Allpro expedition springs
Discussion in '1st Gen. Tacomas (1995-2004)' started by The Munster, Apr 13, 2011.
  1. Apr 13, 2011 at 6:50 PM
    The Munster
    The Munster [OP] I like turtles!!!
    Lance
    Moody AFB, GA
    Hey guys, so I got my springs along with some Billy 5150s. I opened everything up and started thinking. The springs will give me 4" unloaded, so will I need extended brake lines in the rear. If I do, will I be ok to drive around till the lines get in???
  2. Apr 13, 2011 at 7:19 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    PM Jlee he is running those leafs and Billy 5150s, he will know if your safe till they come. But yes i think you will need extended brake lines
  3. Apr 13, 2011 at 7:23 PM
    malander
    malander Well-Known Member
    max
    01 limited trd 4x4
    deck plate mod,jba cat back,bilstein 5100's,ome 883 springs, Allpro expos, allpro U-bolt flip kit, 10" Bilstien 5150 shocks, custom lower shock mounts
    Get lines before you install. Most 1st genners I've talked to report 4.5-5" of lift out of these springs.
  4. Apr 13, 2011 at 7:42 PM
    The Munster
    Lance
    Moody AFB, GA
    i tried to pm him, but he doesn't have a button
  5. Apr 13, 2011 at 11:28 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    should be able to by clicking on his name...
  6. Apr 14, 2011 at 3:11 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    you will need an extended brake line for sure,the stock one will be at its max and then some.
  7. Apr 14, 2011 at 3:16 PM
    Johnnie
    Johnnie Well-Known Member
    I.E. SoCal
    Feds
    You could get away with the stock brake line at 3" because it's rubber but anymore than that you'll need an extended line. You don't want that line to break on you.
  8. Apr 14, 2011 at 3:21 PM
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    Yeah we talked and just to put my 2c in YES you do need longer lines hell I couldn't even install my Expos with the stock break lines. I got just about 5" of lift with the Expos and the 1.5" extended shackles (3/4"Lift) and with the springs with no load(IE frame on jack stands) it's more like 7"
  9. Apr 14, 2011 at 6:52 PM
    malander
    max
    01 limited trd 4x4
    Wait a minute...you have lift shackles too?! So you current ride height in the rear is ~5" correct? So with stock length shackles it would be more around 4.25"?
  10. Apr 15, 2011 at 4:36 PM
    The Munster
    Lance
    Moody AFB, GA
    Well I got everything I need.. Except shackles. I've looked around and I cant find any that DO NOT give lift. I ran down the road to fat bobs garage and he won't have any for 3 weeks. Toytec has OME ones that are greasable but wheelers Offroad says they only work with OME springs. .. Help!!!!
  11. Apr 15, 2011 at 4:41 PM
    malander
    max
    01 limited trd 4x4
    I thought they would work with stock shackles and their bushings? :shrug:
  12. Apr 15, 2011 at 4:43 PM
    Johnnie
    I.E. SoCal
    Feds
    Why do you need longer shackles? Your stock shackles will work fine unless you really want to go higher. Your expo leafs should have come with new bushing too. How high do you plan on going in the front?
  13. Apr 15, 2011 at 4:44 PM
    TacoSID138
    TacoSID138 Well-Known Member
    SoCal
    04 PreRunner TRD
    Faded out tinted tails and 3rd brake light,deck-plate mod, dumped Flow Master 40, King EXTD coil overs, 1.5 AP shackles, AP EXPD leafs. 285 Hankook DynaPro ATM tires
    x2 I want tp pick these springs up for my future lift. and was planning on using the stock shackles....
  14. Apr 15, 2011 at 4:46 PM
    Johnnie
    I.E. SoCal
    Feds
    You're supposed to use your stock shackles unless you plan on going more than 3" in the front.
  15. Apr 15, 2011 at 4:52 PM
    JLee
    Jerry
    Benicia, CA
    Yeah I'm just under 5" of lift so give or take a little 4 to 4.25"
  16. Apr 15, 2011 at 4:53 PM
    JLee
    Jerry
    Benicia, CA
    I only have 3" in the front and I have just about stock rake.
  17. Apr 15, 2011 at 4:56 PM
    JLee
    Jerry
    Benicia, CA
    If you shackles are anything like mine were your going to want new ones. I had to beat my bolts out and almost had to cut one off.
  18. Apr 15, 2011 at 5:10 PM
    TacoSID138
    SoCal
    04 PreRunner TRD
    the truck has 77k on it. you think they would be on there pretty good? if i use the grinder and do what you mentioned above, would the shackles be pretty beat up?
  19. Apr 15, 2011 at 5:29 PM
    The Munster
    Lance
    Moody AFB, GA
    My truck has 226000 miles on the original shackles... Those babies aren't coming off... Yes the springs come with bushings and a sleeve already installed
  20. Apr 15, 2011 at 5:30 PM
    The Munster
    Lance
    Moody AFB, GA
    Yeah I only have 3 inches in the front. That's why I need shackles with NO lift
