Alee891's Radiant Red Build & BS
Discussion in '1st Gen. Builds (1995-2004)' started by alee891, Feb 11, 2016.
  1. Dec 19, 2016 at 10:28 AM
    #821
    cynicalrider
    cynicalrider #NFG
    Jersey
    Can those things get rebuilt/greased up again?
    alee891[QUOTED][OP] likes this.
  2. Dec 19, 2016 at 10:32 AM
    #822
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Yes. I think @lotsoftoys has a write up on his build thread.
  3. Dec 19, 2016 at 10:41 AM
    #823
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    268k on mine and headache free. Not sure why some have issues.
    I think that was an elocker actuator and not the ADD actuator IIRC.
  4. Dec 19, 2016 at 11:58 AM
    #824
    alee891
    alee891 [OP] Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Looks like I jumped the gun on assuming it was stuck.
    Now I'm curious if there is an underlying electrical issue, or if anyone may have another suggestion.
    Yesterday morning I drove around in 4x4 intermittently as the roads weren't plowed very well around Golden. Again, the front would not disengage upon stopping, shifting into 2H, and then rolling forward. I had to do a series of forward/reverse movements to get it to turn off.
    Today was a similar situation. I had to put it in 4 going up an incline on the way to the gym. When I got there, it would not disengage. It wasn't until leaving that it actually switched off (after letting it sit, turned off for a while). No difference in how I was driving from the time of arrival to departure, other then when I pulled forward while leaving it decided to switch.
    Ideas?
  5. Dec 19, 2016 at 6:14 PM
    #825
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    Is it possible the front different has pressure on it and the actuator will not disengage until that pressure is removed? Not that it matter but when was the last time your front different oil was changed?
  6. Dec 19, 2016 at 8:13 PM
    #826
    alee891
    Austin
    Black Hills
    Tacomaless
    I thought that was the case at first, but moving both forwards and back didn't seem to do anything (I traveled ~20ft in each direction in the parking lot). Diff oil was last changed around July (after regear and breakin). I had to add a bit more when I swapped out the first actuator as well. It seems like it's in the actual shifter (no click or disengage).
    I tested it yet again while leaving work and it disengaged just fine. :notsure:
    @thefatkid have any thoughts? Am I just an idiot?
  7. Dec 19, 2016 at 8:15 PM
    #827
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Have you tired to hit it with a hammer? It works in the movies!
    BYJOSHCOOK likes this.
  8. Dec 19, 2016 at 8:18 PM
    #828
    alee891
    Austin
    Black Hills
    Tacomaless
    :smash:
  9. Dec 19, 2016 at 8:18 PM
    #829
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    It's prolly just cold. Might need some slickum on the shaft to help it move easier.
    Gramps likes this.
  10. Dec 19, 2016 at 8:35 PM
    #830
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I think the relay is on the passenger side foot well. Should be able to hear that close when you shift in/out of 4x4, with the truck off but in the run position. You can also hear the actuator if it's working. I'm 99% sure that I confirmed that the motor in your old actuator was bad at RT with the volt meter. This sounds like the actuator is good it just might not be getting the signal to switch or its getting stuck for some reason. Is the breather still connected?
  11. Dec 19, 2016 at 8:58 PM
    #831
    alee891
    Austin
    Black Hills
    Tacomaless
    Yeah, the one at RT was definitely toast. I can hear the relay when it disengages...didn't hear anything when shifting, though. I'll take a look at the breather in the morning.
  12. Dec 19, 2016 at 9:09 PM
    #832
    thefatkid
    Brian
    Colorado
    2004 thingy
    Not coming out of 4wd? Typically on your generation of truck it means your drive line is in a bind. Is the light turning off? You still feel it in 4wd like binding while turning?
  13. Dec 20, 2016 at 5:27 AM
    #833
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    The add? I had posted a write up on the locker actuator rebuild
  14. Dec 20, 2016 at 6:11 AM
    #834
    alee891
    Austin
    Black Hills
    Tacomaless
    The light only turns off once it disengages. If I sit in place, do not move, and shift into 2H the light doesn't go off. It's only when I move forward, similar to what @Gramps explained, in that it seems to provide pressure relief. Again, this has been happening intermittently: it'll disengage on the spot at times, other times it won't after various shifting and moving.
    The only time there is binding while turning is when it's stuck in 4, which is also when the light is on.
  15. Dec 20, 2016 at 7:32 AM
    #835
    thefatkid
    Brian
    Colorado
    2004 thingy
    You'll have to come and see me to talk about this, usually over beer. You are describing a normal condition though
    alee891[OP] likes this.
  16. Dec 20, 2016 at 7:39 AM
    #836
    alee891
    Austin
    Black Hills
    Tacomaless
    :cheers:
  17. Dec 20, 2016 at 11:02 AM
    #837
    alee891
    Austin
    Black Hills
    Tacomaless
    Deathbysnusnu and BYJOSHCOOK like this.
  18. Dec 27, 2016 at 8:18 AM
    #838
    alee891
    Austin
    Black Hills
    Tacomaless
    Not much going on with the build since I've been in South Dakota for the holidays.
    This little gal has been taking up most of my time.
    Have some big plans for the rig that will be happening at the turn of the new year.
  19. Dec 31, 2016 at 12:34 AM
    #839
    LogCabins
    LogCabins Well-Known Member
    Robert
    Oahu
    99 SR5 3.4L 4WD
  20. Dec 31, 2016 at 5:40 PM
    #840
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Sub'd! How the hell did I miss this?!
    hehe
    SilverGhost and alee891[OP] like this.
