Alignment shop issues this morning....
Discussion in 'Suspension' started by Sandfire, Oct 26, 2009.
  1. Oct 26, 2009 at 7:56 AM
    Sandfire
    Sandfire [OP] Well-Known Member
    southwest midwest
    06 TRD Sport DC 4x4 silver
    OME 885 springs with OME N140s shocks, Total Chaos UCA's, TSB AAL, OME N182's, MT BAHA ATZ 4ribs.
    I have searched and read several threads on here but was unable to find answers directly related to the issues I'm having this morning.
    I just got my OME lift and TC UCAs installed last week and this morning had the truck scheduled for alignment (keep in mind here that I am mechanically inclined enough to have installed my own lift but know very little about alignment.) The guy at the shop seemed very unsure about how to align a moderately lifted truck. He informed me he had no idea where to start since he usually just plugs in the year and model and that gives him specs. I told him I could probably get specs (from my friends at TW:)) but there might be some variables, slightly different lift heights, 2wd vs 4x4, etc. He said if it varies more than a 1/4" the numbers would be different.
    He then found out I am planning to put spacers on the front and said that would change things as well.
    I ended up leaving without the alignment done with the task of finding him specs and waiting until my spacers arrive.
    Are issues like this normal or is he making it harder than it should be? Also, if someone could provide me specs that match my application I would appreciate it. Thanks in advance.
  2. Oct 26, 2009 at 8:01 AM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    if its done right, with new ucas and such, you should just use the factory specs
  3. Oct 26, 2009 at 8:06 AM
    Sandfire
    southwest midwest
    Huh....I was under the impression the specs changed with the aftermarket struts/3"lift?, and yes I did use TC UCAs.
  4. Oct 26, 2009 at 8:07 AM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    i beleve
    camber 0
    toe 0
    caster 2.8
  5. Oct 26, 2009 at 8:09 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    This is correct ^^^
  6. Oct 26, 2009 at 8:10 AM
    Sandfire
    southwest midwest
    Thanks for the specs, should I wait for the spacers or is it not that big a deal?
  7. Oct 26, 2009 at 8:11 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Spacers shouldnt affect the alignment.
  8. Oct 26, 2009 at 8:14 AM
    Sandfire
    southwest midwest
    Thanks Chris! The guy at the shop was under the impression it would affect caster for some reason.
  9. Oct 26, 2009 at 8:15 AM
    aww1970
    aww1970 Well-Known Member
    2009 Tacoma TRD Long Box
    Would these be the specs for a mild lift as well- 1.5"-1.75" in the front with rear 1.5" AAL?
  10. Oct 26, 2009 at 8:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Strange....The spacers simply move the wheel out a little further....Kinda like putting on new wheels with a different back spacing....Wont affect the Caster at all.
  11. Oct 26, 2009 at 8:16 AM
    David Tarantino
    N.J.
    08 tacoma
    How ?
  12. Oct 26, 2009 at 8:17 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO!!!! Ditto! :)
  13. Oct 26, 2009 at 8:20 AM
    Sandfire
    southwest midwest
    That's what I thought to but wasn't armed with enough info to disagree with him this morning.:)
    I have no clue...just relaying what he said so the experts here could muse over it.
  14. Oct 26, 2009 at 8:21 AM
    David Tarantino
    N.J.
    08 tacoma
    go some place else and have them set it the the spic above
    youll be fine :D
  15. Oct 26, 2009 at 8:24 AM
    Sandfire
    southwest midwest
    Yeah might have to, now I'm kinda worried they don't know what there doing!
    Oh, and he also tried to talk me out of spacers, said they would be harmful to my wheel bearings.....I did call BS on that one and told him I knew of hundreds of people running them without adverse issues.
  16. Oct 26, 2009 at 8:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    They can cause wear on the wheel bearings to be escalated. They increse the leverage against them.
  17. Oct 26, 2009 at 9:03 AM
    Sandfire
    southwest midwest
    It doesn't surprise me that wear is escalated but the concept would be the same as an aftermarket wheel with more backspacing if I am thinking correctly.
    Although in another thread I said I had no rubbing, turns out the tires are now rubbing (messing up my pretty new UCAs:mad:) at a full lock. Thats why I decided to do spacers.
  18. Oct 26, 2009 at 9:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah, its the same as adding a wheel with 4" BS.
  19. Oct 26, 2009 at 9:13 AM
    Sandfire
    southwest midwest
    I could see that but I hope not....he's the same guy that assembled my new OME springs and shocks.:)
  20. Oct 30, 2009 at 8:16 AM
    testedone
    testedone Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    Hey did you get this resolved?
