Alignment cam ?
Discussion in 'Suspension' started by Fabulous, May 4, 2011.
  1. May 4, 2011 at 12:29 PM
    Fabulous
    Fabulous [OP] Well-Known Member
    Fabian
    Calgary, AB
    2006 Tacoma double-cab TRD Sport
    Homertaco grill, Light Racing UCA's, 2.8" front lift (5100's at 0.85 setting and Eibach springs) 2" AAL with rear 5100's, Wet Okole seat covers fr/ bk. 17 x 9 Incubus Crusher wheels w/ 4.5" backspacing. 30% tinted front windows.
    So I had my alignment done on my truck after installing my Light Racing UCA's, and it drives great...then I read on her about how a lot of places that do alignments don't tighten the cam bolts down enough, so I went to check them out...all of them were tightened to around 30-40 ft/lbs. My question is whether the cams could have moved out of where they were placed after about 40-60 kms of use on bumpy roads? I didn't check where they were right after the alignment, so I have no idea where they would have been. Truck still seems fine, and I tightened them all to the 100 ft/lbs I seen posted on here...should I be paranoid?
  2. May 4, 2011 at 12:36 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    they are 100ft pds.....
    ill check yup
    and you shoukld be fine
  3. May 4, 2011 at 2:33 PM
    Fabulous
    Fabian
    Calgary, AB
    Thanks mang :)
