alighment issues w/ ICON C/O, Camburg UCA & spindles?
Discussion in 'Suspension' started by HAWAIICALIVEGAZ, May 29, 2012.
  1. Jun 25, 2012 at 1:25 PM
    SDHQ OFFROAD
    SDHQ OFFROAD Cuz Stock Sucks!
    SALES
    Gilbert AZ
    Camburg UCAs are not longer than stock... thats why they're called "stock length". They adjust the angle of the uniball slightly to compensate for the increased angles (adds a little more caster as well) but the arms are not any "longer". With zero preload your uniballs might sit at an odd looking angle at ride height but nothing that will prematurely wear any components or cause alignment issues.
  2. Jun 25, 2012 at 4:41 PM
    HAWAIICALIVEGAZ
    HAWAIICALIVEGAZ [OP] Desert Warrior
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    Dr Coilovers; Camburg UCAs; Sway bar Relocation block; Deaver J66 Leafs; ProComp extended travel rear shocks 6K HIDs & 13" antenna
    So the uniball angle is a little more outward (since the UCA sits at a downward angle when lifted) to compensate for the usual droop angle when lifting the truck with coilovers?
  3. Jun 26, 2012 at 8:09 AM
    SDHQ OFFROAD
    SALES
    Gilbert AZ
    yes, but with the 1.25" Uniball you will still hit full bump/droop before the uniball is maxed out. We have done this setup on a number of trucks without issue, any reputable alignment shop will be able to get you into spec
  4. Jun 26, 2012 at 9:14 PM
    HAWAIICALIVEGAZ
    SHANE
    LAS VEGAS NV
    2005 TRD Pre Runner
    perfect! looks like it's time to install these spindles! :D
