alignment questions...
Discussion in '1st Gen. Tacomas (1995-2004)' started by tsab916, May 2, 2011.
  1. May 2, 2011 at 9:29 PM
    tsab916
    tsab916 [OP] Well-Known Member
    Sacramento
    02 DC 4x4
    I just installed my toytec ULK...and now the front tires have a small amount but noticable positive camber, I know if I adjust them down it will fix it but my question is that can you adjust the camber without aftermarket UCA's?
  2. May 2, 2011 at 9:31 PM
    BFA
    BFA Nuttier than squirrel shit.
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    You can adjust the camber without aftermarket ucas but that is your castor that's off I believe
  3. May 2, 2011 at 10:15 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnuson MP62 Supercharger w/URD 2.2" Pulley Haltech Elite 2000 Standalone ECU Denso 650cc Fuel Injectors Doug Thorley Headers Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Get an alignment asap. Shouldn't have any difficulty setting toe and camber to spec. It'll be the caster that'll be somewhat low. Are the CO cranked up to a full 3" of lift? Lowering it down some will improve you chances of getting better caster numbers.
  4. May 2, 2011 at 11:34 PM
    tsab916
    Sacramento
    02 DC 4x4
    I think they are cranked up to 3in...whatever they set it at toytec...I never adjusted anything...the fronts are a little higher then the rears...I was hoping they would settled down a bit after driving it for a week...its only been 2 days...will they settle down a bit? Or should I just adjust them so their even with the rears?
  5. May 3, 2011 at 5:44 AM
    R.etheridge
    R.etheridge Well-Known Member
    Middle GA
    03 Tacoma TRD 4x4
    the front will not settle as much as the back will so you will always have a rake. Take it and get a alignment. I have a true 3in lift on my taco and it took them about an hour to get the caster in alone but they proved that it can be done with a full 3in lift. or you can adjust the front down a little so they can get you caster in and that would reduce your rake issue as well. GL
  6. May 3, 2011 at 5:48 AM
    BFA
    Brian
    Phoenix, AZ
    2003 3.4 4x4 5spd
    i had them and they settled to 3" and made my truck level with a 2" AAL in rear
  7. May 3, 2011 at 9:09 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Which coil is used on those? Is that an Eibach 620 lbs coil? If so, they wont settle much unless you add additional weight to the front, like a plate bumper, winch, aftermarket skids, etc.
    What size tire are you trying to clear?
  8. May 3, 2011 at 10:11 AM
    tsab916
    Sacramento
    02 DC 4x4
    I got the heaviest coil that toytec offers..so I guess they wont settle much...i'll just adjust them down to match the rears...not necessarily trying to clear a certain tire, I have bfg AT 265/75R16 (same as 32's right?) And they use to rub when I make u turns but now after the lift no more rubbing.
  9. May 3, 2011 at 11:50 AM
    mikracer
    mikracer Well-Known Member
    San Luis Obispo, CA
    2009 DCSB | TRD Sport 4x4
    Get an alignment and tell them its new suspension. Most places will allow you to bring it back and get it tweaked a little after the suspension settles.
  10. May 4, 2011 at 12:17 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    You will have to work with the alignment shop to get the numbers as close as possible. I could not get mine to meet the factory alignment numbers, aligned it several times. Without the aftermarker UCAs you can't get there. But I have about 20,000 on my Toytec lift to 2.5 and it works for me.
    Here is my post on the alignment problems I had, note what happened after Chris 4X4 weighed in, I had to work on the alignment several times http://www.tacomaworld.com/forum/suspension/64882-o4-tacoma-lift-result.html
    You can get it close enough if you are patient and get the alignment tech to work with you
  11. May 4, 2011 at 1:04 PM
    gonewheeln
    gonewheeln Member
    Hell I wish I could get my caster over 0.......the aligment shop I went to can't seem to get anything more than 0. I got bette numbers when the lift was first put on 2 years ago.....time to find another shop I guess.
  12. May 4, 2011 at 1:19 PM
    BRP27
    04 4X4 Tacoma SR5
    The trick is to sacrifice camber for caster
  13. May 4, 2011 at 1:26 PM
    gonewheeln
    gonewheeln Member
    good point.......I'm no expert on IFS alignments so I don't know much when I go in a discuss it with them...all I see is numbers. They claim neg. caster won't wear tires but I dunno if I believe them
  14. May 4, 2011 at 6:53 PM
    BRP27
    04 4X4 Tacoma SR5
    With stock UCAs and a toytec set at 2.5in these are my alignment numbers
    camber -0.2 0.0
    caster 1.2 1.6
    toe 0.07 0.05
    These are not the factory spec but they work for me no abnormal tire wear and it drives good.
  15. May 4, 2011 at 6:58 PM
    McBride513
    McBride513 Well-Known Member
    Luke
    Cincinnati
    04 4x4 TRD
    Caster has no effect on tire wear. Only toe and camber do.
