Am I Wired for OEM FogLamps
Discussion in '2nd Gen. Tacomas (2005-2015)' started by lucky, Jun 22, 2008.
  1. Jun 22, 2008 at 3:55 PM
    lucky
    lucky [OP] Well-Known Member
    NB, TX
    07 PreRunnerX4
    My base 07 Dcab does not have fog lights in the bumper - plastic cones instead. Taking a peek behind the bumper, I discovered some wiring that appears to be for the factory lamps. On each side is a lead taped back very near the position of where the lamps would mount. Looking at OEM lamps online, it appears the connector at the end of these leads matches that of the OEM lamps. In the dash, I pulled the blank where the foglamp switch would be located (according to owner's guide) and found a connector and wiring stuffed into the back of the blank. Is all I'm missing is a switch and OEM lamps? Is all the electrical installed by default, minus the switch and lamps?
  2. Jun 22, 2008 at 4:20 PM
    LRH
    LRH Well-Known Member
    GA USA
    '07 2.7L PreRunner
    From what I have heard; if it is a V6 model then everything but the lamps, relay, and switch are present. The problem is; Toyota does not sell it in discounted "kit" form, just individual replacement parts, which makes the missing parts more expensive than most premium brand aftermarket complete kits. People have pieced it together for less than dealer list price and even slightly less than dealer discounted net price by searching E-bay and other sources. They still wind up rather expensive for the performance level given. I would rather have a pair of mid range driving lights to supplement high beams, or some passing beams that have more reach than fogs, but less reach (and oncoming glare) than driving lights. If you just want them to get rid of the filler blanks to make the truck look better, then the factory fog lamps will do the job. I have seen very few factory fog lamps that are much more than just decorative.
  3. Jun 22, 2008 at 4:28 PM
    lucky
    NB, TX
    07 PreRunnerX4
    Thanks. i think I've found an OEM kit on ebay for $129. Includes switch, relay and lamps - all oem, supposedly. I found the switch by itself for $20 at RockAuto. I really just wanted to ditch the blanks.
  4. Jun 22, 2008 at 9:09 PM
    LRH
    GA USA
    '07 2.7L PreRunner
    That's not bad, they have been geting cheaper as more turn up at places other that Toyota dealers. The 07 Tundras were out of site pricewise for a while even after they had been available at E-bay and such, but have come down also, only problem on Tundra's is the fog lamp switch is incorporated in the headlamp off/on-dimmer stalk
