Alloys's and dis-simaliar metals
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Oldewing, Oct 25, 2010.
  1. Oct 25, 2010 at 8:28 AM
    Oldewing
    Oldewing [OP] Guest
    Went to rotate my tires yesterday and low and behold even with the lugs off and "kicking" of the tires, no go. After a 2 hour fight and a can of PB Blaster I got all 4 off. The hubs of the wheels where gauled to the steel hub on the truck.
    These wheels where off in the first week of August for new tires!!!!
    Wire brushed both and applied gobs of anti-sezie to each. Only reason I can come up with is, cheap ass rims
    Love my truck, but next time I get tires, steel rims going back on. If this had of happen of the road I would not have gotten the flat off.
  2. Oct 25, 2010 at 8:32 AM
    viperstd
    viperstd Tacoma convert
    Maryland
    09 4x4 TRD SR5 DC LB
    AllPro Front and Rear trail armor & full skid plates, Demello Hybrid Rock Crushers, Old Man Emu suspension, Warn 8000# winch, PIAA SMR fogs, perforated + heated leather seats, in-dash DVD/NAV/Sound, RE subs
    I just rotated my tires Friday after work and had to kick the crap out of all 4 wheels/tires to get them off of the hubs. One tip is to get under the truck and kick them off from the inside instead of trying to stand beside the truck and kick the top of the tire. I tried that for about 15 minutes before I broke down and laid under the truck. Once I started kicking from the inside, it only took 1 kick per tire.
    ...OBVIOUSLY, dont get under the truck unless it is PROPERLY supported on jack stands.
  3. Oct 25, 2010 at 8:35 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Are you still running factory rims? My mom's Subaru and some of my other trucks have always had issues with this and usually if you remember to apply a little bit of neverseize or grease between the wheel and the hub it comes off without any issues the next time. I don't think it has anything to do with the price of the wheels, just the reaction between the two metals.
  4. Oct 25, 2010 at 8:36 AM
    Pugga
    Massachusetts
    Rubber mallet works well also (hit the tire, not the rim).
  5. Oct 25, 2010 at 8:40 AM
    Oldewing
    Oldewing [OP] Guest
    Pugga,
    Yes stock rims, and yes I did put "gobs" of anti-sezie on when I put them back. My point is that if the wheels where a better grade they would not degrade as fast. Alloy on my Vibe(read Matrix) have never stuck, nor my race car rims, also alloy
    viperstd
    On jack stands, holding the axle and kicking hard( 6'4" 250lbs)........
  6. Oct 25, 2010 at 8:46 AM
    Pugga
    Massachusetts
    I didn't mean to sound confrontational or to doubt you, I've been there in the same situation on plenty of occassions and had the same thought, if this were an emergency, I'd never get the flat tire off the f-in truck! I'm surprised they seized up that quickly though, that's unusual.
  7. Oct 25, 2010 at 8:47 AM
    viperstd
    Maryland
    hrmm... maybe you should play more soccer, 5'10" 148 lbs :D
    It sounds like there was a pretty massive amount of galvanic corrosion. As others suggested, a film of lithium grease or anti-seize should prevent the problem from occuring (or at least slow it down to a rate that doesn't cause a problem w/ a regular tire rotation schedule.)
    :cheers:
  8. Oct 25, 2010 at 9:29 AM
    Oldewing
    Oldewing [OP] Guest
    Well, I guess some gym time would not kill me, but it's happy hour.
    Just glad I did not find out in the dark on the side of the road somewhere....
  9. Oct 25, 2010 at 5:42 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Its just the law of physics
    disimular metals and winter salt.
    Im sure the anti - sieze will help.
    the best you can do is remove them every spring and clean them up.
    or move to arizona!
  10. Oct 25, 2010 at 5:58 PM
    Leadgolem
    Leadgolem Well-Known Member
    Greg
    Littleton, CO
    98 Tacoma SR5 2.7L 4x4 stick
    Herculiner bed liner, White LED instrument lights, Custom painted hood, Homemade leather steering wheel wrap, Avic u310bt gps stereo, 1.5" bushwacker fender flares, 1.25" bilstein lift front, 1" shackle lift rear, rear bilstein 5100 shocks, ridiculous helper spring lift rear, wet okole seat covers, mutilated exhaust, boom mat under hood
    It's also a good idea to kick the side, rather then the top, of the tire. If you kick the top you are fighting against the weight of the tire too.
  11. Oct 26, 2010 at 3:35 AM
    Oldewing
    Oldewing [OP] Guest
    I am a side kicker from way back:rimshot:
  12. Oct 26, 2010 at 12:28 PM
    Oldewing
    Oldewing [OP] Guest
    I also went rust hunting after reading the about the frame rust issues. I have more than should be, but not enough to worry too much about. The 'lip" of corrosion was big enough to have to scraped off on my truck. However after speaking to other owner's this seems to be "normal"..
    Nice shocks..............
  13. Oct 26, 2010 at 12:42 PM
    viperstd
    Maryland
    what rust?! Wait until after a winter or two. There are times when I actually miss Florida... like when I am under my truck after a winter in New England. Do they salt much in canuckville?
  14. Oct 26, 2010 at 12:52 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    This may be a stupid question, but how using about a sacraficial annode like the ones used on an outboard boat motor? I.E. boat motor made of aluminum and steel components used in saltwater it would corrode and rust to hell really quick, every outboard motor I have ever seen uses these and once they start to erode you simply replace them, one or two bolted to the frame forward and aft MAY help?
  15. Oct 26, 2010 at 1:11 PM
    viperstd
    Maryland
    It isn't a stupid question. They are used in marine applications for a good reason. BIG ships use active anodes on the hull for protection too.
    Whenever dissimilar metals make contact, the less noble will corrode. The greater the dissimilarity between the galvanic properties, the faster the anodic metal will corrode.
    http://www.eaa1000.av.org/technicl/corrosion/galvanic.htm
    To avoid corrosion, avoid a small anodic area relative to the cathodic area.
    Corollary I - Use LARGE ANODE AREA.
    Corollary II - The larger the relative anode area, the lower the galvanic current density on the anode, the lesser the attack.
    Corollary III - The amount of galvanic corrosion may be considered as proportional to the Cathode/Anode area ratio.
    Corollary IV - Design for a SMALL Cathodic/Anodic Ratio (CAR).
    Corollary V - The same metal or more noble (cathodic, higher number in the table) metals should be used for small fasteners and bolts.
    It might be possible to prevent some rust on the trucks by putting sacrificial plates on the frame. Anyone want to try it?
  16. Oct 26, 2010 at 1:23 PM
    viperstd
    Maryland
    Nice! I miss the snow. I'm ready for winter.
    I realized that this wasn't clear... there would need to be a lot of plates all over the palce. The more, the better... in essence you are trying to make the equivalent of a hot-dipped galvanic coating.
  17. Oct 26, 2010 at 1:24 PM
    Monkeysuncle
    Kevin
    Florida
    It might be possible to prevent some rust on the trucks by putting sacrificial plates on the frame. Anyone want to try it?[/quote]
    Ok,, I didn't do well in chemistry, so you are saying, use a bigger anode on a truck because the amount of steel is greater on a vehicle than on a typical boat made of fiberglass? SO more anodes placed more often on a frame/body will provide a greater degree of protection? Or is that to simple?
  18. Oct 26, 2010 at 1:31 PM
    viperstd
    Maryland
    More anodes, everwhere is better than one centrally located one... however, since we don't usually drive our trucks underwater, it isn't going to provide a high level of protection. Basically, if a salt water puddle sprays up on the truck frame, that particular area will be exposed to an electrolytic... if that area also has an anodoic element, it could be proteceted. You need the saltwater to carry the current flow. In leiu of that, you need protection everywhere.
    I was being a bit facetious when I originally suggested the anodes.
  19. Oct 26, 2010 at 4:57 PM
    Oldewing
    Oldewing [OP] Guest
    I think a good smeer of anti-sezie should do
