All fuel injectors bad?!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AthensTac, Jan 8, 2019.
  1. Apr 12, 2019 at 8:43 AM
    #81
    AthensTac
    AthensTac [OP] Well-Known Member
    CB
    Quicksand 4-door TRD sport
    It was January when the injectors were replaced.... truck ran fine till the other day....
  2. Apr 12, 2019 at 9:36 AM
    #82
    Brucey
    Brucey Well-Known Member
    Bruce
    2018 DC LB SPORT 4X4
    Ovtuned
    It under warrenty, she can point out to them to might check it if it stall again.
  3. Apr 12, 2019 at 9:48 AM
    #83
    joes06tacoma
    Joe
    Central Coast, CA
    Injection pump might be going out. Debris in injectors, replace for temp fix, then more debris kills the new ones.
    Drunken Chewbacca likes this.
  4. Apr 12, 2019 at 10:09 AM
    #84
    ICU1
    ICU1 Well-Known Member
    My bad. Sorry that happened and that you get it worked out. Would bad fuel cause this?
  5. Apr 16, 2019 at 6:32 AM
    #85
    AthensTac
    CB
    Was told yesterday that they have decided to replace the computer...... so I’m wondering if they are doing that because they cannot really figure out what happened? I am not in the position financially to trade vehicles, otherwise I would consider doing so....... I have had a lot of Toyota vehicles over the years and never had to tow one (well, there was the one I completely wore the clutch out on and we had to tow home LOL)... until this one. I have to believe this repair will take care of what ail’s it....
  6. Apr 16, 2019 at 7:06 AM
    #86
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    To be completely honest, that is usually the way to go unless you have a very clear picture of the exact issue. Cars are so complicated these days, the same issues can often be caused by many things. Usually if the problem is intermittent or hard to diagnose, you are left with traditional troubleshooting. Find the variables that most easily eliminate the largest amount of possibilities and repeat until you have an answer. The dealership can do this differently than an individual as it would get expensive quickly if you replaced the injectors, then the computer, etc. They have resources we don't. That was a long way of saying that, yes, they do not know what the issue is and are trying to eliminate possibilities. Did they replace the cps as stated on page 1. That sounded like a likely cause.
  7. Apr 16, 2019 at 7:09 AM
    #87
    AthensTac
    CB
    To my knowledge they have not replaced the cps.... I have inquired about it with them, but have not received a reply about it. Thinking if it has not been replaced when I get it back, that the hubby and I will replace it ourselves just to be sure.
  8. Apr 16, 2019 at 7:16 AM
    #88
    Pilsner
    18 TRDOR
    I wouldn't do that yet. If you still have issues and have to bring it back in they will take exception to other work being done. It makes troubleshooting a lot tougher if variables change during the process. I wouldn't touch it until warranty is up.
    Brucey and AthensTac[QUOTED][OP] like this.
  9. Apr 16, 2019 at 7:20 AM
    #89
    AthensTac
    CB
    What is the warranty period on it? I am out of factory, but did purchase an extended warranty. I have about 35,000 miles on it....
  10. Apr 16, 2019 at 7:20 AM
    #90
    fiftyxp
    fiftyxp Well-Known Member
    2017 trd offroad 4x4
    yes dont change it now that they are changing the computer.
    AthensTac[QUOTED][OP] likes this.
  11. Apr 16, 2019 at 7:38 AM
    #91
    Pilsner
    18 TRDOR
    I would wait until the end of the extended warranty, and only change it out if you have issues sometime down the road not covered under warranty. If they are addressing this issue under warranty, they will continue to work it out until it is fixed.
  12. Apr 17, 2019 at 7:46 PM
    #92
    AthensTac
    CB
    OK! Was able to pick up the truck today. Its about a 40 mile drive one way, and most of that is interstate, so was able to put it through its paces. It is for sure shifting differently than it was, but guessing thats because its "new brain" has to learn my driving habits. The idle feels smoother, and got 21mpg on the way home @75mph. Diagnostic showed codes P09024, P020113, and 160500 . They opened a TAS case and after testing this n that and about 200 miles of driving were told to replace the ECM.... so they did.
    bulalo, Brucey, Jessrin and 1 other person like this.
  13. May 23, 2019 at 4:02 PM
    #93
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    So is all good now? Computer replacement resolved the issue long term?
    AthensTac[OP] likes this.
  14. May 23, 2019 at 9:29 PM
    #94
    AthensTac
    CB
    Yes, so far all is good. Fuel mileage actually went up a couple mpg. Had to get used to the transmission doing its thing, but I believe we have an understanding now LOL. Last week drove about 1200 miles round trip to visit with my Mom and all was well. Thanks for asking....
    JNG, HacksawMark, bulalo and 2 others like this.
  15. May 23, 2019 at 10:33 PM
    #95
    r1200gs4ok
    r1200gs4ok Well-Known Member
    O. K.
    Irvine, Ca
    2016 Tacoma TRD Sport DCLB w/ Tech, Nav, Tow Pkg, MGM
    ill bet cps fixed the issue
  16. May 24, 2019 at 12:22 AM
    #96
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    Shotgun troubleshooting
    Chew likes this.
  17. May 24, 2019 at 1:22 AM
    #97
    bulalo
    bulalo Well-Known Member
    SoCAL Inland Empire
    2017 trd offroad 4wd LB
    KDMax pro 9.0
    So they never really replaced the cps right ?
  18. May 24, 2019 at 6:35 AM
    #98
    AthensTac
    CB
    Nowhere on my paperwork does it say the cps was replaced........
  19. May 24, 2019 at 6:36 AM
    #99
    AthensTac
    CB
    No, not to my knowledge.
    bulalo[QUOTED] likes this.
  20. May 24, 2019 at 3:07 PM
    #100
    r1200gs4ok
    O. K.
    Irvine, Ca
    meant to say: “fixes” when you install it....i think that is the problem
