
    Toyotacrawler
    Toyotacrawler She's got the jimmy legs
    Cusseta/Opelika AL
    2010 Tacoma DC TRD Sport
    5100's set to 1.75" Wheelers 3 leaf progressive AAL & 5100's for the rear Konig Countersteer Offroads K&N Drop in WeatherTech's Bed Mat Blacked out Badges Rear leaf TSB
    You guys seen Miller Lite's ad for the super bowl? Basically if you type out a ridiculously long url that they made up during Michelob ultras commercial, they will send you free Miller Lite. I think they venmo you 8 bucks
  13. Feb 5, 2021 at 2:15 PM
    JBTacoma
    Jeff
    Cullman Alabama
    They admit they had some bad seals, most everyone I know that has them has never had any problems. Even though I have had to pull it twice I would still get another one. They even give me a $500 set of lights for my troubles.
    Dirk Diggler likes this.
  14. Feb 5, 2021 at 2:20 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    So i guess that stony ride is a no go?
  15. Feb 5, 2021 at 2:21 PM
    JBTacoma
    Jeff
    Cullman Alabama
    Maybe not
  16. Feb 5, 2021 at 2:22 PM
    JBTacoma
    Jeff
    Cullman Alabama
    You going?
  17. Feb 5, 2021 at 2:23 PM
    JBTacoma
    Jeff
    Cullman Alabama
    If the compressor is not cycling it isn't the seal.
  18. Feb 5, 2021 at 2:25 PM
    JEtaco03
    JEtaco03 Well-Known Member
    Justin
    New Market, AL
    08 Tacoma TRD
    Lifted on 18s and tires, LEDs all around
    Wyatt and I are still going. He as been looking forward to it for 3 weeks. We are going to ride until we are miserable and then dry off and come home. You want to come sling some mud?
  19. Feb 5, 2021 at 2:30 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Im not really a mud kinda guy lol. Just got my truck semi clean so im probably not goona go haha.
  20. Feb 5, 2021 at 2:32 PM
    JEtaco03
    Justin
    New Market, AL
    08 Tacoma TRD
    it's going to rain on your way home for a natural quick wash off, :rofl:
    baldridge and Brian422[QUOTED] like this.
