Alee891's Radiant Red Build & BS
Discussion in '1st Gen. Builds (1995-2004)' started by alee891, Feb 11, 2016.
  1. Mar 28, 2016 at 8:07 AM
    #201
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    @thefatkid let mepull my price book out and ill shoot you a price.
  2. Mar 28, 2016 at 8:18 AM
    #202
    3378jakesr5
    jake
    littleton colorado
  3. Mar 28, 2016 at 8:58 AM
    #203
    alee891
    alee891 [OP] Destination: unknown
    Austin
    Black Hills
    Tacomaless
    :anonymous:
    Hoping to get them installed this week. The combination of weather, school, and family has killed my time to get rig related work done.
    Brian, I'll shoot you a pm regarding the break in process shortly.
    Jake, can I swing by this afternoon to grab those stands??
    3378jakesr5[QUOTED] likes this.
  4. Mar 28, 2016 at 9:03 AM
    #204
    3378jakesr5
    jake
    littleton colorado
    would 7:30 be to late tonight on coming over? if so i can have my dad grab things out for you.. either way is fine
  5. Mar 28, 2016 at 9:05 AM
    #205
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    1st 3 trips, no more then 30minutes drive time. I would try and stay slower then 55mph. Keep acceleration loading low. Use 4wd on the straights for front diff break in. Allow the diffs to cool for about an hour or more between trips. After the 1st 3 trips drive normal keeping the load low. After 500 miles change the diff fluid, expect that fluid to be shiny and look to have metal in it, normal with break in. Do not tow for 1k miles. Try not to 4wheel for 1k miles. Use the front diff as much as possible on straights. I use standard 80-90wt for break in
    alee891[OP] likes this.
  6. Mar 28, 2016 at 9:06 AM
    #206
    alee891
    Austin
    Black Hills
    Tacomaless
    I was going to try and get the front back in this evening and the rear tomorrow. Looks like some weather is supposed to roll in by Wednesday morning...
  7. Mar 28, 2016 at 9:06 AM
    #207
    3378jakesr5
    jake
    littleton colorado
    damn i need to get going then on mine so they are ready to play!!!!!
  8. Mar 28, 2016 at 9:07 AM
    #208
    3378jakesr5
    jake
    littleton colorado
    ok well let me know what you want to do and ill get them out
  9. Mar 28, 2016 at 9:11 AM
    #209
    alee891
    Austin
    Black Hills
    Tacomaless
    I'll head that way around noon to grab them. Let the old man know I'll be stopping by!!
  10. Mar 28, 2016 at 9:12 AM
    #210
    3378jakesr5
    jake
    littleton colorado
    ouch im telling him you said that and i might reconsider letting you use the new impact!!
  11. Mar 28, 2016 at 9:13 AM
    #211
    alee891
    Austin
    Black Hills
    Tacomaless
    Thank you, Brian. I'm really hoping to start the process this week. Are you just switching between 4wd and 2wd on straights, or driving 4wd everywhere?
  12. Mar 28, 2016 at 9:15 AM
    #212
    alee891
    Austin
    Black Hills
    Tacomaless
    Fixed it!
    Also, I completely forgot about the impact. I can use the old one, too, no biggie. The addition of either will be greatly appreciated!
  13. Mar 28, 2016 at 9:16 AM
    #213
    3378jakesr5
    jake
    littleton colorado
    ill think ill let you use the baby impact
  14. Mar 28, 2016 at 9:16 AM
    #214
    thefatkid
    Brian
    Colorado
    2004 thingy
    Long sweeping turns I leave it in. Run 2wd for 90° stop light turns or other sharp turns.
    alee891[QUOTED][OP] likes this.
  15. Mar 28, 2016 at 9:17 AM
    #215
    3378jakesr5
    jake
    littleton colorado
    so i take it braking the tires loose and drifting around the corners in 4wd is not recommended for brake in? :pout:
  16. Mar 28, 2016 at 9:18 AM
    #216
    alee891
    Austin
    Black Hills
    Tacomaless
  17. Mar 28, 2016 at 9:19 AM
    #217
    3378jakesr5
    jake
    littleton colorado
  18. Mar 28, 2016 at 10:05 AM
    #218
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Should have mentioned that the mounting holes are all off on that template. On the two that I've installed, I cut the large hole through the paper, and then put one stud in the snorkel, and hold it where you want it. Then you can mark that, and adjust the template accordingly. Back holes were off by 1/2" or more. IIRC, the snorkel rotates clockwise a bit on the template.
    Anyways, looks good! :thumbsup:
  19. Mar 28, 2016 at 11:53 AM
    #219
    alee891
    Austin
    Black Hills
    Tacomaless
    Thanks bud! Luckily I had yours and Matt's write-ups to make the process fairly easy.
  20. Mar 28, 2016 at 5:53 PM
    #220
    alee891
    Austin
    Black Hills
    Tacomaless
    Front is in! :thumbsup:
    TacoVio likes this.
