alignment
Discussion in 'Suspension' started by toymachine, May 26, 2009.
  1. May 26, 2009 at 2:32 PM
    toymachine
    toymachine [OP] .
    i went to discount tire today to get my alignment done and he said he couldnt do it. i have the ome shocks with 885 set up with LR ucas and he said i need LOwer control arms now ? couldnt get the specs close enough or something. i dontknow what to do. or u think he doesnt know anything and i should try somewhere else? anybody know a good place?
  2. May 26, 2009 at 3:15 PM
    cyantucaz
    cyantucaz Member
    Vail, AZ
    07 4x4 Quad Cab
    5100'S ALL AROUND WITH 885 COILS AND LIGHT RACING UCA UP FRONT. 1.5 AAL IN THE BACK. SPIDERTRAX SPACERS. IPOD ADAPTOR. SEXY WIFE IN THE PASSENGER SEAT!!
    My set up is the same except for the shocks. The plan was to take it in today for the first time to get the alignment done as well, but never made it. I am having a company that works on my tractor/trailors. I will keep you posted as to what my guy says.
  3. May 26, 2009 at 3:21 PM
    SocalMan22
    SocalMan22 Well-Known Member
    Steve-0
    So*Cal
    06 PreRunner Dbl Cab
    What Mods!
    I had the same thing happen they dont specialize in aftermarket suspension and they got mine as close as they could, some will even void it because you have you altered the suspension only if you have the lifetime allignment, but as for the lower control arms thats news to me makes me laugh.
  4. May 26, 2009 at 3:46 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    the caster was a little off when I got mine aligned, but they were able to get everything else in spec. Thats with 3" spacer lift and with stock UCAs too. Yours should be better than mine with the aftermarket UCAs. I'm going to the OME setup with the 885's when I have the money to buy a set of N140's and can do it in one swoop.
  5. May 26, 2009 at 3:55 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    You'd probably have better luck takeing it to a shop that see's more aftermarket suspension.
  6. May 26, 2009 at 3:59 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    ive got the lruca and got mine done at NTB.luckily the dude that did mine had (until the divorce) a lifted taco and knew what to do.turned out great.ide say go some where else and u dont need lca either.good luck.
  7. May 26, 2009 at 4:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Your Lower control arms are fine. The guy at the shop is a doooosh.
  8. May 26, 2009 at 7:26 PM
    toymachine
    toymachine [OP] .
    hahaha alrite. just gotta find another place. thanks for ur guys help
