Alignment is good, but tires at still scalloping?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Texasdynaryder, May 30, 2013.
  1. May 30, 2013 at 5:28 AM
    Texasdynaryder
    Texasdynaryder [OP] Well-Known Member
    Chance
    Paris, Tx
    OME Nitrocharger OME Dakars All the other small goodies
    I have aligned my front end twice and they say that everything is good to go! But my truck still wanders around and is chewing up the from tires! Would bad bushings cause this or would it still be in the caster? I'm running 285 75 16 Baja Claws on my toytech coilovers. I don't want to be buying a new set e wry few months or rotating tires every couple weeks. What are you guys thoughts ?
  2. May 30, 2013 at 5:35 AM
    Texasdynaryder
    Chance
    Paris, Tx
    Another pic
  3. May 30, 2013 at 5:43 AM
    Warputer
    Warputer Dirt Road Inspector
    Lake Murray, South Carolina
    2011 TRD Off Road
    Super Bro lift!
    What year is the truck & how many miles on the suspension?
  4. May 30, 2013 at 5:48 AM
    mightytacoman
    mightytacoman Well-Known Member
    kelby
    Moving every 3 months
    Heavily upgraded
    Magnuson supercharger, Walbro 255 fuel pump. URD supergrip pulley 2.825", urd O2 sensor calibrator, Puma On-board air, Radflo CDC ext coilovers with 14" 700# springs, extended length rear Radflo shocks with CDC, Dakar leak pack, Brute Force Fab front bumper galvanized and powder coated, DTRL mod, yellow fogs, fog anytime mod, relocated rear differential breather, synthetic fluid swap, Afe Stage II with pro-dry filter, secondary air filter removed, Airflow snorkel, 4x innovation sliders powder coated, Magnaflow headers, DT y-pipe, Aero-Turbine 2525xl exhaust dumped over axle, seat belt chime disabled, Warn 8000i winch, 2- 20" light bars, 42" curved roof light both with custom brackets. Mesh grill, Brute Force Fab rear bumper with extra reverse lights, u bolt flip kit, SS extended brake lines, hockey puck bump stop extension, AT shackle flip kit, Light Racing UCA's, 4crawler 1.5" bodylift. custom built front and mid skid plates, re-geared to 4.56s, windows tinted 25%, Sony stereo, 8" skar sub-woofer, 1000 watt mono amp, retrofit headlights with legal demon eye, Kryptek Marathon seat covers. Optima yellow top, Helo 791 rims, 315/75/r16 Mt/r ARB front air locker
    how much lift you runnin?
  5. May 30, 2013 at 5:56 AM
    Texasdynaryder
    Chance
    Paris, Tx
    I put all new suspension last year! Toytech coilovers, OME Dakar leaks, LT uca, lowers bj's, rack bushings, and hats about it. I have 198k on the odometer and its 2004 double cab. The coils are about 3/4 way cranked up
  6. May 30, 2013 at 5:57 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    What are the alignment numbers?
  7. May 30, 2013 at 5:58 AM
    cdj1
    cdj1 Well-Known Member
    Clint
    Portsmouth, VA
    97 Tacoma
    King Extended travel coilovers, 5100 Shocks, Daystar shackles,OME Leaf Springs,255/85/16, front diff drop, RAT skid plates, 4.56 gears, LSD in rear, Aussie locker in the front, Front Range Offroad twin sticks, trail gear/ Bash Fab rear bumper, elite off road front bumper and sliders, warn m8000 winch, in cab winch control
    Typically that is the sign of bad struts. But lifted and it looks like you have lr uca's not really positive. So miles on current struts and lift height is?
  8. May 30, 2013 at 6:01 AM
    Southern01Taco
    Southern01Taco Well-Known Member
    Sean
    Holden, La
    01 V6 4x4 Xtra Cab SR5
    Once a mud tire starts cupping, there is no stopping it. The best thing that you can do is rotate the tires very often but that still won't stop it. You won't know if it is fixed completely till you put another set of tires on it.
  9. May 30, 2013 at 6:05 AM
    Warputer
    2011 TRD Off Road
    Super Bro lift!
    I have the same issue with my tires....and my wear is even more noticeable. Been doing alot of reading on this and I've gone thru my suspension top to bottom with no issues "visibly" found.
    I believe that my issue is the springs. When I added the heavy bumper to the front, the wear issues began. I've seen on some tire wear charts that a saggy (overloaded?) spring can cause this. My tires are currently out of balance again which I'm sure dosen't help the situation. I've had 3 alignments in less than a year & each time it's dead on.
  10. May 30, 2013 at 6:05 AM
    Texasdynaryder
    Chance
    Paris, Tx
    I'm saying somewhere in the 12-15k mile range.
    I don't have them off hand but every thing looked in spec with numbers I got off here!
  11. May 30, 2013 at 6:07 AM
    Warputer
    2011 TRD Off Road
    Super Bro lift!
    ^^Yes...I've been told this also by many guys in the tire/alignment business that I trust.
  12. May 30, 2013 at 6:08 AM
    JDMcQ
    Were the numbers you got for a stock or lifted truck?
    How are your wheel bearing? Tire balance?
  13. May 30, 2013 at 6:08 AM
    Texasdynaryder
    Chance
    Paris, Tx
    I have and alluminum front bumper from relentless fabrication so I don't have a lot of weight hanging up front .
  14. May 30, 2013 at 6:09 AM
    Texasdynaryder
    Chance
    Paris, Tx
    One brand new on the driver side and the passenger in stock but no issues! I guess I should try another balance job!
    Sorry the numbers where on it ad it sits now- lifted
  15. May 30, 2013 at 6:57 AM
    Mad Man Marty
    Mad Man Marty Well-Known Member
    Marty
    PA
    2007 Tacoma SR5 TRD Sport
    6speed, TRD intake, bed tie downs, weathertech rear,Tint
    More info would be helpful...what have u checked??
    Chalk tire pressure test.
    Suspension parts.
    All Bushings.
    Wheel bearings.
    Etc.
    Keep checking, from easy & cheap on up.
    Let us know what u do & how it works out.
  16. May 30, 2013 at 6:59 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    it's the tire itself
    Michelin is the very top of the industry in building a balanced tire and carcass for consistent road use
    Mickey Thompson Baja Claw is nowhere near that. That is an offroad tire, no
    one really expects them to have perfect wear for pavement duty
    what is chewing up the tires, is putting the truck on paved roads
  17. May 30, 2013 at 7:08 AM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    Toyo AT2's, TRD rock rails, pro clip GPS mount, Husky floor liners
    ^^^^^^ and it could be under inflated. Do the chalk test until you get the tire running flat.
  18. May 30, 2013 at 7:11 AM
    Texasdynaryder
    Chance
    Paris, Tx
    Shoot man everything, I have replaced almost the whole front end that moves. So the whole front end is relatively new. I'm going to get them balanced again as soon as I can get to San Antonio. I was just trying to figure out what I was missing.
  19. May 30, 2013 at 7:14 AM
    TACO TX
    Kelly
    Denison ,Texas
    2013 FJ cruiser 4x4
    What tire pressure are you running?
  20. May 30, 2013 at 7:17 AM
    Texasdynaryder
    Chance
    Paris, Tx
    So your saying I should sell my tires and run some Michelin road tire. Well evidently you have never been to South Texas. I run lease roads and dirt pipeline right of ways 85 percent of the time. So again tell me how I can possible run off road all day. And I was trying to figure out what is chewing them up so fast. Yes it's my first set of them and I usually run a Toyo with similar problems.
