alignment needed after removing 1/2" spacer??
Discussion in 'Suspension' started by especk, Feb 28, 2011.
  1. Feb 28, 2011 at 11:44 AM
    especk
    especk [OP] Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    So I'll be removing my 1/2" top plate spacer to bring my CV joints into better position. Right now I'm at about 3.5" of lift and this will bring me down to almost 3".
    Do I need to get a new alignment after doing this? or is it not a big enough change to make a difference in my alignment?
    Thanks!
  2. Feb 28, 2011 at 11:47 AM
    JLee
    JLee The Man! Vendor
    Jerry
    Bay Area NorCal
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yes!
  3. Feb 28, 2011 at 11:52 AM
    especk
    Erik
    Redding, CA
    just saw it on my build page too. Thanks.
  4. Feb 28, 2011 at 11:56 AM
    JLee
    Jerry
    Bay Area NorCal
    Yeah any time you remove your front shocks you will need an alignment
  5. Feb 28, 2011 at 11:58 AM
    especk
    Erik
    Redding, CA
    O so even if you dont replace them or anything?
    Or do you only need an alignment after anytime you change the height?
  6. Feb 28, 2011 at 12:01 PM
    JLee
    Jerry
    Bay Area NorCal
    Yeah if you remove them and reinstall everything your not going to get it all back to spec it will me miner but you should still do it.
