All Rock Guards On Sale This Month!
Discussion in 'All-Pro Off Road' started by allpro, Mar 4, 2010.
  1. Mar 4, 2010 at 9:18 AM
    allpro
    allpro [OP] Well-Known Member
    Montana
    All Kinds Of Toyotas!!!
    (Hot Chick Not Included!)
    These are no ordinary nerf bars. Our bars are trail tested and proven to protect your doors and rocker panels against severe trail hazards. There is nothing better than falling off the fifth waterfall at Surprise Canyon with no body damage. ​
    The outer tube angles up to provide more ground clearance and more door protection. The rear of the rock guard extends out to provide extra body protection where it’s needed most. This signature “kick-out” design protects the vulnerable rocker panels that are prone to damage. You’ll be glad you have this feature the next time you are wheeling next to a boulder, as you near the end of the sliders, they will push your truck out and away from danger just in time.​
    Our rock guards also make a great lifting point. A HighLift Jack can be used anywhere along the bars to lift one or both wheels. All rock guards come unpainted. ​
    95-04 Tacoma XCab/Dbl Cab 80" Bolt-On*- Now Only $279/pair!
    95-04 Tacoma/96-02 4Runner 60" Weld-On - Now Only $215/pair!
    05+ Tacoma XCab/Dbl Cab Short Bed 80" Bolt-On*- Now Only $319/pair!
    07+ FJ Cruiser 60" Bolt-On - Now Only $287/pair!
    84-95 Std Cab/4Runner 60" Weld-On - Now Only $215/pair!
    *Please Note: Tacoma Bolt-On Sliders do require drilling your frame to install. We recommend welding them on if used in situations where the full weight of the truck is on them. Also, these rock guards are designed to provide the utmost in off-road performance, and, as such, notching of the pinch weld is needed to tuck them up as high as possible so that ground clearance isn't limited. You don't want to get other sliders that hang down low, or you're just asking to get hung up on them, and no kickout equals inevitable damage to your rear doors/cab. Go with our trail tested & proven design!
    Extreme Duty DOM Rock Guards also available!
