Am I dreaming if I think I can install a set of rock sliders myself?
Discussion in 'Ontario, Canada' started by ontariotruckman, May 16, 2022.
  1. May 16, 2022 at 12:01 PM
    ontariotruckman
    ontariotruckman [OP] Well-Known Member
    ... as the title says, I want to get my sliders on but I don't have help (just me) and I don't have a lift. Bolt-on sliders.
    My plan for example is to get the slider onto a set of jack stands (edit: I also have a floor jack which is better, thanks Drizzoh and RoadWarrior) and get it approximately in the right place, then crawl under the truck and secure the bolt at one end, then secure the other end in place, then finally all the bolts in between. I'm pretty sure I'm missing something critical here. Is this even possible or am I thinking pie in the sky?
    Also: if you read this far, if you're around the GTA have access to a lift and want to help me install these sliders, I've got a brand new Mityvac pneumatic fluid extractor (hooks up to shop air) I'll give you.
    Thanks everyone
    Marc70 likes this.
  2. May 16, 2022 at 12:03 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    That is how most do it. Having a jack will help. They're heavy and bulky but should not be an overly difficult job.
    Leave all the fasteners loose until they are all in place, then torque them down.
    wi_taco and Blue_Steel_Taco like this.
  3. May 16, 2022 at 12:03 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    2021 Black SR5 4x4
    If you have a couple of floor jacks, you can probably do it yourself.
    I installed mine last weekend with the help of two friends and it was extremely hard but that was because we didn’t have a jack.
    Shveet and ontariotruckman[OP] like this.
  4. May 16, 2022 at 12:08 PM
    ontariotruckman
    Thanks guys. Yes I do have a floor jack (only 1) so I figure I can balance the slider on the cradle, jack up as close to position as possible, then affix fasteners.
    Road_Warrior likes this.
  5. May 16, 2022 at 12:09 PM
    cgs2k2
    cgs2k2 old man
    i have installed several sets of bolt on sliders myself. it's definitely doable. jack it up, put some stands or wood under it when it's in place, and bolt them in. not too hard. just don't let it fall on your head!
  6. May 16, 2022 at 12:16 PM
    Off Topic Guy
    Off Topic Guy 2023 Trophy Points - Runner Up
    Definitely doable with only a jack. Find your balance point, jack it into place, and secure all fasteners loosely; then snug it all up. Some jackstands are a nice addition for that added insurance, in case your jack fails.
    wi_taco and ontariotruckman[OP] like this.
  7. May 16, 2022 at 12:25 PM
    Chunk
    Chunk I smell Ice Cream!
    Aiken, SC
    2016 DCSB OR
    Baby Ruth
    Jacks?! You bunch of wussies! Lift scooch and palm one end, lift, scooch and knee/foot the other end and put the bottom frame rail set screw in with your free hand! Cmon! Easy peasy!
  8. May 16, 2022 at 12:27 PM
    Scottyskywalker
    Scottyskywalker Well-Known Member
    Scott
    Kantukee
    2020 Silver Sky SR V6 4X4 SX
    RCI sliders, RCI front skid, RCI trans skid, Bridgestone Revo 3 AT, OVTune 87 stock, Fox 2.0 rear, Front Summo springs, Truxport roll up bed cover, Tekonsha P3, Meso total tails, rear diff breather relocate.
    With the RCI sliders one bolt near the middle will hold the slider up allowing you to easily fasten the rest. I used a 1x6 board and a floor jack. Balance is key.
    ontariotruckman[OP] likes this.
  9. May 16, 2022 at 12:42 PM
    Saturnine
    Saturnine YVAN EHT NIOJ
    Dar C
    North of the wall
    TRD go brrrr
    All the mods
    I did mine by myself with only a bottle jack and a hand dolly
  10. May 16, 2022 at 12:42 PM
    Signatureinc
    Signatureinc Well-Known Member
    Doug
    Flat Land, Ontario
    2019 TRD OR Access Cab
    What all these guys said for sure. I’m no expert and haven’t tried sliders but I find if you take your time, don’t rush it and you have the tools and aren’t intimidated you can do it. Just don’t rush it carve out a full day and giv’r! Good luck post pics I’m shopping sliders now so like to see the result
  11. May 16, 2022 at 12:50 PM
    Browner
    Browner Well-Known Member
    Shawn
    Central Iowa
    2020 TRD OR
    Prinsu Rack, CBI Sliders, UpTop Truss Rack, Softtopper, TRD OEM 2" Lift, SCS Rims, Wildpeak tires, OVS RTT and 270 Awning, Off-Grid Engineering Dual Battery tray, Red-arc BCDC, Switch Pros Controller, cheap Amazon lights.
    I did it with minimal help from the wife. The floor jack just got in the way. CBI sliders with one bolt in the middle to hold it up and then add all the other bolts.
  12. May 16, 2022 at 6:44 PM
    ontariotruckman
    Thanks for your replies everyone, you're all great. I'll let you know how it goes
  13. May 16, 2022 at 6:45 PM
    Road_Warrior
    2021 Black SR5 4x4
    Yep, that’s the exact method we used. Throw one bolt in there to hold it up and then do the rest. Those suckers are heavy!
  14. May 17, 2022 at 5:42 AM
    3JOH22A
    3JOH22A Toyota Gigolo
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    It's overkill for just sliders, but if you have other armor to install (like a rear bumper), you could build a platform out of scrap wood, something like this:
    Remove the swivel off the hydraulic jack and bolt the platform to it:
    Shveet, VXEric and Road_Warrior like this.
  15. May 17, 2022 at 5:54 AM
    clip
    clip Well-Known Member
    VA
    15 OR
    pinstripes. lots of pinstripes.
    Mine shipped on some wood blocking nailed together so Fedex could move it around during shipment. I just used that on the jack to support while I lifted it up.
    3JOH22A likes this.
  16. May 17, 2022 at 6:06 AM
    Modern.Hermit
    Modern.Hermit Well-Known Member
    JD
    Munford, AL
    2020 SR5 DCSB 4x4, 2024 KLX300, 2016 Triumph Scrambler
    Stock-ish
    Complete newb here myself, but I managed to install mine in my gravel driveway and didn’t even have a floor jack. Just used some blocks of wood til I got it kind of close. Then crawled on under and made it happen. You got this.
  17. May 17, 2022 at 6:12 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Yep, same as everyone else. Get some reps in before hand or use the jack stands as safety's to catch it if it falls and to balance it while it's on the jack.
  18. May 18, 2022 at 9:37 PM
    Shveet
    Shveet retired TEC Picture Guy (̶r̶e̶t̶u̶r̶n̶e̶d̶)̶
    Own-tario
    2018 Cement DCSB TRD OR
    Jack stand and a dream
    Keep bolts loose until the very end.
  19. May 18, 2022 at 10:10 PM
    tacoWithstickyrice
    tacoWithstickyrice Well-Known Member
    '19 DCSB TRD OffRoad 4x4
    Floor jack and a piece of scrap 2x4. Laid the slider on the lumber, lifted it up. Ran one bolt through and the rest is easy peasy.
  20. May 28, 2022 at 6:41 AM
    daks
    daks Juzt for Shitz
    Hammertown,Canada
    2017-TRD-Sport DCSB
    Ongoing
    Easiest DIY way, with very little effort is with milk crates and some plywood. (milk crate slides easier on the plywood)
    In this pic I just used one milk crate, and balanced the sliders on it, (2 would prob be a little safer as you would not have to balance)
    Then pushed the milk crate under the truck,
    Climbed up underneath and used one hand to lift the slider and the other to install bolts.
    Add a floor jack to the mix if you don't want to lift the slider when you install bolts.
