Alee891's Radiant Red Build & BS
Discussion in '1st Gen. Builds (1995-2004)' started by alee891, Feb 11, 2016.
  1. May 6, 2017 at 10:50 AM
    #1301
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    On mine what I see is two blink speeds. When I first click the button I will see a rapid blink until the locker engages. Then it starts blinking slowly. Its weird. It blinks about 99% of the time when it's engaged, once in a while I'll see it solid tho.
    The slow blink behavior started when I regeared. So its been working this way for about 4 years. I'm just grateful it still engages.
    alee891[OP] likes this.
  2. May 6, 2017 at 11:03 AM
    #1302
    TacoVio
    TacoVio Well-Known Member
    Kolton
    CO/WY
    R.I.P '04 Roy Super White ^^
    '00 Imperial Jade Flatty / '14 Spruce Mica, 6MT, Sick
    I think I have that 4wd ecu deal. its been in the wrecked truck. Hopefully its not damaged from the rain/snow...Are you a j shift tcase? Idk if that matters
  3. May 6, 2017 at 11:11 AM
    #1303
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I'm no electrician but we did also try putting power to pins 2 & 3, nothing then reversed the leads and still nothing. The brushes and commutator didn't have any burns and looked clean so I didn't think the motor was bad. But thought it would have turned when putting power to it.
  4. May 6, 2017 at 11:16 AM
    #1304
    alee891
    alee891 [OP] Destination: unknown
    Austin
    Black Hills
    Tacomaless
    J shift - no push button. Are you going to the meetup tomorrow?
  5. May 6, 2017 at 11:16 AM
    #1305
    alee891
    Austin
    Black Hills
    Tacomaless
    :annoyed:
  6. May 6, 2017 at 2:08 PM
    #1306
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    I was not planning on going, but am only 15 minutes north of Toytec if you wanted to stop by before or after to test out the black box if your numbers match what I posted.
    Call or text 303-900-8306.
    alee891[QUOTED][OP] and Reh5108 like this.
  7. May 6, 2017 at 3:22 PM
    #1307
    TacoVio
    Kolton
    CO/WY
    Unfortunately no. I'm in the middle of my shock relocation and frame plates...I was gonna try and make it but its not gonna happen lol
  8. May 7, 2017 at 8:57 PM
    #1308
    thefatkid
    thefatkid Well-Known Member
    Brian
    Colorado
    2004 thingy
    Electronics don't like getting wet
  9. May 7, 2017 at 9:01 PM
    #1309
    alee891
    Austin
    Black Hills
    Tacomaless
    New comp didn't do anything :confused:
    As @Reh5108 stated before, doesn't seem to be getting power to the rear. Suggestions?
  10. May 7, 2017 at 9:11 PM
    #1310
    thefatkid
    Brian
    Colorado
    2004 thingy
    Electrical diagnosis, I can't really offer any more then that. Start tracing (electrically) the wiring until you find the missing circuit that is causing issues.
    alee891[QUOTED][OP] likes this.
  11. May 7, 2017 at 9:47 PM
    #1311
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Pretty much. Get a volt meter out and start testing
  12. May 8, 2017 at 1:10 PM
    #1312
    Reh5108
    Idaho
    Maybe it is the motor actuator not working.
    Here's the diagram I was going off of. Adding direct power to 2 and 3 should turn the motor right?
    Edit: first time trying to use Flickr for photos heres the link
    https://www.flickr.com/gp/107514292@N04/m27w36
  13. May 8, 2017 at 1:11 PM
    #1313
    cbechtold
    cbechtold IG: @corybechtold
    Cory
    Pleasanton, CA
    2001 DCSB SR5 TRD 4x4
  14. May 8, 2017 at 1:15 PM
    #1314
    cbechtold
    Cory
    Pleasanton, CA
    Use the BBcode when you share a photo from Flickr
  15. May 8, 2017 at 1:17 PM
    #1315
    Reh5108
    Idaho
    Bbcode? :notsure:
    Where can I find that?
  16. May 8, 2017 at 1:26 PM
    #1316
    cbechtold
    Cory
    Pleasanton, CA
    In between the "edit photo" and "download photo" buttons, is the "share photo" button. Click on that and you'll have 4 option on sharing photos. Share, Embed, Email and BBcode. BBcode will have the photo in the format to post the photo correctly, as well as it'll credit the person who took the photo.
    Edit:
    Also make sure to set the size the photo so it doesn't try to take up the entirety of the screen.
  17. May 8, 2017 at 1:27 PM
    #1317
    Reh5108
    Idaho
    Thanks! Is this an option via the app? Probably why I'm not seeing it
  18. May 8, 2017 at 1:30 PM
    #1318
    cbechtold
    Cory
    Pleasanton, CA
    As far as I know, no. You'll have to use [​IMG][IMG ] url to image [/IMG ]
    Just remove the spaces in the brackets and you'll be golden
    Reh5108[QUOTED] likes this.
  19. May 8, 2017 at 1:31 PM
    #1319
    Reh5108
    Idaho
    I'll have to hop on a computer tonight not sure why my usual way of doing it isn't working. Maybe I'm using too much if my media space on here to send it through the TW live way.
  20. May 9, 2017 at 9:35 AM
    #1320
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
