All pro 5" rear springs installed won't level out
Discussion in 'Suspension' started by dtmccray, Jan 26, 2013.
  1. Jan 28, 2013 at 5:45 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    How tight is the brake line and BPV? Are they being stretched? There is no reason it should be leaning if your frame is straight and nothing is limiting the downtravel of your springs
  2. Jan 28, 2013 at 6:02 AM
    dtmccray
    dtmccray [OP] Well-Known Member
    millbrook alabama
    01 money pit
    d60 3link sas, bumpers, sliders, arb twin on board air comp w/11gal air tank,38.5/14.5r15 tsl sx swampers, rock 8 beadlocks, detroit rear, trutrac front.
    Brake lines are more than long enough. No Bpv on this one.
  3. Jan 28, 2013 at 7:50 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    I said to measure from top of bump stop on axle to bottom of contact on frame, disconnect the rear shocks, then take measurement. If hangers & shackles are fine, springs are equal & if it was all good before without the benefit of seeing it myself I don't know what else to tell ya, good luck
  4. Jan 28, 2013 at 6:56 PM
    SandDiesel
    SandDiesel Member
    Bob
    Phoenix
    2016 Tacoma TRD Offroad 4x4
    The driver side of my truck is .5-.75" lower than the passenger side anywhere you measure on the body. The rear shock shafts on my truck are extended 4.5" on drivers side and 6.5" on passenger side, much more than the visible lean. The frame height is equal on both sides when measuring from the ground making me look hard at the body mounts but nothing unusual. I did notice that if I measure from the ground to the center of both front and back leaf spring bolts, the drivers side is still a .5" lower. Doesn't sound like much but it's noticeable looking at the tail gate.
