Alignment adjustment with TC UCAs
Discussion in 'Suspension' started by bigmooze, Sep 7, 2010.
  1. Sep 7, 2010 at 1:19 PM
    bigmooze
    bigmooze [OP] Well-Known Member
    Richard
    Belle River, ON
    2009 4x4 access cab SR5
    Bilstein 5100's all round (0" up front with stock springs), 265/75/16 Goodyear Wrangler Duratracs, K&N 63 Series Aircharger Kit, Flowmaster Super 44 Muffler, Delta Champion Toolbox, fog lights, back-up lights, Sirius satellite radio with PA15-TOY, Midland 1001z CB radio with 2' Firestik II antenna, Weathertech floor mats, AVS sill protectors, Marathon SuperHides Seatcovers (Universal Digital Camo), trimmed front mud flaps, Viair 20005 OBA, Warn W650D driving lights and W650F fog lights on N-Fab light bar, Hi-Lift X-treme jack with off road accessories, TracRac "TracONE" system
    I'm going to install my 5100's (2.5" up front, stock springs), rear TSB AAL and TC UCA's during my up-coming vacation. I'm curious as to what alters the alignment on the 2nd Gen Tacoma - not that I'd be doing it myself, I'm just curious.
    From what I've read there are alignment cams, but what else is adjusted... is there anything on the UCA?
    Thanks.
  2. Sep 11, 2010 at 6:12 PM
    bigmooze
    Richard
    Belle River, ON
    *Bump*
    I'm wondering if the alignment shop I take the truck to will have to adjust the TC control arms in any way. I'll make sure they know how before I let them, loose on it.
  3. Sep 11, 2010 at 6:15 PM
    AK27
    AK27 Well-Known Member
    the tc ucas dont need adjust, not like the light racing ucas where you can swivel the ball joint around. and the ucas are fixed in place with no adjustment as far as i can tell :)
  4. Sep 12, 2010 at 1:41 AM
    sanga700
    sanga700 Well-Known Member
    San Diego, CA
    09 Red Tacoma SR5 4x4 V6 6sp
    TRD intake Airbox,4 corners 5100 front set @ 2.5".Rear TSB,1.5" Toytec AAL,skid plate.running board, EGR in channel sun visors,Valetine one radar detector, 17x8.5 Black MB Wheels. 265/70/17 Handkook Dynapro ATM
    At 2.5" lift you don't need new UCA ( cost 500 bucks )
    at 3"0 lift yes you will need new UCA .
    make sure have print out alignment paper . Caster must be atleast 2.0 or your ride will be wander when ur on high speed.
  5. Sep 12, 2010 at 5:20 AM
    bigmooze
    Richard
    Belle River, ON
    Thanks for the replies.
    I already purchased the UCAs with the intention of installing them when I intall the 5100s. Don't want to have to rip everything apart again if I can avoid it.
    From the threads I have seen, installing TC UCAs with front Billies set at 2.5" will not harm anything, just allows the alignment to be dialled closer to perfect.
    Please, some correct me if this is wrong.
  6. Sep 12, 2010 at 6:29 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You got it. You loose caster on the alignment if you lift higher than 2", and they have to push the Camber out to be able to get it close. You should be sitting nice with the TC UCA's.
  7. Sep 12, 2010 at 6:36 AM
    bigmooze
    Richard
    Belle River, ON
    Thanks Chris, I appreciate it.
