Alignment issues??
Discussion in 'Suspension' started by jab08, Nov 9, 2009.
  1. Nov 9, 2009 at 1:52 PM
    jab08
    jab08 [OP] Well-Known Member
    Alabama
    02 T4R 4wd
    I have had my truck "lined up" (thats what I call it) twice. It drives straight as an arrow. But Iv noticed that my fornt tires are wearing on the outsides for some reason. I do have balance issues can not get them balanced have had them balanced like 6 times with no luck. The tires are yokahama Geolanders. Im getting in the next week some factory 16in rims with factory donlaps that come off a 09 tacoma with 1,800 miles on them. Just was wondering if I need to spend the money to get the truck "lined up" or sould I save the money? Or is the wear coming from the balance issues and not the alignment?
  2. Nov 9, 2009 at 1:57 PM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    post your alignment #'s and how much lift are you running?
  3. Nov 9, 2009 at 2:03 PM
    jab08
    Alabama
    02 T4R 4wd
    Dont know the #'s, but I have stock suspension w/no lift. Factory 265/75/15's if that helps out.
  4. Nov 9, 2009 at 2:03 PM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    I just got mine done I have the 5100's at 1.75 and an AAL.
    Left front
    Camber .2
    caster 1.8
    toe .02
    right front
    Camber .5
    Caster 1.8
    toe .06
    Total toe .08
    steer ahead -0.02
  5. Nov 9, 2009 at 2:06 PM
    jab08
    Alabama
    02 T4R 4wd
    Its weird Iv seen wearing on the inside of the tires but never have realy seen wear on the outside of both front tires.
    Im talking about other tires not the ones I have! Mine are wearing on the outside of both front tires.
  6. Nov 9, 2009 at 2:25 PM
    FuTang909Inamo
    FuTang909Inamo Well-Known Member
    Socal IE
    03 TRD PreRunner
    Deckplate mod, Trueflow drop in filter, clear corners, 31 BFG A/T on 15x8 Mb Razors.
    Everything checked out ok in your front end? Ball joints, tie-rods, rack and pinion bushings, suspension? If it's outside wear it's either toed-in or too much positive camber. But most likely it's toe. Post your numbers if you can. If it was done right you shouldn't have to align again if you change your wheels out.
  7. Nov 9, 2009 at 3:56 PM
    jab08
    Alabama
    02 T4R 4wd
    Ok Ill look everything over good sometime or another. The first time I had it done I done it at school, then I had the yokahamas put on and I had it re-aligned at the tire shop (thats what they recommended). But I cant remember what the #'s were its been about a year since the last time I had it aligned. It might be due to re-check IDK. How often sould you have to re-align a truck? Thanks for the help.:)
  8. Nov 11, 2009 at 10:23 PM
    FuTang909Inamo
    Socal IE
    03 TRD PreRunner
    It's always a good idea to get an alignment when you put on new tires. You may not even need it but at least have it checked. But other times would be like in your case, unusual tread wear, a pull from one side or the other, if you were in an accident or hit a curb or something, replaced a front-end component ie. tie-rods, and also of course when you lift your truck. Some shops may say like get an alignment once a year for maintenance, i say that's BS. I actually overheard that from a Sears Auto manager.
  9. Nov 11, 2009 at 10:29 PM
    Dellosa89
    Dellosa89 Love peace and Taco Grease
    Brian
    Murrieta CA
    07 Prerunner TRD Off Road
    Fox 2.5 Coilovers, Camburg 1.25" UCA's, Icon RR, Icon aal,EVS foam bump stops, Borla Catback, HID Headlights and fogs, Defiant light bar, 3 hella 700 hid, Satellite Radio, Sony hu with 10'' sub, custom jetski rack, TRD seat covers, secondary air filter removed.
    Just wondering whats ur tire pressure, my friend was running his at 20 psi and within 4 months the outsides of the tires were showing a lot of wear.
  10. Nov 12, 2009 at 6:14 AM
    jab08
    Alabama
    02 T4R 4wd
    I was runnung 32psi but not any more I got my new tires!!!! Ill see how it works out for now.
  11. Nov 12, 2009 at 7:10 PM
    Bellpepper
    Bellpepper New Member
    San Antonio, Texas
    The Roaming Tacoma
    Lift, Bumper, with more to come!
    You might want to check your shock, because bad shocks can cause tire wear.
  12. Nov 12, 2009 at 7:11 PM
    jab08
    Alabama
    02 T4R 4wd
    Thanks Ill check that out. And WELCOME TO TW!!!!!!!!!:D
