Aluminum oil filter
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RED_BEARD 4X4, Apr 25, 2021.
  1. Apr 25, 2021 at 8:12 PM
    RED_BEARD 4X4
    RED_BEARD 4X4 [OP] Well-Known Member
    Vista, ca
    2016 TACOMA TRD SPORT 4X4 DCLB
    Has anyone used the aluminum oil filter from Amazon? I have broken 3 of the plastic housing by braking the 3 plastic notches!
    I’m not sure how to add an Amazon link here...
  2. Apr 25, 2021 at 8:20 PM
    Lunar Cruiser
    Lunar Cruiser Well-Known Member
    There is a tool for the filter
    If you break 3 times are you sure you have the right tools
    Aluminum filter housing is great I like them
    Dirk Diggler, pltommyo and Skydvrr like this.
  3. Apr 25, 2021 at 8:20 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    dang, 18 pound feet if I remember correctly, that's just about how tight the housing should be
    if you had broken notches, you or someone must have over tightened the crap out of it
    FWIW
    I had aluminum housing, bought it from the dealership. No problem for me, but still I torqued it to spec so even the plastic one shouldn't break under correct torque spec.
  4. Apr 25, 2021 at 8:22 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Definitely over torqued if you're breaking off the tabs lol.
    Dirk Diggler likes this.
  5. Apr 25, 2021 at 8:37 PM
    RED_BEARD 4X4
    Vista, ca
    I didn’t know the dealership cold them too?
  6. Apr 25, 2021 at 8:38 PM
    RED_BEARD 4X4
    Vista, ca
    The dealership has only done my oil. Today was my first attempt to doing it. Super upset
  7. Apr 25, 2021 at 8:38 PM
    Losv
    Losv Active Member
    2019 Tacoma TRD Off Road 4x4
    I just did my first oil change yesterday and swapped to the aluminium one. Looks better in my opinion and matches with the rest of the engine.
    Georgia Native likes this.
  8. Apr 25, 2021 at 8:39 PM
    RED_BEARD 4X4
    Vista, ca
    I’m just looking for the rigidity and fucking plastic? Who does this!
  9. Apr 25, 2021 at 8:41 PM
    malatx
    Yes, you can go to parts department and say you want to buy oil filter housing for your Tacoma v6. Chances are they are plastic. I visited 2 different dealerships locally to finally find one that had just 1 aluminum housing left in stock.
  10. Apr 25, 2021 at 8:42 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
  11. Apr 25, 2021 at 8:47 PM
    malatx
    Yep, I had an Avalon and only had dealership done all the maintenance until the warranty expired.
    First time I tried to change oil, the housing was so tight I had to go out and buy a breaker bar just to loosen it.
    You'd think that dealership would do it right, but I learned that and after that only change oil myself and not even gonna use the free oil changes Toyota offers.
  12. Apr 25, 2021 at 8:54 PM
    RED_BEARD 4X4
    Vista, ca
    It is very frustrating. I’m also not used to this type of oil filter set up. coming from a family of Ford lovers this is like working on a spaceship aha
  13. Apr 25, 2021 at 8:58 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Get a plastic one and if you treat it right...
  14. Apr 26, 2021 at 5:13 AM
    RED_BEARD 4X4
    Vista, ca
    I tried, i hardly put any pressure on it before the teeth broke. I even bought the adapter from local toyota dealership.
    hiPSI[QUOTED] likes this.
  15. Apr 26, 2021 at 6:27 AM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    You broke 3 plastic housings while doing one oil change?
    Talented!
    Northerntaco69 and beergeek like this.
  16. Apr 26, 2021 at 6:28 AM
    JEFFRPM
    JEFFRPM Well-Known Member
    Jeff
    2018 inferno Double cab long bed 4x4
    17 x 8.5 KMC wheels, yokohama 285-70-17 geolander, 3" lift, 800 watts of alpine, leer shell, front & rear cloud cameras,
    Get the snap on wrench
  17. Apr 26, 2021 at 6:44 AM
    FLA_Hoosier
    FLA_Hoosier Well-Known Member
    Rick
    Space Coast
    2017 White TRD Sport AC
  18. Apr 26, 2021 at 6:52 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Yes, be careful with aluminum on aluminum. Galling happens very easily with Al to Al contact.
    Suggest to use a little lube on the threads and DO NOT over torque it.
    Hairless_Ape likes this.
  19. Apr 26, 2021 at 7:00 AM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    On my wife's 4Runner the first time I did the oil change I had to use a 30" cheater bar to break it loose. I've ordered the metal housing and will be installing it on the next oil change but I would definitely like to have a word with whoever severely over-torqued it at the dealership.
  20. Apr 26, 2021 at 9:11 AM
    Hemlocktherm78
    Hemlocktherm78 Well-Known Member
    Hi
    I broke my filter housing the day before a long trip. 2017 OR taco. Yes, same amazement and frustration about plastic housing. The three teeth on one side and two on other (something to that affect) do not distribute the applied torque evenly. All the torque went on one single tooth on plastic housing and cracked off on mine. Luckily I heard it and could view filter media thru hole before filling oil.
    Use the below linked wrench which grabs the bottom of the housing on the 14 flats instead.
    I ordered a aluminum housing instead also and will put it on next oil change. Luckily my dealer had the replacement plastic housing in stock. The parts dept said it is a common occurrence. Likely due to popular wrenches which grab the housing mid way up by the teeth like projections. Ill put the new plastic housing in rear storage incase Im on a trip and aluminum one damaged etc .
    Cause yer up a creek if it breaks.
    Assenmacher Specialty Tools TOY 640 Oil Filter Socket Wrench for Toyota/Lexus
    https://www.amazon.com/Assenmacher-Specialty-Tools-TOY-640/dp/B0015PK3AG
    Aluminum housing:
    https://www.amazon.com/Genuine-Toyota-15620-31060-Filter-Assembly/dp/B008BHP68A
