Alignment
Discussion in 'Suspension' started by SMG26, Sep 24, 2009.
  1. Sep 24, 2009 at 5:37 PM
    SMG26
    SMG26 [OP] Well-Known Member
    Woodstock,GA
    06 Prerunner TRD Offroad
    Injen CAI, JBA exhaust pipes 2.5" w/magnaflow muffler, Doug Thorley Long tube headers, URD MAF CAL and O2 sim,Access roll up cover, AVS Wind deflectors, coverking seatcovers, grillcraft upper/lower grille, Halo projectors w/6000k HID and pop lock on tailgate.
    I am having some uneven tire wear on the two front tires. I put a 3" lift on the truck about 3 months ago and took it to my local toyota dealer to have them align the wheels. The tread on both front tires are wearing more on the outer part of the tires. The left tire seems to be wearing a little more than the right side but both are wearing on the outer part of the tire. Also I noticed that the steering wheel when driving straight it has too be a little to the right for it to go straight and when I let go of it pulls a little to the left. When I am looking at the truck head on it looks like the wheels are pointed inward. Does anyone have any alignment specs that work for a prerunner with 3" lift,spidertrax spacers and stock trd off road wheels. Any help would be great.
  2. Sep 24, 2009 at 6:01 PM
    SMG26
    Woodstock,GA
    Bump Anyone
  3. Sep 24, 2009 at 6:05 PM
    98tacoma27
    Ben
    Not Beech Creek
    Shoot a PM to Chris4x4
  4. Sep 24, 2009 at 6:10 PM
    David Tarantino
    David Tarantino Well-Known Member
    N.J.
    08 tacoma
    i believe its 0 toe o camber 2.5 on caster
  5. Sep 24, 2009 at 6:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Sounds like the alignment is off...
    Take it back, and tell them to make it right. Alignment shoutl be set to:
    0* Camber
    0* Toe
    2.5* (or so) Caster.
    If you dont have an after market UCA that corrects for lost caster after lifting, you may want to consider getting a set.
  6. Sep 24, 2009 at 6:22 PM
    SMG26
    Woodstock,GA
    Thanks Chris
  7. Sep 24, 2009 at 6:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  8. Sep 25, 2009 at 10:54 AM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2021 Jeep Rubicon
    I don't know what these forums would do without u chris. Thanks for all the help u provide!
  9. Sep 25, 2009 at 12:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thank you, for the kind words, Manny!
