Alarm and Power windows
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pinktaco808, Oct 3, 2011.
  1. Oct 3, 2011 at 7:24 AM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    Anyone have the diagram so that I can hookup my power locks. Also anyone have a wiring diagram on where they hooked up there power windows too the wires in the factory wires?I wanna know what /where people hooked up there power window too. 06 Single cab 4cylinder base model
    I have a Alarm system Hornet 740T and need the wire diagram so that I can wire my power locks to this alarm system. Thankyou
  2. Oct 3, 2011 at 7:36 AM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2015 TRD Sport
    Clazzio Seat Covers Extang Tri-Fold Soft Tonneau Cover TRD Skid Plate AMP Research Electric Steps 43% Llumar Security tint TRD Exhaust Fox 2.0 coilovers and rear shocks 16" TRD Fake Beadlocks Custom LED Cube mounts in foglight location TRD Pro Grill Wheelers progressive aal
  3. Oct 3, 2011 at 4:44 PM
    pinktaco808
    Sorry about that it aftermarket parts the same one the Ronus americanus did. He never installed it him self and had a shop do it. My questions is where would I run the power window locks too? Do you have a factory diagram for power window and locks and pictures that I can use as a reference?
  4. Oct 3, 2011 at 4:54 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    Sorry no diagrams or pictures, I have not installed power windows/lock on mine yet still not sure if I'm going to, but I have installed them before usually you just need a 12V source (tap in to the fusebox). Not sure if toyota left anything pre-wired on the regular cabs. For the alarm you usually need to tap in to one wire only either the power or ground wire that goes from the switch to the regulator/motor.
  5. Oct 3, 2011 at 6:21 PM
    pinktaco808
    anyone know if it prewired? got pic diagram
  6. Oct 3, 2011 at 9:10 PM
    pinktaco808
    ok well anyone that did this mod where did you guys tap into?
  7. Oct 8, 2011 at 6:12 PM
    pinktaco808
  8. Oct 8, 2011 at 6:22 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    hs or h2?
  9. Oct 8, 2011 at 8:00 PM
    pinktaco808
  10. Oct 8, 2011 at 8:02 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    you'll need it for unlocking/locking the doors with the key fob
  11. Oct 9, 2011 at 9:56 PM
    pinktaco808
    key fob?
  12. Oct 9, 2011 at 10:01 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    the key-chain beeper/remote
  13. Oct 9, 2011 at 11:00 PM
    pinktaco808
    well the kit im getting doesnt have it.
  14. Oct 9, 2011 at 11:07 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    you only need to hook up one wire from the h2 harness, maybe you can find a connector small enough that works
  15. Oct 9, 2011 at 11:10 PM
    pinktaco808
    yes, but my power door locks dont come with a separate keychain beeper. I was wondering if i can make it work with the alarm it self keychain beeper?
  16. Oct 9, 2011 at 11:12 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    yes that is what that harness is for, it connects the alarm to your door locks, so you can unlock/lock the doors whit the alarm beeper.
  17. Oct 10, 2011 at 7:23 AM
    pinktaco808
    what are those other door wires on the other harness that say for door locks
  18. Oct 10, 2011 at 5:31 PM
    pinktaco808
  19. Oct 10, 2011 at 5:37 PM
    epa4wd
    Eduardo
    2015 TRD Sport
    the one that says negative & positive door pin switch?
  20. Oct 10, 2011 at 5:42 PM
    pinktaco808
