Alee891's Radiant Red Build & BS
Discussion in '1st Gen. Builds (1995-2004)' started by alee891, Feb 11, 2016.
  1. May 17, 2017 at 9:03 AM
    #1361
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I used industrial seam sealer inside and out. Sprayed undercoating on the outside.
    Haven't had an issue I think.
    Maybe my welds were better :luvya:
    Jk
    I honestly don't check it. I will this summer. Since frank isn't a DD the miles don't click up very high.
  2. May 17, 2017 at 9:10 AM
    #1362
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I'm in no rush either. Maybe once I get back from my trip east.
  3. May 17, 2017 at 9:17 AM
    #1363
    alee891
    alee891 [OP] Destination: unknown
    Austin
    Black Hills
    Tacomaless
    That tank isn't going to be moving by summer! :p
    I think the welds are alright, aside from the bottom portion. I'm going to foam it and hope for the best.
  4. May 17, 2017 at 9:23 AM
    #1364
    Blackdawg
    Monte
    Wyoming/St. Louis
    Honestly, I'd do RTV over foam. Foam can mold or rot.
    And indeed it wont! About to go get him actually to start working on the blower..
    Stig likes this.
  5. May 17, 2017 at 10:04 AM
    #1365
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I could see an open cell foam retaining water and molding/rotting.
    But a closed cell foam specifically engineered to provide a waterproof seal shouldn't do that at all. Especially one that is made to handle exposure to the elements, like pond/waterfall foam.
    Also, part of the problem for me is lack of access to the inside of the lowermost welds. I couldn't get seam sealer or RTV all the way down there at all.
    Stig and Blackdawg[QUOTED] like this.
  6. May 17, 2017 at 10:09 AM
    #1366
    cynicalrider
    cynicalrider #NFG
    Jersey
    I think that's why @jubei777 chose the foam he suggested, closed cell, waterproof urethane foam. Especially on an interior.
    alee891[OP] likes this.
  7. May 17, 2017 at 10:36 AM
    #1367
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ahh gotcha.
  8. May 17, 2017 at 12:04 PM
    #1368
    jubei
    NoCo
    Stuff. Also things.
    DISCLAIMER:
    BYJOSHCOOK, cbechtold and alee891[OP] like this.
  9. May 17, 2017 at 12:36 PM
    #1369
    Blackdawg
    Monte
    Wyoming/St. Louis
    Do any of us? :anonymous:
  10. May 18, 2017 at 7:14 AM
    #1370
    alee891
    Austin
    Black Hills
    Tacomaless
    Going to find out if the additional sealing holds up whether I'm ready or not...
    Stig, Deathbysnusnu and jubei like this.
  11. May 18, 2017 at 7:17 AM
    #1371
    jubei
    NoCo
    Stuff. Also things.
    :fingerscrossed::fingerscrossed:
    alee891[QUOTED][OP] likes this.
  12. May 18, 2017 at 5:11 PM
    #1372
    alee891
    Austin
    Black Hills
    Tacomaless
    Passenger side clear.
    Drivers side wet :bananadead:
    Seeping in from the tiniest little hole. I hate everything.
  13. May 18, 2017 at 5:36 PM
    #1373
    jubei
    NoCo
    Stuff. Also things.
    Well that fucking sucks.
  14. May 18, 2017 at 5:43 PM
    #1374
    alee891
    Austin
    Black Hills
    Tacomaless
    I wiped it off and unloaded the remaining can of flex seal in there in a furious attempt to solve my issues.
    TacoVio likes this.
  15. May 18, 2017 at 5:45 PM
    #1375
    jubei
    NoCo
    Stuff. Also things.
    Where was the leak?
  16. May 18, 2017 at 6:25 PM
    #1376
    alee891
    Austin
    Black Hills
    Tacomaless
    Towards the top, which was a bit dissatisfying to say the least.
    I'm somewhat thinking there is water coming from the empty space along the rocker panel as well. We'll see what tomorrow has in store.
  17. May 18, 2017 at 6:32 PM
    #1377
    Reh5108
    Idaho
    I've got the empty space in the rocker that you guys are talking about, I think. Lots of dirt likes to collect there but I don't think things leak.
  18. May 19, 2017 at 8:01 AM
    #1378
    alee891
    Austin
    Black Hills
    Tacomaless
    I mentioned it because I noticed the carpet was wet along the door trim. There still water coming from somewhere and appears to be worse than it ever was before, which doesn't make sense because I caked everything on last weekend. I'll have to wait until it dries up this weekend to look at it again. Not too stoked at the moment.
  19. May 19, 2017 at 8:08 AM
    #1379
    cynicalrider
    cynicalrider #NFG
    Jersey
    Check your rear cubby. Make your you eliminate those two plugs behind the cab as well as the potential source as well as the side windows like I saw. I thought I had tub issues but water was coming from the back to the front down the channel near the door trim.
  20. May 19, 2017 at 8:17 AM
    #1380
    alee891
    Austin
    Black Hills
    Tacomaless
    I'll definitely check it out, though I'm certain it's not coming from the rear. If it were, I'd assume the carpet towards the back would be wet.
    The pinhole leak I found last night was about midway up the weld - actually coming through the first coat of seam sealer. When looking from the outside (wheel well) I couldn't really find an impression in the seal or indication of a point source. I'm wondering if water is seeping in somewhere else, likely above, and then making it's way to a possible hole in the weld. Might just say fuck it an get a quart of hurculiner and pull a Jason.
