already asked kinda of but still dont understand...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 08pretaco, Feb 24, 2010.
  1. Feb 24, 2010 at 7:41 AM
    08pretaco
    08pretaco [OP] Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    why is it that sometimes i can be driving and in first gear i can disengage the transmission without my clutch? i can also take it out of 5th gear everytime that i am coasting in it without engaging the clutch!
    you guys already told me that its because everything lines up but is there anything more to it than that?
  2. Feb 24, 2010 at 7:44 AM
    Voodoo Rufus
    Voodoo Rufus Well-Known Member
    Bakersfield, CA
    07 Sport Indigo Ink DCSB 4WD
    Magnuson S/C, Relentless armor, Icon/Dakar suspension, Konig CountersteerX 17", KO2's, Hellwig rear swaybar, BudBuilt Trac Bar, Level 10 VBU, Weathertech floorliners, Cravenspeed antenna, Redline elite hood struts, RollnLock, Satoshi, CBI sliders
    If there is the zero or the right amount of load on the transmission you can disengage the gears without the clutch. If you don't hear any grinding it's probably fine. Used to do it in an old Honda on occasion.
    That's all there is to it.
  3. Feb 24, 2010 at 7:47 AM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    RPM matching. It's all about hitting the right RPM and you can do it in and out of any gear. It's not exactly bad for the engine (if you do it right) but it's not good either.
  4. Feb 24, 2010 at 7:50 AM
    08pretaco
    az
    cause everytime im driving and it doesnt matter the rpms for 5th gear, 1.5k 2.5k, i can disengage it without any grinding happening
  5. Feb 24, 2010 at 7:54 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I always do that when coming to a stop. I just leave it in the gear im in, wait untill the RPM drops to about 1000 and it will pop out of gear without the clutch very easily.
  6. Feb 24, 2010 at 8:04 AM
    grivera
    grivera Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    In a standard transmission there are synchronizers between the gears. When you shift, as you engage the next gear, a sleeve (for a lack of a better term) rides over the synchronizer for said gear. There is a taper on the synchronizer which aids in it slowing down as the sleeve slides over it to mesh with the next gear. Disengaging the clutch reduces the friction caused during this process because the transmission isn't being forced to turn with the speed of the flywheel. At certain speeds, the synchronizers' speeds are compatible and things "fall into place" smoothly. These are the times when one can easily shift without a clutch.
    When synchronizers become worn, even with the use of the clutch, the process will often cause grinding.
  7. Feb 24, 2010 at 10:58 AM
    08pretaco
    az
    cool so on the drive home just now, it actually does it for all the gears except 1st once i reach under 2k
  8. Feb 24, 2010 at 11:14 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    Excellent description. The new 370Z even has software that rev matches the engine for you so you can down shift without using the heel/toe technique.
    Before anyone asks...
    http://en.wikipedia.org/wiki/Heel-and-toe
    http://www.drivingfast.net/car-control/heel-toe-shifting.htm
  9. Feb 24, 2010 at 11:17 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Used to do it w/ the bike all the time when rowing through the gears/accelerating. Never tried it w/ the truck though.
  10. Feb 25, 2010 at 8:19 PM
    08pretaco
    az
    how long does your clutches usually last?
