always lock differentiel on 2007 TRD Sport SR5
Discussion in '2nd Gen. Tacomas (2005-2015)' started by maxc86, Dec 13, 2012.
  1. Dec 13, 2012 at 5:23 PM
    maxc86
    maxc86 [OP] New Member
    qc, canada
    Tacoma TRD SR5 Sport
    Hey! I am looking for someone who can help me. I have a 2007 Tacoma with SR5 TRD Sport package.
    My differential seems to remain "locked" at all times. When I drive on snow / ice, the truck want to stay in a perfect line, not so good on a twisty road.
    any clue? :confused:
  2. Dec 13, 2012 at 5:25 PM
    BulletToothTony
    BulletToothTony You’ll have that on these big jobs.
    You can call me Susan if it makes you happy.
    If you have a trd sport you don't have a locker. You're probably feeling the LSD do its thing
  3. Dec 13, 2012 at 5:27 PM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Do you have oversized tires?
  4. Dec 13, 2012 at 5:28 PM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Rear Lockers come only on the Off Road TRDs.
    2005-2008 Sport TRDs have a mechanical limited slip differential. Obviously there are good reasons Toyota dropped that in 2009, and gave ALL Tacomas an electronic/ brake controlled limited slip system that can be turned off with a push of a button.
    You should see a sticker on your rear differential that calls for LSD additive.
  5. Dec 13, 2012 at 5:31 PM
    BradyT88
    BradyT88 Well-Known Member
    I think we need a bit more detail on what you mean by "always stays locked" since you don't have a locker, unless you added one.
  6. Dec 13, 2012 at 5:46 PM
    maxc86
    qc, canada
    ok, thank you for answer
    No over sized tire.
    so when i make a tight turn, I hear my rear inside (from direction of turn) wheel slipping on ground.
    And when i switch to 4x4 HI, if i try to turn on dry road it's feel like the front wheel screech on pavement. On slippy road the rear wheel will push the truck straight foward
    I drive Ford pickup at ma job and never feel that before on rwd, very strange to me.
  7. Dec 13, 2012 at 5:49 PM
    maxc86
    qc, canada
    No locker add, but i'm the second owner. Bought the truck at the toyota dealer, the truck was a leasing.
  8. Dec 13, 2012 at 7:15 PM
    BradyT88
    um... 1st things first don't use 4WD on a dry high traction surface, you can break shit... Tires always slip while turning in 4wd. It's just how our 4wd systems work on these rigs.
    It is having this problem in 2wd too right? Sounds like you may have a auto locking type locker in there possibly, that is stuck locked. If you can, while in 2wd get both back tires in the air with some jack stands (Be sure to block the front tires or the truck can start to roll!!!). Leave it in park and try turning one of the tires. The other tire should go in the opposite direction. If it doesn't move then your rig is locked. If it does, then either you aren't locked or the locker is currently unlocked. Could be really hard to tell if you have a locker or not after that without just dropping the diff... Another way to check that might be easier, is to just get one rear tire in the air (again block the front tires) and put the tranny in neutral. You should be able to freely spin that tire now and the driveshaft should spin with it, while the other tire doesn't move.
  9. Dec 13, 2012 at 7:59 PM
    David K
    Isn't it likely his mechanical limited slip is failed to work correctly?
  10. Dec 13, 2012 at 8:43 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    or that his mechanical limited slip is functioning as intended. i remember mobbing my brothers 05 trd sport up snowboarding when i was used to my open diff chevy. holy cow what a difference. if it wasnt pushing a straight line it was completeley sideways in the snow.
    i believe what you are experiencing is about the only downside to having a limited slip rear. it is otherwise a nice thing to have. your front tires scrub while turning in 4wd for the same reason that your inside rear tire does on any slick surface. shorter distance to travel but forced at the same speed to get there kind of thing. to make that up, tires must lose traction, or you have to break something. dry pavement can result in the latter, less fortunate option.
    your inside rear tire will not break traction on dry, grippy surfaces because it is again doing as designed, it is allowing a limited amount of slip between inside and outside tires inside the differential. if you had a locker in the rear that was on, you would be in the the same situation as you are now with 4wd on, except the scrubbing would be between the rear tires, at the tires, instead of the diff
  11. Dec 13, 2012 at 9:00 PM
    BradyT88
    oh brainfart... duh, haha... Forgot he has a mechanical LSD. (It's almost finals week here, brain isn't working right anymore... haha)
    I don't have any experience with a mechanical LSD so maybe it is working like it is supposed to as Kevin suggests. Or as David suggests maybe something is wrong with it.
  12. Dec 13, 2012 at 9:10 PM
    Brewmaster
    Brewmaster Active Member
    Tim
    Hillsboro, Oregon
    08 Sport edition
    True flow cold air intake, JBA header Flowmaster dual, exhaust, Ride Rite air bags, Kenwood sat nav head unit. Eibach 620 springs Bilstien heavy duty struts AAL + Rancho shocks. Front diff drop kit Rear carrier bearing drop ECGS Diff bearing Wheelers front strut 1/4 polly spacer. Satoshi front grill, LED hood scoop mod, LED running, turn, reverse, interior lighting.
    My 08 DCLB SPORT does the same thing when making right hand turns on wet pavement, I can also feel the same thing from the front right wheel every time I make a right turn. I don't think its hurting anything but it sure is annoying.
  13. Dec 13, 2012 at 9:11 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Usauly in a mechanical lsd with a bad or worn clutch pack the vehicle operator will experience more slippage as opposed to more torque being supplied to the wheel with less traction.
    I would do a drain and refill of the diff fluid checking the old oil for clutch pack material or metal shavings
  14. Dec 15, 2012 at 8:00 AM
    David K
    Could be why Toyota discontinued using them for the 2009+ models... which all now have electronic/ brake limited slip without any of those issues (nice!)?
  15. Dec 15, 2012 at 8:07 AM
    GP3
    GP3 Well-Known Member
    California
    4X4 TRD Off Road
    Front: stock suspension, 12" wide fiberglass fenders Rear: stock suspension, 10" wide fiberglass fenders
    Because it's cheaper for Toyota and less maintenance? Sure.
    It's not an issue unless you call worn out brakes an issue.
    Normal wear and tear.
    OP when's the last time you changed out the rear diff fluid? LSD's should be done every 30k.
  16. Dec 15, 2012 at 8:35 AM
    ManMan
    ManMan Well-Known Member
    You do at least have e-LSD though
  17. Dec 15, 2012 at 8:42 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I think it is working as intended. In a slippery situation it is just more noticeable.
  18. Dec 15, 2012 at 8:46 AM
    David K
    You do have two levels of Limited Slip available:
    a) TRAC (in 2WD) a light limited slip (with engine regulation)
    and
    b) AUTO LSD in 2WD or TRAC in 4WD-HI, both strong limited slip (no regulation) systems.
    If you perform the 4-low trac mod, you can have limited slip in low range, as well.
