ALL black 1st gen Tacomas
Discussion in '1st Gen. Tacomas (1995-2004)' started by Critta93, Jun 9, 2012.
  1. Jan 23, 2017 at 9:16 PM
    #241
    carofchoice
    carofchoice Well-Known Member
    Jeff
    Newton, IL
    2003 DC 4X4 TRD, 2012 X-Runner
    When they had a group buy on them a while back I asked the question a couple times and the answer was yes and no. Even emailed the company and they said no. if it does for sure, I'll order on the spot.
  2. Jan 23, 2017 at 9:18 PM
    #242
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    You could always just order it and give it a try. If it doesn't work, you could probably return it. And if not, sell it on here. They sell fast here.
  3. Jan 23, 2017 at 9:19 PM
    #243
    tacomah7
    tacomah7 Well-Known Member
    Brendan
    1999 Tacoma 4x4
    3" suspension lift (Sway Away 2.0 Racerunners with eibach 14" 650lbs coils) All Pro Offroad Rear Expo Leafs w/ toytec boss shocks 4crawler 1" body lift Trail gear front bumper & rock sliders Trail gear rear bumper w/ custom tire carrier 33x12.5x15 Cooper Stt Pro Glare led 42" curved lightbar spidertrax 1.25" wheel spacers on the front Smittybilt 9500 winch Trd E locker w/ 12voltguy harness
    pretty hard to clean this badboy clean
  4. Jan 23, 2017 at 9:22 PM
    #244
    carofchoice
    Jeff
    Newton, IL
    I probably will but still keep it for the other functions. Will have to do more searching on the answer first.
    DustStorm4x4[QUOTED] likes this.
  5. Jan 23, 2017 at 9:45 PM
    #245
    MCObray
    MCObray Well-Known Member
    Oregon
    2002 Toyota Tacoma DC TRD
  6. Jan 23, 2017 at 9:48 PM
    #246
    rmorit_DC_04
    rmorit_DC_04 Well-Known Member
    Bob
    2004 Double Cab - new to me in 2015
    ARE Tonneau Cover
    It is an automatic, but you program it with the x code feature. This link provides info on the codes you can enter https://www.tacomaworld.com/threads/scangauge-ii-transmission-temp.82690/
    Scroll down the first page and the codes are posted.
  7. Jan 23, 2017 at 9:50 PM
    #247
    MCObray
    Oregon
  8. Jan 24, 2017 at 5:27 AM
    #248
    carofchoice
    Jeff
    Newton, IL
  9. Jan 26, 2017 at 11:31 AM
    #249
    James Lee
    James Lee 1st gen for the win.
    Seattle,WA
    2001 Tacoma 4x4 Limited TRD
    -OME 882 coils -Jeep Jk 10mm trimpackers -Wheeler's extending rear brake line -OME Dakars+aal -4in Deckplate -nitro sport shocks all around -Star Hid projector headlights -Trail gear rock sliders -Trail Gear low profile front bumper -Pro Comp 51's 15x8 on BFG KO 32" -ARB snorkel -EBC pads and rotors -Rago Fabrication ditch lights+brackets -SpiderTraxx 1.25 wheel spacers -Snugtop Canopy
    More goodies on the rig.
  10. Jan 31, 2017 at 9:43 AM
    #250
    samTRD
    samTRD Well-Known Member
    Sam
    Gainesville,GA
    2001 Black Tacoma TRD
    3" toytec lift procomp series 69 wheels leer truck cap All-pro Apex front bumper baja design squadron amber fogs extreme LED ditch lights
    Did you have problem with scrubbing?
  11. Jan 31, 2017 at 12:38 PM
    #251
    mblkh2o
    mblkh2o Well-Known Member
    Manny
    Chandler, AZ
    2002 Black Tacoma TRD Crew Cab
    2.5 inch Bilstein 5100 lift and 3 leaf progressive springs w/Pro Comp 69 series wheels and BFGoodrich K/O2 265/75R16's
    Yes I do have a rub on the driver side front wheel well only when I turn right like 3/4 of a turn and I do have a frame rub at full lock but it's expected and I'm also going to raise the front another half inch with some coils either OME or eibachs
  12. Feb 3, 2017 at 12:12 PM
    #252
    James Lee
    Seattle,WA
    Is the tire carrier adjustable? Can it be seated closer to the canopy at an angle? I was planning on getting the same swing out bumper but i dont like the way how the spare tire sits so far out.
    Taco Addiction likes this.
  13. Feb 3, 2017 at 12:14 PM
    #253
    PROseur
    PROseur Well-Known Member
    Pussy
    2012 FJC TTSE/ 2001 Taliban Poverty DCSB/ 2017 6MT PRO / 2018 2.7L SR Utility
    Which spare tire carrier is that that you are looking at getting?
    Also what is your wheel/tire setup?
  14. Feb 3, 2017 at 12:16 PM
    #254
    James Lee
    Seattle,WA
    Cbi. I have 15x8 pro comp 51's with 3.75 backspace. running on 32's right now but upgrading to 33's towards the end of this year.
    PROseur[QUOTED] likes this.
  15. Feb 3, 2017 at 12:21 PM
    #255
    PROseur
    Pussy
    Do you have a straight side view of your truck, to show how much the wheels stick out?
  16. Feb 3, 2017 at 2:20 PM
    #256
    TrailRider2002
    TrailRider2002 Well-Known Member
    Cameron
    Powdersville, SC
    02 Tacoma 4x4
    -3in old man emu suspension lift with 882 coils, nitro chargers and rear add a leaf -1in Daystar Body lift -295/75 BFG KO2'S -flowmaster dual 40s
    Yes the tire carrier is adjustable and sadly the and will most likely stay the same. I used a little heavier metal then normal so it weighs it down a little bit
    James Lee[QUOTED] and PROseur like this.
  17. Feb 3, 2017 at 2:55 PM
    #257
    James Lee
    Seattle,WA
  18. Feb 3, 2017 at 4:18 PM
    #258
    Gen1tacotime
    Gen1tacotime Well-Known Member
  19. Feb 5, 2017 at 11:21 AM
    #259
    tahco_02
    tahco_02 Well-Known Member
    SoCal
    2002 Black TRD PreRunner Access Cab 2WD
    Stage 1 Lift, 16x8 SCS SR8, 285/75-16 Dick Cepek Extreme Country, Ethan's Skid, Driving Lights Mod
    Before and After (second time around)
  20. Feb 5, 2017 at 11:25 AM
    #260
    PROseur
    Pussy
    P.I.M.P.
