Alee891's Radiant Red Build & BS
Discussion in '1st Gen. Builds (1995-2004)' started by alee891, Feb 11, 2016.
  1. Jan 26, 2017 at 8:02 AM
    #881
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I looked at that.
    Very doable. A lot of ham radios face plates are quite small actually. Only 1'' tall and 4-5'' wide some times.
    Mine is huge and out of the ordinary. touch screen though so has to be.
  2. Jan 26, 2017 at 8:05 AM
    #882
    alee891
    alee891 [OP] Destination: unknown
    Austin
    Black Hills
    Tacomaless
    I'm testing the waters with handheld devices. If the hobby takes off I'll eventually get a "regular" radio. At this point I'm not certain where the handheld radio will be placed in the cab, but I'll find out soon enough.
    I'm open for ideas on the location for both types. I've thought about putting it in the bottom storage of the center console, but that'd likely be a pain in the ass to access. @3378jakesr5 once thought about putting a Corolla (?) overhead console in a Tacoma.
    There is always this option:
    https://www.tacomaworld.com/threads/switches-in-headliner.402183/#post-11221235
    I like to take the easiest route possible, so the headliner option is likely out of the question for me. I may end up just placing it near the passenger side floorboard. Who knows...
  3. Jan 26, 2017 at 8:07 AM
    #883
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    Im sure we can build some thing
    jubei and alee891[QUOTED][OP] like this.
  4. Jan 26, 2017 at 8:11 AM
    #884
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  5. Jan 26, 2017 at 8:22 AM
    #885
    Blackdawg
    Monte
    Wyoming/St. Louis
    well remember no a mobile Ham radio, the unit itself is about the size of a car stereo or even small actually. Then the faceplate removes. You can put the main radio under the seat easily and the face plate which is tiny can go many many places. Think of it as about the size of a scan gauge generally speaking.
    They are pretty easy to fit into a cab.
  6. Jan 26, 2017 at 8:25 AM
    #886
    alee891
    Austin
    Black Hills
    Tacomaless
    Link for a newb?
  7. Jan 26, 2017 at 8:33 AM
    #887
    Blackdawg
    Monte
    Wyoming/St. Louis
    mmm the best way i can show case is with my own..
    This is the ACTUAL radio. Where the antenna gets plugged into, power and SD card. As well as my mic cable and a cable for the face plate.
    [​IMG]HamStuff-2.jpg by Monte Nickles Photos, on Flickr
    This is my faceplate. This isn't a great example as again, my faceplate is huge in the world of radios. Its a small tablet almost..lol
    [​IMG]IgorsCommandCenter-40.jpg by Monte Nickles Photos, on Flickr
    But they are separate is the point. Its not like a CB where the controls are on the unit. Even though photos will show the face plates attached to the unit, they almost all are detachable. So you only have to mount a very small unit to the dash somewhere.
    alee891[QUOTED][OP] likes this.
  8. Jan 26, 2017 at 8:36 AM
    #888
    alee891
    Austin
    Black Hills
    Tacomaless
    Well that makes things a hell of a lot easier, and the face plate is significantly larger than what I was envisioning. Did you have to extend the cable for the face plate, or do they come in a generous length as is? Now I'm liking Brett's headliner idea :stirthepot:
    Blackdawg[QUOTED] likes this.
  9. Jan 26, 2017 at 8:39 AM
    #889
    Blackdawg
    Monte
    Wyoming/St. Louis
    Usually come with quite a bit of cable. Mine did. Like 10' or more i think. Easy to get longer ones if needed though.
  10. Jan 26, 2017 at 8:40 AM
    #890
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I don't need any more clutter in my cab that already has limited space. When I go the HAM route, it will be a clean and permanent install.
    Don't think I need something that elaborate for the headliner. Just a little mount for the faceplate, wouldn't be much different than a setup for 6 switches.
    But I've got an amp under one seat and a sub under the other. Maybe I can fit it in one of the cubbies in the back.
  11. Jan 26, 2017 at 9:16 AM
    #891
    alee891
    Austin
    Black Hills
    Tacomaless
    jubei and BYJOSHCOOK like this.
  12. Jan 26, 2017 at 9:49 AM
    #892
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea you probably could. You'd have to extend the mic cable but that is easy to do. All depends on the unit you get.
  13. Jan 26, 2017 at 1:29 PM
    #893
    Gramps
    Gramps My walker is faster than your Prius!
    Gramps
    Colorado! Where else?
    07 TRD DC 4x4
    A small handful of select mods.
    The Yaesu 7900R I got has a detachable face and comes with an extension cable and mounting bracket for the face. You could easily mount the face up front and stash the radio someplace else. Mine will be going in the ARB overhead console I custom fit in my truck.
    alee891[OP] likes this.
  14. Jan 27, 2017 at 12:47 PM
    #894
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    It's possible to use your phone as a display. I don't know how as I've done very little research on ham at all. I'll probably link it to my tablet on my dash if I ever go ham.
  15. Jan 27, 2017 at 12:54 PM
    #895
    Blackdawg
    Monte
    Wyoming/St. Louis
    My radio can do that. Never bothered though. I hate setting up apps on the phone to run stuff. I like having a dedicated screen with its buttons on their own devices. Faster and easier to use. Safer too in some ways.
    Gramps likes this.
  16. Jan 27, 2017 at 6:43 PM
    #896
    Reh5108
    Idaho
    How often do you change settings? I just figured you would set it to what you want and let it run in the background.
  17. Jan 27, 2017 at 8:27 PM
    #897
    Blackdawg
    Monte
    Wyoming/St. Louis
    Well if you're traveling you have to switch repeaters. So plenty. Or i monitor other channels and GPS data. Squelch is a constant change as is volume.
  18. Jan 30, 2017 at 5:26 PM
    #898
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    subd:popcorn:
  19. Jan 30, 2017 at 6:55 PM
    #899
    alee891
    Austin
    Black Hills
    Tacomaless
    :cheers:
    snowboard704[QUOTED] likes this.
  20. Feb 6, 2017 at 6:41 PM
    #900
    alee891
    Austin
    Black Hills
    Tacomaless
    Not Tacoma related, but picked up a new daily carry Glock 43 last week for an awesome deal. Previous owner was a police officer who qualified with it and never shot it afterwards. Said it was too small for his hands and he hated it. His loss, my gain. Can't shoot it for shit yet but it's a good little gun.
    BYJOSHCOOK, Red Baron, jubei and 3 others like this.
