Always-on 12V power outlet mod - 3rd gen
Discussion in '3rd Gen. Tacomas (2016-2023)' started by catware, May 17, 2016.
  1. May 17, 2016 at 1:00 PM
    catware
    catware [OP] Member
    Michelle
    2016 Tacoma TRD OffRoad
    To modify the 12v power outlet in the center console armrest to be always on in the 3rd generation Tacoma, you will need to completely remove the fuse box located to the left below the steering wheel. Disconnect all the electrical plugs, carefully figuring out how each one connects so as to not break any plastic tabs. Then take the box into a bench where you can do some soldering on it.
    Remove the white plastic cover on the box, and remove all 12 or so screws holding down the circuit board, and remove the board. You will see 11 relays soldered into the board, each one with a small id tag. Find the one labeled P/OUTLET, as in this photo:
    Then flip the board over, and find the corresponding pins on the underside. Solder a wire between the following two pins as in this photo (red wire):
    Then reassemble the fusebox, and reinstall in the truck. Putting it all back together will go MUCH faster than removal.
    Note that this mod will only affect the 12v outlet in the center console armrest. The 12v outlet on the lower dash will still be controlled by the ignition.
    Hope this helps! I was tired of camping with the truck and having a dead phone the next morning.
    Michelle
  2. May 17, 2016 at 1:06 PM
    RitchieE24
    RitchieE24 Well-Known Member
    Zack
    Ontario
    2016 Inferno Tacoma TRD Sport Upgrade 6MT
    Amazing! Thank you for this!
  3. May 17, 2016 at 1:57 PM
    onepremiere
    onepremiere I Tinker
    Jeff
    Left Coast
    Well done. Not to high jack your thread, but since you seem to be electrically inclined. I am trying to find a way to keep the LED DRL's in "High" mode all the time. Even when the head light is on. You didn't see a replay here for the LED DRL did you?
  4. May 19, 2016 at 9:43 AM
    catware
    catware [OP] Member
    Michelle
    I haven't looked into that, so I'm afraid I can't help. I am guessing when you write that you want them "in 'High' mode all the time", you would actually like them to turn off when the truck is off (with the ignition). This current mod provides power to the center console armrest outlet at all times by short-circuiting the relay, so it would perform differently than what you want with the DRL's.
    MisterKitchen and 2017 limited like this.
  5. May 25, 2016 at 5:49 AM
    Inferno_Taco
    Inferno_Taco Well-Known Member
    2015 TRD Pro
    Nice write up! Has anyone figured out how to keep the 110v plug in the bed always "on"?
    Flash1034 and sorgon82 like this.
  6. May 25, 2016 at 7:28 AM
    crvz
    crvz Well-Known Member
    while I like the cleanliness of this mod, why did you opt for this instead of just running a 12V hot wire to the outlet (which could then be on a switch if desired)?
    jruiz555 and CMScheid like this.
  7. May 25, 2016 at 9:02 AM
    hodo_taco
    hodo_taco Well-Known Member
    Colorado Springs, CO
    '16 SW Tacoma DCSBTRDOR
    Lot's o' plastidip.
    Bookmarked for later, thanks for posting.
  8. May 26, 2016 at 12:15 PM
    catware
    catware [OP] Member
    Michelle
    I started digging in there, expecting to find a blue socket relay that could easily be shorted to provide constant power, as in the Gen 2 trucks. However that isn't the design in Gen 3, and I just kept digging until I found the correct relay for Gen 3, which happened to be deep inside the fusebox module :) Plus, IMO this is easier than pulling up the trim to the center console to run a wire, and finding a constant 12v source for that wire, that can also handle the load.
    MapleBuddy and Snowtrooper17 like this.
  9. Jun 2, 2016 at 8:16 AM
    Greg Hall
    Greg Hall Well-Known Member
    Greg
    Pittsburgh PA
    2016 Tacoma OR
    This is great, thank you. Do you know if the other power outlets go through this circuit board also? For example if I wanted to provide constant power to my usb and other 12v outlets as well.
    RNJNKE likes this.
  10. Oct 24, 2016 at 11:34 AM
    skrankk
    skrankk Well-Known Member
    Scott
    Flagstaff
    2016 TRD Off Road Access
    Just did this mod, was a little more involved than I expected but not too bad. Worked great, and I have constant power to my center console DC. Of note here are a couple of my points.
    1. To access the fuse box you need to remove your lower dash panel. To do this pop out the step panel and then the cowl cover. This will provide access to a silver bolt, then remove the two black bolts attaching the lower dash panel. Next you need to release the cable for the hood release. Page 8 of this manual gives a rough idea http://toyotaparts.sparkstoyota.com/install/PT398-35160inst.pdf
    2. Remove all of the clips attached to the fusebox. They require a flathead screwdriver to release, then pull on the handles on either end to gently pull the connectors out.
    3. Once you have the box out remove the plastic cover as stated. The diagram pictured matched my truck (2016 TRD OR AC), so you can probably get away without unscrewing the board and flipping it. Instead just make sure you match the image of the soldered points.
    4. The only thing that came up for me was in the process of manipulating the box, a 30a Type B fuse fell out. There were three possible places for it, and nothing was noted on the fuse diagram. I placed it in the center after taking this picture have had no problems. If anybody does this mod, could you let me know where that fuse is supposed to live.
    BlueOverTaco and Toynado like this.
  11. Jan 16, 2017 at 12:56 PM
    hotrod 15
    hotrod 15 Well-Known Member
    Robert
    2017 Toyota Tacoma trd pro
    Just did this to my pro today works like a charm
  12. Jan 16, 2017 at 12:59 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Holy molee.. really? What happened to just modifying the relay? Did it become this difficult now?
  13. Jan 16, 2017 at 3:13 PM
    hotrod 15
    Robert
    Man it was actually quite easy, like REALLY easy
  14. Jan 16, 2017 at 3:23 PM
    ramonortiz55
    Ramon
    Texas
    stock
    probably.. lol
  15. Feb 4, 2017 at 7:50 AM
    Greg Hall
    Greg
    Pittsburgh PA
    2016 Tacoma OR
    The thing that stopped me on this mod was the removal of the dash panel. lol But those instructions up above are giving me more confidence. Now that I've got 10K miles on it, the sweat band of modifying stuff if loosening.
    jruiz555, boynoyce and bobrown14 like this.
  16. Feb 4, 2017 at 7:59 AM
    skrankk
    Scott
    Flagstaff
    Good luck, it really is pretty easy
    Greg Hall[QUOTED] likes this.
  17. Feb 4, 2017 at 8:10 PM
    Joethebugman
    Joethebugman Well-Known Member
    Joe
    '17 Trd OR DBCLB
    Looks a little intimidating to me. Is this difficult? I could really use an always on 12v.
  18. Feb 14, 2017 at 5:58 PM
    hightechcoonass
    hightechcoonass Living the dream
    Ritchie
    land of the swamps LA
    2017 SR5 4x4 super white
    TRD Offroad wheels and decal set.
    Nice work! Thanks for the write up!
  19. Apr 18, 2017 at 8:54 AM
    hodo_taco
    Lot's o' plastidip.
    If you haven't soldered anything before, definitely avoid this.
    I just did this last night...I'd say for a person who's a novice or hasn't ripped into their truck before, you should avoid this. For the most part it's pretty easy. Pop some covers off, unscrew a handful of 10mm bolts, solder and put it all back together. The thing that got me was the hood latch cable...you have to remove it to get the knee bolster off. Getting it back into the hood release handle was a pain in the ass.
    Thanks to @skrankk for the additional details he provided. OP made it seem super easy and straight forward, but I wouldn't have thought I needed to pull the step plate and cowl cover just to get the knee bolster off. And sorry, I didn't see your point #4 since I was reading from my phone, didn't scroll far enough down otherwise I would have told ya where that fuse was on mine.
    Joethebugman[QUOTED] likes this.
  20. Apr 18, 2017 at 8:55 AM
    hodo_taco
    Lot's o' plastidip.
    Oh but thanks @catware for posting this...worked like a charm once I got the fuse box out of there.
