All pro tube bumper Glass works?
Discussion in '1st Gen. Tacomas (1995-2004)' started by So.Cal Taco, Nov 18, 2011.
  1. Nov 18, 2011 at 9:07 AM
    So.Cal Taco
    So.Cal Taco [OP] Well-Known Member
    Jeremy
    So.Cal
    1996 4x4 v6
    Total Chaos Long travel Total Chaos Spindle Gussets, Nathan Air Chime K3LA's,Onboard Air system,K&N intake,Chuys 200 plus Amp Alternator,All Pro front Bumper,Lots of Dynamat,99 tacoma Gas Tank Mod ''Secret'' maybe I'll Tell
    Can someone tell me if my all pro tube bumper will fit with 4.5 inch glass works fiberglass fenders the bumper has those handles on the side 96 Taco?
  2. Nov 18, 2011 at 9:58 AM
    Box Rocket
    Box Rocket Well-Known Member
    Adam
    Syracuse, Utah
    1995 FZJ80 Land Cruiser
    3xLocked, lifted, well used
    I'm not positive but I think it should fit. If not you can always cut off those "handles" on the side of the bumper.
  3. Nov 18, 2011 at 12:26 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Isn't that what they did on their Baja build?? :notsure:
  4. Nov 18, 2011 at 12:38 PM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
    the baja build bumper is diff
  5. Nov 18, 2011 at 1:18 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    ...nooo...i am pretty sure its just the normal bumper..
  6. Nov 18, 2011 at 1:30 PM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
    its not the same the baja build has no handles but has the head light hoops
  7. Nov 18, 2011 at 1:51 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    You can order the bumper with those man..
  8. Nov 18, 2011 at 1:55 PM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
    I have the bumper on my truck it has the handles i just want to know if the glass works fenders 4.5 inch will fit without me having to cut off the handles.
  9. Nov 18, 2011 at 2:05 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  10. Nov 18, 2011 at 2:10 PM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
    ya the handles are set like 45 degrees and the head light hoops are higher so i can't tell.
  11. Nov 18, 2011 at 2:15 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I think the problem is that the fender overlapps the bumper and would hit it.
  12. Nov 18, 2011 at 2:38 PM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
    Ya that looks to be the case sucks time to grind off the nice powder coat
  13. Nov 18, 2011 at 6:07 PM
    atvlifestyle
    atvlifestyle Well-Known Member
    Michigan
    01 trd tacoma
    supercharged with MCM front kit
    I think you will have to cut them off. I have the allpro with out handles and the 3.5 glass and I dont see how it would clear if it was there. pics in my build should give you an idea of the room.
  14. Nov 23, 2011 at 7:19 PM
    So.Cal Taco
    Jeremy
    So.Cal
    1996 4x4 v6
    The glassworks 4.5 fenders do work with the all pro tube bumper.
  15. Nov 23, 2011 at 7:21 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Great to here! even with the handles??
