Alternator noise, new HU
Discussion in 'Audio & Video' started by 81Taco, Feb 10, 2017.
  1. Feb 10, 2017 at 7:09 PM
    81Taco
    81Taco [OP] Well-Known Member
    Bend Overegon
    2015 DCSB, SC
    F me. I've installed several car stereo systems, but now I've got a bugger.
    My setup:
    Kenwood HU
    Alpine power pack
    Jbl door speakers.
    Today i installed the kenwood. I was already using the power pack and door speakers. Now im getting alternator whine. I tried several grounds. In switching to the aftermarket HU, i went from high level inputs to rca's.
    Heres another tidbit. Ive got a jl amp and subs in the back and those rca's ring like hell when i plug em in.
    Spent 7 hours on it today. Rca's are run down the passenger side, power on the drivers side.
    Tomorrow I'll try grounding the rcas at the deck, and T'ing all 3 grounds. Running a ground directly to the battery did nothing.
  2. Feb 10, 2017 at 7:22 PM
    Team Flatline
    Team Flatline Not squatin' w/ my spurs on...
    Eric
    Up a creek, Fla
    PreRunner
    Maxtrac'd, Icons, Dakars...........
    On your 445 Power Pack, did you flip the DIP switch on the bottom to low-level RCA?
    81Taco[OP] likes this.
  3. Feb 11, 2017 at 6:21 AM
    jv_74
    jv_74 Well-Known Member
    Jesse
    Filthadelphia
    2015 DCSB Silver Sky Metallic
    Ugh. This is one of the worst problems to track down.
    I went through this same thing with my setup - turned out the amp itself was the culprit (shitty Dual)
    That being said, the PowerPack is a good amp. What kind of RCA's are your using? Maybe the RCAs themselves are the issue? You COULD go back to high level inputs or buy an upgraded set of twisted RCA's
    Also that^...
  4. Feb 11, 2017 at 6:58 AM
    81Taco
    Bend Overegon
    2015 DCSB, SC
    Yes
  5. Feb 11, 2017 at 8:02 AM
    81Taco
    Bend Overegon
    2015 DCSB, SC
    Rca's are ebay cheapos.
  6. Feb 11, 2017 at 8:49 AM
    jv_74
    Jesse
    Filthadelphia
    I have used cheap RCAs before with no issue, I've also used cheap RCAs and gotten the whine. Not much help but I'd probably start by getting a good set of braided ones.
  7. Feb 11, 2017 at 8:52 AM
    81Taco
    Bend Overegon
    2015 DCSB, SC
    Yeah. I've read all the threads on this last night and that is highly suspect. I don't have any more money to blow!
  8. Feb 11, 2017 at 8:53 AM
    jv_74
    Jesse
    Filthadelphia
  9. Feb 11, 2017 at 8:55 AM
    nm4553
    nm4553 You had me at "Meat Tornado"
    Nick
    NEPA
    2017 DCSB TRD Sport
    SCS Stealth 6 Matte Bronze on Toyo Open Country 265/70R17, Fox 2.5 Coilovers, Bilstien 6150 w/ Remote Resi, Dakar Leaf Pack, Wheeler's Bumpstop, OVTuned
    Probably need some ground shields.
  10. Feb 13, 2017 at 1:16 PM
    81Taco
    Bend Overegon
    2015 DCSB, SC
    Ok, so i ran a wire from my HU red RCA to my AMP end of the RCA and the noise went away. Tried a different set of RCA's and got the same bad noise.
    Is this an RCA problem, or something else? I hesitate to buy a really expensive set of RCA's if I'm going to have to still run that wire.
  11. Feb 13, 2017 at 1:26 PM
    jv_74
    Jesse
    Filthadelphia
    Can you elaborate what you did? "i ran a wire from my HU red RCA to my AMP end of the RCA" What did you tie this wire to?
  12. Feb 13, 2017 at 1:50 PM
    81Taco
    Bend Overegon
    2015 DCSB, SC
    Outer shields of the red connector.... at each end of the cable.
    The wire is pinched between the red rca cable and socket.
  13. May 18, 2019 at 6:02 AM
    rogerman
    rogerman Well-Known Member
    Roger
    HNL 808, SPN 670
    2000 Tacoma SR5 V6 4wd 5speed
    Hey OP did you ever solve this? I have the same set up as you and have that whine.
  14. May 18, 2019 at 6:16 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    If that fixed it, try a cheap ground loop isolator. Your local Best Buy will have one for $15, and of course Amazon will have them as well.
    I’ve never had good luck with cheap RCA’s. The ones that come in BOSS and Rockville wiring kits especially. I usually tell my clients I don’t recommend them and if we have to pull them out and run new ones, it’s costing them another 30-60min of labor. I usually run the blue Kicker cables and be done with it. But the ground loop isolator is cheaper and an easy add-in. Plus it’s an easy removal and return if it doesn’t work.
  15. May 18, 2019 at 6:35 AM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Yeah, sounds like a ground loop. But it can be bad grounds - poor contact at one of the connections. Grounding all the gear at the same location typically works to iron it out but not always. In some cases all grounds need to go straight to the battery. As mentioned above ground loop isolators can work but starting with known good grounds (no paint, low resistance, etc) is always best practice.
    I've never had issues with cheap signal cables personally as long as certain conditions are met...like the terminal fits the jack snugly. But a noise prone environment might benefit from a shielded or twisted pair cable.
  16. May 20, 2019 at 2:12 PM
    pinktaco808
    pinktaco808 Hot Steppa
    Rf make good cheap rca
