Alignment problems, expert advice requested.
Discussion in 'Suspension' started by hudhawk, Jan 31, 2012.
  1. Jan 31, 2012 at 6:06 PM
    hudhawk
    hudhawk [OP] #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    So I think I've finally figured out my alignment woes. Tell me if you guys have any better ideas.
    My truck has 139k miles on it. I have stock upper and lowers, Camburg spindles, and bilstein 5100@0.85 with stock coils.
    For about two months now my passengers side wheel has had -1.4 degrees of camber. I walked out to the truck one day and noticed it. I went and had it aligned twice and both places said they couldn't align it because the alignment tabs were maxed out. So I had them align it as best they could so it would still drive somewhat straight. I know these trucks have alignment issues when lifted 3" with stock uppers, but I'm below that, and these trucks have problems with positive camber when lifted, not negative.
    Before you say anything, yes I know its really bad to drive it like that, but there was nothing I could do about it at the time. I discussed it with my dad and we both decided that, with money being as tight as it is with me going to school and my truck not seeing a whole lot of road time while I'm here, that we would hold off buying anything or taking it to a shop until we figured out exactly what was wrong.
    So over the past few months I've been going over everything I could think of that would cause this problem. I checked the wheel bearings, nothing. I've crawled under every inch of the truck looking for signs of bends or cracks, especially in the front of the frame, and inspected control arms for bends, nothing. I've asked and gotten all my mechanically inclined friends to look over and tell me what they thought, nothing.
    So today while I was surfing the wonderful world of TW, I came across a thread about how the lower control arm bushings are made of a sleeved piece of rubber and that over time they can wear out and deteriorate causing the control arms to move laterally on there mounts causing alignments to not hold and make loud metal clunking noises in the front suspension. I started thinking, my truck started making loud clunking noises in the front suspension shortly after I bought it and it has never held an alignment very well in all the time I've owned it. Could this be my problem?
    So today I climbed under the truck and visually inspected all 4 bushings, every one looked dry rotted and cracked. I then layed under the truck and watched the control arm mounts while a friend turned the steering wheel. I was not surprised at all when I witnessed both control arms moving laterally in the mounts.
    So my question is, do y'all think it's worth it to buy new bushings and install them in the lower arms? Does this sound like I've figured out the problem?
    I know I can't actually know until I do it, but I at least want to know that I'm on the right track.
    I'm not asking to be burned at the stake for driving my truck out of alignment, I'm asking for advice from those more experienced than I.
    Thanks,
    Hudson
  2. Jan 31, 2012 at 6:09 PM
    Ohbrian
    Ohbrian Taco Roja
    Brian
    Fremont, CA
    04 PreRunner
    Eclipse head unit,scratched paint,ripped seat, black chaos 6 rims, Bilstein 5100's, top plate spacers, AAL, Midget antenna, Bakflip G2 cover, 14" Magnaflow, 400W inverter, LR UCA's
    Either bushings or maybe something got bent. I would start with bushings, cheap fix and you are probably due anyway.
  3. Jan 31, 2012 at 6:11 PM
    4wd Boss
    4wd Boss Shake and Bake
    Jefferson
    Big D
    16 Quiksand TRD Offroad
    Fog Light Mod, Pro Grille, raptor lights, 1.25 spacers, RC coilovers
    totally plausible that a truck with 139K would need new bushings. most likely the cause if nothing else looks out of place.
  4. Jan 31, 2012 at 10:08 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Ttt, anyone else?
  5. Jan 31, 2012 at 10:31 PM
    Zimaura
    Zimaura Well-Known Member
    Nj
    San jose, CA
    05 4x4 Double Cab. level Kit, 33 inch BFGs
    Level Kit, 16inch Moto Metals, 33 BFGs, Flowmaster, tinted taillights, silver billet grills
    My truck loses alignment pretty fast too, but i have only about 50k on mine.
    What kind of clunking noise are you talking about, and when do you hear it? Do you hear it when turning?
  6. Jan 31, 2012 at 10:34 PM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Yes, when turning. Sounds like its coming from right under my feet, like where the LCA is
  7. Feb 1, 2012 at 7:56 AM
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    I found the bushings online for $160 for the set of 4. Sounds like a pretty good deal to me, but I'll keep checking things out.
  8. Mar 27, 2014 at 9:53 AM
    SpaceBalls
    SpaceBalls Active Member
    Vancouver Canada
    08 Taco trd
    3" block lift 33" BFG's AT
    I'm having similar problems, my bushings look all cracked and crappy too. 100km's on mine. I ride my truck hard. So... I'm getting a wheel alignment right now and they are looking into the knocking noise.
  9. Mar 27, 2014 at 10:04 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
  10. Mar 28, 2014 at 9:12 AM
    SpaceBalls
    Vancouver Canada
    08 Taco trd
    Nice that helped! Turns out my noise is coming from the leaf springs! Says some random mechanic.. I'm not fully convinced. I guess the point is it can be really hard to tell where funny sounds are coming from. Hope you get your truck fixed!!
