All you longtravel Guys/Gals need your opinions.
Discussion in 'Long Travel Suspension' started by s13bdafocker, Feb 1, 2012.
  1. Feb 1, 2012 at 3:14 PM
    s13bdafocker
    s13bdafocker [OP] Well-Known Member
    Daniel
    Lake Havasu City
    2002 Taco TRD SR5 4x4
    3'' lift with 33'' tires and a high lift jack thats all rite now
    What are 3 major things you would change about your longtrave kits.
  2. Feb 1, 2012 at 3:17 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    I want lower uniballs, but no kit offers that without modification. Other than that I wouldnt change anything, Camburg is top notch :D
  3. Feb 1, 2012 at 3:18 PM
    s13bdafocker
    Daniel
    Lake Havasu City
    This is the number one issue i have heard.
  4. Feb 1, 2012 at 3:21 PM
    Cr250jumper
    The moon
    50 shades of tan©
    Yup that is the story with 1st gens :( 2nd gens get lower uniballs
    Are you trying to make a decision on which kit to buy? or making one?
  5. Feb 1, 2012 at 3:24 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    hes making one.
    upper and lower uniballs
    thats really the only thing i can think of.
    jd, is the only reason we cant get more up travel on our kits right now because the wheel well is in the way? or is it the kit that restricts that?
  6. Feb 1, 2012 at 3:26 PM
    Cr250jumper
    The moon
    50 shades of tan©
    I am pretty sure up travel is limited by a combo of the tire into the core support and the shock bottoming out. Mine hit at almost the exact same time (285/75 16's). True 33's might hit the support first. I think if you made a new shock hoop and removed the core support you can get a little extra, but idk how much
  7. Feb 1, 2012 at 3:27 PM
    Sunner
    Sunner Well-Known Member
  8. Feb 1, 2012 at 3:27 PM
    97yota4wd
    Eric
    Mesa, AZ
    okay i was going to say if the kit is the limiting factor on up travel it would be cool to get more!
    yeah uniballs are really the only thing i would change.... everything else is pretty much golden
  9. Feb 1, 2012 at 3:30 PM
    s13bdafocker
    Daniel
    Lake Havasu City
    Not one to buy things. Im going to start off with making some 1st gen kits and want to take care of the things that need to be addressed. I have some things in CAD and going to go full force into 2 test kits after the 18th of this month.
  10. Feb 1, 2012 at 3:31 PM
    97yota4wd
    Eric
    Mesa, AZ
    2 test kits..... hmm i wonder whos truck they will be on.......
    lucky bastards
  11. Feb 1, 2012 at 4:32 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Double shear everything, vertical upper uniball, and 3.0" shock capabilities
  12. Feb 1, 2012 at 4:57 PM
    97yota4wd
    Eric
    Mesa, AZ
    would a vertical upper uniball be useful on a 4wd kit? since you cant get more down travel out of the kit cause of the axel?
  13. Feb 1, 2012 at 5:03 PM
    97yota4wd
    Eric
    Mesa, AZ
  14. Feb 1, 2012 at 7:47 PM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    A boxed upper arm would be different. I like anthonys 3.0 coilover and vertical upper uni ball idea
  15. Feb 2, 2012 at 1:46 PM
    jtlachac08
    jtlachac08 Well-Known Member
    Jeremy
    Phoenix, Az
    vertical upper uni for sure!
  16. Feb 2, 2012 at 1:50 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
  17. Feb 2, 2012 at 2:16 PM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I'd honestly like to see vertical upper and lower uniballs so air bumps could strike the UCA. After reinforcing the hell out of the spindles, of course.
    Coilover + bypass + steering linkage + limit strap + axle doesn't leave much room for a bump on that LCA.
  18. Feb 2, 2012 at 2:18 PM
    97yota4wd
    Eric
    Mesa, AZ
    true, i wonder how much harder it is to make the bump strike the upper. you would need to with a 1 piece clip to do this though:(
  19. Feb 2, 2012 at 7:17 PM
    s13bdafocker
    Daniel
    Lake Havasu City
    Ok so let me know what you think about what I have in mind. I will keep in mind the 3.0 option and the upper or lower bump stop.
    Boxed lower and upper.
    Lower uni ball / upper uniball
    Upper heim joints - lower bushed
    Both spindle uniballs moved forward 1"-1.5" to help with tire fitment
    I have plans for a 4x4 spindle that can be bought with the kit or without the kit.
    My main plan is to sell the base kit for $1500-$1800 just for arms axles and steering extensions.
  20. Feb 2, 2012 at 7:37 PM
    Rebel Taco 22
    Rebel Taco 22 mall crawler
    I want one. Will it be 3.5'' over so we can run tundra axles?
