Alee891's Radiant Red Build & BS
Discussion in '1st Gen. Builds (1995-2004)' started by alee891, Feb 11, 2016.
  1. Apr 3, 2017 at 4:04 PM
    #1161
    3378jakesr5
    3378jakesr5 AOF, trucks, guns, repeat....
    jake
    littleton colorado
    2006 DCLB silver taco. Soild axle swapped, Bumpers, armor, expo..... Money pit. Yata yata yata
    Better to ask what I have not done.
    12"*
  2. Apr 3, 2017 at 4:10 PM
    #1162
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    I don't think any pack will cycle 12" with stock mounts on a 1st gen.
  3. Apr 3, 2017 at 4:16 PM
    #1163
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
    Not even going on the outside of the frame? It would be a tight fit, but it seems possible.
  4. Apr 3, 2017 at 4:17 PM
    #1164
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    think the operative phrase Bret used was "with stock mounts"
  5. Apr 3, 2017 at 4:18 PM
    #1165
    cbechtold
    Cory
    Pleasanton, CA
    oh... :oops: ignore me :anonymous:
    alee891[OP] and ebbs15[QUOTED] like this.
  6. Apr 3, 2017 at 4:19 PM
    #1166
    ebbs15
    Brandon
    Spokane Washington
    09 Lexus GX470
    no stress, we all miss a word or two here and there :cheers:
  7. Apr 3, 2017 at 4:21 PM
    #1167
    Squeaky Penguin
    Brett
    Not talking shocks. You could put 12" shocks on but if your leafs only cycle 9" you still have 9" of travel.
    jubei likes this.
  8. Apr 3, 2017 at 4:21 PM
    #1168
    3378jakesr5
    jake
    littleton colorado
    I thought he was doing reloacte
  9. Apr 3, 2017 at 4:22 PM
    #1169
    3378jakesr5
    jake
    littleton colorado
    And my 12" shocks are my limiting factor...
  10. Apr 3, 2017 at 4:27 PM
    #1170
    cbechtold
    Cory
    Pleasanton, CA
    For myself, my Dakars could flex a good amount more if I had longer shocks. I'll probably end up boxing my frame within a year or so. Currently thinking about building shock towers in the rear fender wells for better stability and still good flex.
  11. Apr 3, 2017 at 4:34 PM
    #1171
    Squeaky Penguin
    Brett
    Report back after you cycle them.
    Only person I know that's properly cycled Dakar's on a 1st gen got like 9.5" of travel.
  12. Apr 3, 2017 at 4:37 PM
    #1172
    cbechtold
    Cory
    Pleasanton, CA
    Will do :thumbsup:
    alee891[OP] likes this.
  13. Apr 3, 2017 at 4:39 PM
    #1173
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    It really depends on what you're focus is. If I were more of a crawler, I'd get some 12s and mount them looking like /\ from the back. But i want something more like LT, without going to a bed cage.
    Experience shows that you can typically only get a fairly vertical setup under the bed with a 10" shock. That assumes you're not hanging the lower mount past the bottom of the axle tube. What I want is just slightly in toward center at the top looking from behind, and just enough layback looking from the side to accommodate lateral movement of the shackle.
    I'd rather have 10" of well thought out travel than longer shocks for the sake of longer shocks.
  14. Apr 3, 2017 at 4:52 PM
    #1174
    snowboard704
    snowboard704 Well-Known Member
    Austin
    Jurupa Valley, CA
    03' 4x4 Tacoma
    Check Build thread
    Not sure how people are running fairly vertical 10”s without making the lower shock mount below the rear end. Shortbodies?
    Cause with my 10’s they still have to be like this /\, which is not what I wanted ideally. And the upper mount is 1/4 from the bottom of the bed
  15. Apr 3, 2017 at 4:58 PM
    #1175
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You have to run them below the axle. Simple as that.
    The only shortbodies that are "worth it" and barely at that are the 7100s. Barely worth it anyways as they aren't even a full 2'' diameter shock.
    snowboard704[QUOTED] likes this.
  16. Apr 3, 2017 at 5:12 PM
    #1176
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    You guys are way over thinking this shock thing.
    Carry on. :popcorn:
  17. Apr 3, 2017 at 5:18 PM
    #1177
    Squeaky Penguin
    Brett
    Report back when you can keep up without complaining about the bumpy ride. You need to take my truck for a spin this year.
    :luvya:
  18. Apr 3, 2017 at 5:19 PM
    #1178
    Blackdawg
    Monte
    Wyoming/St. Louis
    :rofl:
    snowboard704 and ebbs15 like this.
  19. Apr 3, 2017 at 5:20 PM
    #1179
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    It was the tires man, it rides like a caddy now. :luvya:
  20. Apr 3, 2017 at 5:22 PM
    #1180
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Maybe a clapped out caddy, but still pretty good....
    jubei and Squeaky Penguin like this.
