Alee891's Radiant Red Build & BS
Discussion in '1st Gen. Builds (1995-2004)' started by alee891, Feb 11, 2016.
  1. May 16, 2017 at 8:34 AM
    #1341
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Or someone can just buy my swingout :spy:
  2. May 16, 2017 at 8:48 AM
    #1342
    alee891
    alee891 [OP] Destination: unknown
    Austin
    Black Hills
    Tacomaless
    Updating thread title to "First Gen Trading Post And Other Stuff With Things" :luvya:
  3. May 16, 2017 at 1:25 PM
    #1343
    cynicalrider
    cynicalrider #NFG
    Jersey
    Quoted to steer this bitch back on topic!
    How bad was it sealing the tippy top of the tub? I had my interior out when I went back to do mine and it was still a nightmare. Do you have that pocket next to the fuse panel in the door where that piece of foam once was? I was thinking about filling that with expanding foam but wasn't sure if that would hold moisture or not.
    jubei and alee891[QUOTED][OP] like this.
  4. May 16, 2017 at 1:33 PM
    #1344
    alee891
    Austin
    Black Hills
    Tacomaless
    It was still a pain in the ass.
    I seam sealed what I could by hand, then used Flex Seal and sprayed it in every nook and cranny I could find. It isn't nearly as aesthetically pleasing as @jubei777, but I'm hoping it got the job done. I also seam sealed/flex sealed a bit on the underside of the outer portion (near the cab mount) as that appeared to be my troubled area.
    jubei likes this.
  5. May 16, 2017 at 3:23 PM
    #1345
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    That area at the peak of my tub was an absolute BITCH on the passenger side. I literally just did the seam seal there last night and I was cussing a blue streak the whole time. Between fighting the blower motor and maneuvering around the antenna cable, the whole thing just sucked massive salty balls.
    As for that dead space where the foam was, I was thinking the same thing, Mike. But I want to make sure if I do that that the expanding foam is CLOSED CELL. Open cell foam would likely just let water past as well as absorb a bunch of it. That area sucks because on my tubs, I don't have a weld there to close it out and seam seal it on the inside, besides the fact that I can't get all the way down there from the inside anyway. Maybe a closed cell expandable foam is the right way to go...
    By the way, I'm going seam sealer, brush on bedliner, and then flex seal on the outside. Hopefully it all works, because grinding it all off to fix it would suuuuuuuuuuuck.
    alee891[QUOTED][OP] and Stig like this.
  6. May 16, 2017 at 3:29 PM
    #1346
    Stig
    Stig Resident smartass
    Brandon
    Ta no mo
    So all in all.. You had fun. :D
    jubei[QUOTED] likes this.
  7. May 16, 2017 at 3:35 PM
    #1347
    alee891
    Austin
    Black Hills
    Tacomaless
    I guess I never had that much trouble on the tops of my tubs, both times around. Just the bottoms.
    I also have small hands. Just used a dollop of seam sealer and crammed er in there.
    You know what they say about tiny hands...
  8. May 16, 2017 at 3:44 PM
    #1348
    jubei
    NoCo
    Stuff. Also things.
    I'm scarred for life, Brandon!
    So much lulz...
    Yeah, getting my hands past the blower motor without smearing the sealer everywhere BUT where I intended was certainly a challenge. So glad that part is over.
  9. May 16, 2017 at 7:22 PM
    #1349
    cynicalrider
    cynicalrider #NFG
    Jersey
    Yup. All I see is cut and bashed metal in that corner, no welds can get to those spots, and there is no way to seal that bottoms part. I sprayed the fuck out of it with flex seal but I feel like it needs something else. @alee891 you know this area right? Opinions?
  10. May 16, 2017 at 7:39 PM
    #1350
    alee891
    Austin
    Black Hills
    Tacomaless
    The peak of the tub or the empty space that used to have foam? I'm good at the top, the bottom was sprayed with flex seal inside and out. Nothing has filled the void, though I'm chewing on Jason's idea of expanding foam now.
  11. May 17, 2017 at 3:44 AM
    #1351
    cynicalrider
    cynicalrider #NFG
    Jersey
    The bottom. I think what I hate about that section is I know it basically leads down the rocker because smoke would come out near my back windows when we were welding so if water gets in the rocker somehow it's in the cab now. Not sure if that was a risk to begin with with a stock truck but it's more apparent now.
  12. May 17, 2017 at 5:36 AM
    #1352
    jubei
    NoCo
    Stuff. Also things.
    The expandable foam was actually Mike's idea, and I'm starting to think that's what I'm going to do. I don't like the idea of not having something down there on the inside.
    I found this on the Google machine. Expandable, waterproof, and tack-free in 45 minutes. Might be the way to go.
    http://m.homedepot.com/p/12-oz-Fill-and-Seal-Expanding-Foam-Sealant-2-Pack-217272/203459971
    alee891[QUOTED][OP] likes this.
  13. May 17, 2017 at 5:57 AM
    #1353
    alee891
    Austin
    Black Hills
    Tacomaless
    I think I'm going to do the foam to be safe - maybe over the weekend. Should be easy enough to do and not time consuming at all.
    I also plan on herculining my rocker panels sometime in the future. Not that that would prevent water from entering, but who knows.
  14. May 17, 2017 at 6:08 AM
    #1354
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Are you planning on herculining the bottom 6" or so? My paint is starting to chip pretty badly and was thinking of bedlining it.
  15. May 17, 2017 at 6:14 AM
    #1355
    jubei
    NoCo
    Stuff. Also things.
    Didn't @Star-Lord do that with Herculiner? Or was that just black paint? Probably not a bad idea with all of the rock strikes these trucks see. If you take your time masking, I think it would look really good.
    As an aside, I used herculiner for my inner fenders last night. It's messy, and you have to mix it often, but it turns out really nice.
    Reh5108 likes this.
  16. May 17, 2017 at 6:27 AM
    #1356
    alee891
    Austin
    Black Hills
    Tacomaless
    Yep, there's a few writeups on here for it that I've found. Herculiner seems to be the best product from what I've read in the past.
    Did you go through it pretty fast? Would a half gallon be enough for the rockers? That's all I'd be doing since I cut the bed sides.
  17. May 17, 2017 at 6:35 AM
    #1357
    cynicalrider
    cynicalrider #NFG
    Jersey
    Viva la foam revolution! Good find on the foam @jubei777, going to get some too!
    jubei likes this.
  18. May 17, 2017 at 6:47 AM
    #1358
    Reh5108
    Idaho
    If you want I'd be down to split material cost and do both rigs at the same time.
    alee891[OP] likes this.
  19. May 17, 2017 at 7:08 AM
    #1359
    alee891
    Austin
    Black Hills
    Tacomaless
    I'm definitely up for this. It's not high on my list, but if we have a day during an upcoming weekend to burn then let's knock it out.
  20. May 17, 2017 at 8:32 AM
    #1360
    alee891
    Austin
    Black Hills
    Tacomaless
