Alaska BS thread
Discussion in 'Alaska' started by benbacher, Nov 4, 2012.
  1. Nov 13, 2014 at 10:20 AM
    #7801
    N8ivFlav
    N8ivFlav Well-Known Member
    aaron
    anchorage,ak
    04 sr5 v6
    Homertaco Satoshi,Weathertech & husky liner floormats, bamf behind grill mount and led bar, leer topper, avs rain deflectors, bug deflector, Bluetooth CD player with 6 switch panel
    Ok I do have an 85 pin and as far as I can tell there isn't a dedicated wire for the relay ground
  2. Nov 13, 2014 at 11:47 AM
    #7802
    423 TACO
    423 TACO Well-Known Member
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    Happy bday old fart!
  3. Nov 13, 2014 at 12:31 PM
    #7803
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Ground it yet?
  4. Nov 13, 2014 at 1:18 PM
    #7804
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    Chassis of the light bar may be acting as the ground point right now.
  5. Nov 13, 2014 at 1:30 PM
    #7805
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    i am going to kind of assume that the light bar is being powered by the high beam circut. it needs to be powered directly from the battery. the second wire is the "trigger" wire for the relay.
  6. Nov 13, 2014 at 1:58 PM
    #7806
    N8ivFlav
    aaron
    anchorage,ak
    04 sr5 v6
    The relay is grounded on the 85 pin, 87 has 2 red wires one is going to the battery with an inline fuse the other red one is tapped into the headlight as well, the blue wire that's tapped into the headlight is going to 86
  7. Nov 13, 2014 at 2:24 PM
    #7807
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    "87 has 2 red wires one is going to the battery with an inline fuse the other red one is tapped into the headlight as well"
    This is bad! disconnect this wire(s)
  8. Nov 13, 2014 at 2:27 PM
    #7808
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    the fused red wire should be the only wire running from the battery to the relay pin 87. the other wire should be hooked up to pin 30 and going to the positive lead on the light bar.
  9. Nov 13, 2014 at 2:33 PM
    #7809
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    "other red one is tapped into the headlight as well"
    This is back feeding battery voltage through the high beam circuit
  10. Nov 13, 2014 at 2:38 PM
    #7810
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    at a minimum, pull the fuse and the relay untill this can be wired correctly.
  11. Nov 13, 2014 at 2:51 PM
    #7811
    N8ivFlav
    aaron
    anchorage,ak
    04 sr5 v6
    So I pulled everything out so it's easier to see where they are going, the red wire from the light bar is going to 30. The black wire from the light bar is going to 85 (there's 3 black wires on this) one to where the battery grounds the last one to the headlight. 87 has 2 red wires one with fuse to batt and the other to head light.
  12. Nov 13, 2014 at 4:00 PM
    #7812
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    use steveO86 wiring diagram... this is exactly how that light bar should be wired. only 1 wire should be soldered (high beam wire) at the headlight socket harness. that needs to be the wire going to the 86 pin. nothing else
    the light bar negitive wire needs to be grounded at a chassis ground or battery ground. you're golden for the positive wire on pin 30.
    the relay can be grounded the same way on pin 85. no need for 3 wires there.
    the fused red wire should be the only wire going to pin 87.
    remove the second red wire going to the headlight socket. this is connection is causing you problems... and will cause more if not removed.
  13. Nov 13, 2014 at 4:04 PM
    #7813
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
    do you want this light bar to only operate when the high beams are on? that's how your setup is right now.
  14. Nov 13, 2014 at 4:10 PM
    #7814
    toyotaT32
    toyotaT32 Well-Known Member
    Thomas
    Palmer, Alaska
    3 inch revtek in coil spacer, all pro bumper, smittybuilt 8000 winch, 265/75/17 BFG AT, cookie monster stuffed animal in bumper... UPDATE 10/17/12.... OME886 Coil lift with spacer. UPDATE 9/6/13..... Plasti dipped 17inch eagle alloy wheels. 285/70/17 Goodyear Duratracs, 6 bulb rigid industries LED D2 lights
    Do we have a Alaska for sale thread?
  15. Nov 13, 2014 at 4:22 PM
    #7815
    fergyz
    fergyz Mmmm...Tacos
    49th State
    06' DBC 4x4 6spd
  16. Nov 13, 2014 at 5:31 PM
    #7816
    N8ivFlav
    aaron
    anchorage,ak
    04 sr5 v6
    Yes
  17. Nov 14, 2014 at 12:51 PM
    #7817
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    Might be heading out tonight to see the N. Lights tonight, supposed to be visible. :woot:
  18. Nov 14, 2014 at 1:14 PM
    #7818
    N8ivFlav
    aaron
    anchorage,ak
    04 sr5 v6
    I unplugged relay n fuse, I will take care of it when I get back from the boonies this weekend... If I can make this flight
  19. Nov 14, 2014 at 1:47 PM
    #7819
    423 TACO
    Daniel
    Knox-ish, TN
    13 MGM Sport 6sp AC
    I was reading all weekend is supposed to be pretty active. I should get out myself, but don't know that I will. Still trying to get some meat on the ground
  20. Nov 14, 2014 at 1:53 PM
    #7820
    SnowroxKT
    Kyle
    Anchorage Alaska
    2008 TRD OR
    :amen:
