alignment tech/ help thread
Discussion in 'Suspension' started by livel0veryde, Feb 1, 2012.
  1. Feb 4, 2013 at 7:21 PM
    #301
    Gabassman
    Gabassman Drive it like a 4WD
    Tyler
    Georgia
    got my Alignment done today got a full 3 inches with 885s anf 5100's 05 pre runner
    right side
    caster +1.00
    Camber +.55
    Toe 0.00
    Left Side
    Caster +1.55
    Camber +0.85
    Toe 0.00
    Do these look good, alignment confuses the shit out of me. From My reading I assume I want higher caster and lower camber. But is this the best i can get with Stock UCA'S?
    After reviewing the alignment sheet I had to beg for them to print me a copy, they had the machine set for the 5 lug trucks. All my max min ranges are way off what i am seeing for the 2nd gen 6 lugs.
  2. Feb 5, 2013 at 12:29 PM
    #302
    Gabassman
    Tyler
    Georgia
    Took it in again. Numbers are more f'ed up then the ones I posted had them do it again with no luck. So LR UCA's will be ordered with tax refund.
  3. Feb 12, 2013 at 9:44 PM
    #303
    Tricky
    Tricky Well-Known Member
    Palmetto, Fl
    09 TRD Sport DC
    Anytime Fog Lights Bakflip HD Billstein 5100's Blacked Out Scoop Debadged FJ62 TOYOTA Smile Grillcraft Upper & Lower K&N Intake Magnaflow Cat-Back OEM Roof Rack Pioneer Speaker Upgrade Redline Hood Struts Slimcubby's HIDs Toytec 1.5 AAL
    Had an "alignment" yesterday and was told that the cam adjustment colts are seized in both diver and passenger side. The tech told me he saw the same thing with a a similar year taco , mine is 09 with 70k miles, last week and seems to be a common problem. Any advice? Torch? PB Blaster? BFH with cheater bar? Feel free to link any threads. Im currently via iPhone and the search thread function is useless.
    Seemingly unrelated but I'm maxed out with 5100s running stock uca so I know alignment can be difficult but I'm trying to figure out if this guy is full if it or not. Thanks.
  4. Feb 12, 2013 at 9:45 PM
    #304
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Pretty common issue , let me see if I can find you a thread
  5. Feb 12, 2013 at 9:47 PM
    #305
    OZ-T
    Peter North
    British Columbia
  6. Feb 12, 2013 at 9:54 PM
    #306
    Tricky
    Palmetto, Fl
    09 TRD Sport DC
    Thanks man. Guess I got my weekend planned.
  7. Feb 12, 2013 at 9:57 PM
    #307
    OZ-T
    Peter North
    British Columbia
    You may be able to free them up with Deep Creep or PB Blaster or similar , but quite often the cam bolt is seized to the inner metal sleeve in the bushing
  8. Feb 12, 2013 at 9:59 PM
    #308
    Tricky
    Palmetto, Fl
    09 TRD Sport DC
    Certainally will try it first. But I'm expecting it to be FUBAR as the alignment tech told me he worked in it for about an hour. My only hope is that after seeing the size if his gut, his definition of worked might be a but different than mine.
  9. Feb 12, 2013 at 10:00 PM
    #309
    OZ-T
    Peter North
    British Columbia
    Haha , good luck
  10. Feb 15, 2013 at 12:16 AM
    #310
    EDJY
    EDJY Well-Known Member
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    has anyone noticed their truck comes out of alignment really easily?
    I bumped a rock with my wheel and LCA going like 3 mph and came to an abrupt stop. i ended up driving down the road with my wheel at an angle for a few weeks until i had the alignment done. Now I smacked a pothole when I was not paying attention to the road and it pulls to the opposite side! Admittedly it was one mother of a pothole, but this seems ridiculous. My 01 never had bad alignment and it took a thrashing.
  11. Feb 15, 2013 at 8:16 AM
    #311
    OZ-T
    Peter North
    British Columbia
    Perhaps your LCA cam bolts were not torqued sufficiently or the cam bolt could be seized inside the bushing sleeze and is actually twisting with the LCA
    Have you checked your alignment tabs for signs of damage / rubbing ?
  12. Feb 15, 2013 at 3:09 PM
    #312
    EDJY
    Elliott
    Bay Area, CA
    2016 DCSB TRD OR MT
    I tightened all the LCA bolts. They were tight. I also inspected everything. one alignment cam seemed to be pushed slightly to one side on the impact side. My truck has about 145k but its about 80% highway in California. Absolutely zero rust, all bolts were in very good shape and not seized. I recently put 5100's all the way around and was very impressed with the status of my undercarriage.
  13. Feb 15, 2013 at 6:05 PM
    #313
    OZ-T
    Peter North
    British Columbia
    100ftlbs torque for the LCA bolts I believe , and your bolts may be seized in the inner sleeve of the bushing
  14. Feb 16, 2013 at 9:06 PM
    #314
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    So i guess my Caster is on the low side. Would this cause harder steering, also it wouldnt be maxed at this would it?
  15. Apr 10, 2013 at 1:26 PM
    #315
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    This link provides good understanding for alignment terminology (it has pictures)
    http://www.autek.dk/Articles/PrincipOfSteeringGeo_eng.pdf
    Stock specs for 2nd Gen are min to max range
    values are in degrees
    Front
    Caster 1.3 to 2.8
    (never want negative #, bad steering control; steering will wander with every little bump, too much caster hard to steer wheels always want to go back to center.)
    Camber -0.3 to 1.3
    Toe 0.0 to 0.10 (0.0 toe out to 0.10 degrees Toe in)
  16. Apr 10, 2013 at 1:30 PM
    #316
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    More caster makes the wheel want to return to center (harder steering feel) and drive straight, less caster makes steering easier and return to center on its own less. But you are really close to acceptable range. If you have bent something you may be out of adjustibility on the caster because it also affecets camber. Which is why its both very close to limits on the right side
  17. Apr 10, 2013 at 1:31 PM
    #317
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    installed Camburg UCA, took in for alignment.
    Yes Camburg BJ UCA does help provide caster
    Have OME 885 w/nitrocharger shocks + 1/4" spacer for lift.
    stock LCA
    Result(degrees) =
    Left Caster 1.9 (was 2.6)
    Right Caster 1.8 (was 1.2)
    Left Camber 0.7 (was 1.0)
    Right Camber 0.7 (was 0.7)
    Left Toe 0.05 (was -0.25)
    Right Toe 0.05 (was -0.45)
  18. Apr 10, 2013 at 4:05 PM
    #318
    Double Down
    Double Down Well-Known Member
    Colorado Springs, CO
    '23 ACLB TRD OR
    Magnuson, King, OVRLND, Deaver, Method, BFG
    I posted this in a new thread, but I thought I'd post here as well.
    Hey Guys
    So I just installed a set of FOX 2.5 Factory Series Coil-overs with Remote Reservoirs and set of Total Chaos UCA's on my 12 Access Cab TRD OR. I have BFG TA's 265/75 16's mounted on Method Double Standard's with 0mm offset and 4.5" backspace.
    After having the truck aligned, the truck has very sluggish steering. It drives straight in the road, doesn't wander, but it is very hard to initiate tuns.
    In looking at my alignment numbers, it looks like my caster is quite high: 4.2 but it was they best they said they could do. Is this what is causing my steering issue?
    Should I just take the truck back to the alignment shop and tell them to aim for caster in the 2.7 to 3.0 range?
    Thanks for the help!
  19. Apr 10, 2013 at 4:29 PM
    #319
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    If your preload on the coil overs is set to stock height, then that might explain the high Caster #. The TC UCA are there to compensate for lift, and provide more caster, but if there is no lift above stock, then you'll have too much caster. Maybe??
  20. Apr 11, 2013 at 5:35 AM
    #320
    Double Down
    '23 ACLB TRD OR
    I forgot to add that Fox pre-set the coilovers to level the truck, so 2" lift.
