Aluminum Sliders?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by g34rh34d, Feb 4, 2012.
  1. Feb 4, 2012 at 2:45 PM
    g34rh34d
    g34rh34d [OP] Well-Known Member
    Colorado
    '08 4 DR TRD Off Road - 3" OME Lift, UCWMS
    UCWMS; OME 3" lift/OME 885 springs; OME 90000/60091 shocks; Diff drop Spacers; Light Racing UCAs
    Anyone consider Aluminum sliders? Obviously you would use a decent thick walled aluminum tube (Square or Round) and build them just like any of the normal sliders.
    I was talking to my neighbor today who does a lot of aluminum custom Gas tanks for diesel trucks using the spare wheel well. (Very cool BTW.) I broached the subject with him on the idea, and honestly for the light amount of off-roading I would do anymore this may be a nice option. We could purchase some nice 1/4" wall aluminum tube from the local aluminum supplier, and then use a 1/4-3/8" L angle for mount points.
    The idea being that these would be stronger than just nerf bars or step tubes, and give you a 75% solution for mild off-roading, yet save some weight.
    I think the major considerations would be dissimilar metals oxidation between the frame and the L angle, or possibly the aluminum turning dull, unless they were painted or powder coated.
    Has anyone ever considered it/made any?
    Pros/cons?
  2. Feb 4, 2012 at 2:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    I would think they would be more prone to gouging than the steel ones.
    ChadsPride likes this.
  3. Feb 4, 2012 at 3:04 PM
    zul
    zul Professional Goofball
    PNW
    2012 Pyrite Mica DCSB SR5 4WD V6 AT
    HAVE: Bed mat, Tailgate Lock, Color-matched Grille, Weathertech Floor Liners, Avid Step Rails WANT: Rear Plate Bumper, RokBlokz mud flaps, Steel bed cage
    If you get decently thick aluminum I believe it would hold the truck off of rocks, but it would gouge and scrape like nobody's business. I doubt even a thick bed liner or powdercoat would keep aluminum with a bunch of weight on it from gouging.
    Now if you really want to save weight without sacrificing strength, have your buddy fab up some sliders out of Titanium! :laugh:
    R0dzilla75 and DrFunker like this.
  4. Feb 5, 2012 at 5:58 AM
    g34rh34d
    Colorado
    Yea, that is a good point.. One or two good rubs and they may end up looking like string cheese. I wonder if some 6061-T6 would be resistant enough for some occasional brushes against the rocks. I need to look into the properties a bit more.
    Thanks!
  5. Feb 5, 2012 at 6:03 AM
    g34rh34d
    Colorado
    Lol yea, in retrospect aluminum may just be a bad idea.. But that is why I figured I'd at least get a discussion going on the topic.
    Now Titanium.... hmmm. lol!
    http://www.titaniumtubing.com/
  6. Feb 5, 2012 at 6:30 AM
    Twizter68
    Twizter68 AMS1(AW), USN retired
    Bill
    Weatherford, TX
    08 Crew Cab Prerunner
    For what you would spend making one set out of titanium, you could buy 4 sets of steel sliders...and the titanium ones would not last any longer than good quality steel ones. It's not the wonder metal some folks think it is.
  7. Feb 5, 2012 at 9:12 AM
    badger
    badger Well-Known Member
    07 SR5
    If you are going to do a lot of actual rock sliding, then steel is better because it's harder. For the other 90% of us that just want protection without a ton of weight, aluminum would be great. You can match the strength of steel at much lower weight. The tensile strength of 6061-t6 is 45K PSI, typical low carbon steel hot rolled is 47K and typical low carbon cold rolled is 53K. I would go thicker on the aluminum by maybe 25%. You wouldn't see much strength advantage over steel unless you are talking 4130 (chromoly) or similar. I would powdercoat it to prevent corrosion. Aluminum weighs 1/3 of steel, so even with a slightly thicker wall you're talking a weight savings of around 60%.
    warehouse32 likes this.
  8. Feb 5, 2012 at 9:15 AM
    steve o 77
    steve o 77 braaap
    Steven
    In a corn field, OH
    1990 Chevy Siveraydo
    I'd go at least 3/8" wall if it's even made. Also use square tube for the mounting legs. If you aren't coming down on rocks ever and just light use I think they would work. I just wouldn't hi lift off them if you used 1/4" wall.
  9. Feb 6, 2012 at 4:16 AM
    g34rh34d
    Colorado
    Yes, I realize that - I was actually kidding. The reality is for the cost of materials (aluminum or other) it would cost the same if not more than to just buy a set already made up. (That is the reality, and probably the way to go!)
    Thanks
  10. Feb 6, 2012 at 4:21 AM
    g34rh34d
    Colorado
    You touch on my original thought. I don't wheel much at all anymore, the idea for my use would be for camping and the yearly hunting trip, just for some added rocker protection.
    Thanks for providing the tensile strength data!
  11. Feb 6, 2012 at 4:24 AM
    g34rh34d
    Colorado
    That makes sense. If you were to do some out of Aluminum, you certainly would have to beef up the wall thickness to account for the softer material. IF I were to make some, regardless of the material, they would have to provide enough strength to use a high lift jack.
    Thanks
  12. Feb 6, 2012 at 5:50 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    Also with alum. sliders you would have to make them bolt on. Cant weld aluminum to steel right?
  13. Feb 6, 2012 at 6:11 AM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    03 F250 CCSB
    Gibson stainless headers, custom free-flow Y-pipe, Magnaflow muffler, 285/75R16 KBro2's
    This was my thought. You would have to build them in some way that they would bolt to steel mounting brackets welded to the frame. Maybe some smaller diameter steel tubing that would slide inside the aluminum tubing and then bolts go through both.
    If we're talking unconventional materials, go with aluminum main body with tungsten carbide added to the sides that would actually make contact with the rocks.
  14. Feb 6, 2012 at 9:03 AM
    badger
    07 SR5
    Properly designed you would not need more than 1/4" wall. Where people miss the boat is by copying a steel design in aluminum. When you change the material you need to adjust the design. More extensive use of gussets, etc. You will need extra attention at the welded joints. There is no reason that you can't build an equal strength slider at a 60% weight savings.
  15. Feb 6, 2012 at 9:06 AM
    G scott04
    G scott04 ...
    Garrett
    Mesa
    04 PreRunner
    This is brilliant! bolt on aluminum sliders. I only want sliders to dent door flingers anyway, mall crawlin ftw.
    Sugar Silva likes this.
  16. Feb 6, 2012 at 10:13 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    thats what tube steps and running boards are for :p
  17. Feb 6, 2012 at 10:14 AM
    ruggedT
    ruggedT The Sticker Guy Vendor
    Stan
    Midlothian, Va
    2016 Ford F250
    Diesel on 35's
    I made a set of aluminum skids. Everyone I spoke to about them said they wouldnt hold up at all, iv been bashing them since. 1/4" t6061 plate. Skip to 4:00 in the vid
    http://www.youtube.com/embed/Q3K1WfWi85s
  18. Feb 7, 2012 at 4:24 AM
    g34rh34d
    Colorado
    My intention was a bolt on slider regardless of the type. I prefer that. And you are correct, you cannot weld aluminum to steel.
    Thanks
  19. Feb 7, 2012 at 4:29 AM
    g34rh34d
    Colorado
    Aluminum...: It ain't just for the malls anymore... :rimshot:
    LOL
  20. Feb 7, 2012 at 9:00 AM
    badger
    07 SR5
    They said that because they have never done it. Opinions don't require experience. I've used aluminum in skids and bumpers.
