alternator current and amps advice
Discussion in 'New Members' started by tviada, Nov 7, 2010.
  1. Nov 7, 2010 at 12:12 PM
    tviada
    tviada [OP] Member
    tom
    northern california
    02 tacoma ext.cab 4x4
    billet grill,leather interior,rear light guards,eagle alloy rims
    I've got a 2002 tacoma v-6 4x4 ext. cab with a stock alternator and I'm putting in a JL 400-4 channel amp for 4 infinity 5x7 speakers, and a 1000 watt 2 channel amp thats bridged powering 1 bazooka sub tube. my queston is will the stock alternator keep up with the extra draw or will I need to install a capacitor to store extra juice?The stereo is an aftermarket sony.
  2. Nov 7, 2010 at 12:59 PM
    WATRD
    WATRD Keyser Soze
    Rob
    Duvall, WA
    '01 Supercharged SAS
    Check out my site, it's mostly up to date and there's too much to list here.
    A capacitor is really for smoothing out quick power demands, like when the bass hits suddenly. It's not a substitute for having an adequate battery and charging system over longer periods. I am betting you are going to need upgrades all around if you plan on using that system for extended periods.
  3. Nov 7, 2010 at 1:15 PM
    tviada
    tviada [OP] Member
    tom
    northern california
    thanks, so I should get a bigger alternator?
  4. Nov 7, 2010 at 4:28 PM
    WATRD
    WATRD Keyser Soze
    Rob
    Duvall, WA
    I am sure there are more audio oriented folks on here than myself, who are better qualified to answer here, but what I have always done/heard, a bigger or additional battery allows the unit to be used more heavily/longer. It's also good, clean, relatively spike free power. However, a bigger alternator enables you to refill that that battery capacity faster, or keep it topped up.
    Batteries, alternators and capacitors are all part of the equation. You have to build in a properly balanced way or your system will be less than it could have been.
  5. Nov 8, 2010 at 6:52 PM
    tviada
    tviada [OP] Member
    tom
    northern california
    thanks, I appreciate the help!!
