Amazing what a 3 degree shim can do
Discussion in 'Suspension' started by mattmxracer454, Jan 4, 2015.
  1. Jan 4, 2015 at 8:55 AM
    mattmxracer454
    mattmxracer454 [OP] Well-Known Member
    South Carolina
    GTR!!
    Icon Suspension, Deaver Leafs, 285/70/17 Duratracs, SCS Stealth Wheels, ALL Pro bumper, ATO H/C rear bumper
    Been dealing with a driveline vibration for about a year and I wanted to stay away from axle shims but why the hell did I do that. I have dakar leafs and an add a leaf to the pack. I tried the carrier bearing drop with spacers and that helped but did not relieve completely. I added the 3 degree shim to the axle that toytec supplies and Im a happy camper. Just thought I would share if anyone is on the fence about axle shims.
    Kgrecurit88, Nexon1295 and Mack411 like this.
  2. Jan 4, 2015 at 9:03 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Did you install thin end forward or reverse ?
  3. Jan 4, 2015 at 9:07 AM
    mattmxracer454
    South Carolina
    GTR!!
    Thin end towards the driver side and thick end towards the rear. I looked over this many times on the forum before I installed. I also put in that pin that you have talked about;( toytec actually provides them now to) the one that goes into the axle that makes it longer. Worked like a charm :D
  4. Jan 4, 2015 at 9:13 AM
    OZ-T
    Peter North
    British Columbia
    cool
    I have the 3 degree shim installed too , but I may need to revisit the driveline angles thread cause it seems to be pushing me pinion high with my regular load and cap , although I may add the d29xl AAL first and see what effect that has
    You used the slide in style shim or the pin through shim style ?
  5. Jan 4, 2015 at 9:19 AM
    mattmxracer454
    South Carolina
    GTR!!
    I ordered the pin through shims but they sent me the slide in style shim and it worked really good. Install took about 1 hr per side. I replaced the center pins and made sure everything was flush before tightening down.
  6. Jan 4, 2015 at 9:23 AM
    OZ-T
    Peter North
    British Columbia
    Did you use collars or just longer pins ?
  7. Jan 4, 2015 at 9:31 AM
    mattmxracer454
    South Carolina
    GTR!!
    I used both------Toytec gave me collars and longer pins throught the kit I ordered. I also had another collar pin.
  8. Jan 4, 2015 at 9:33 AM
    OZ-T
    Peter North
    British Columbia
    Interesting to hear Toytec supplying collars now , that's cool
  9. Jan 4, 2015 at 9:53 AM
    mattmxracer454
    South Carolina
    GTR!!
    Can you send me the link for the collars so I can make sure we are talking about the same thing. They are the things that extend the center bolt that drops into the axle right?
    Do you know where to buy longer u bolts for a flip kit? I need longer U bolts. The ones I have go about 1 thread about the nut and I need more assurance.
  10. Jan 4, 2015 at 10:02 AM
    OZ-T
    Peter North
    British Columbia
    Like this
    http://www.autoandtrucksprings.com/products/Center_Bolt_Head_Lengthener_2_Pcs-1662-0.html
    I had my local spring shop make custom U bolts for me but I'm pretty sure Toytec and all the regular vendors on here offer them
  11. Jan 4, 2015 at 10:06 AM
    mattmxracer454
    South Carolina
    GTR!!
    Thats exactly what I put on! I actually put the ones I bought plus the ones toytec had for a flush fit. Seems Toytec has been taking notes.
    I need longer u bolts but I dont want to buy the entire flip kit. I believe all the vendors just sell them in the kit.
  12. Jan 9, 2015 at 4:35 PM
    NEW YORK T100
    NEW YORK T100 Member
    Augie
    Hudson Valley, N.Y.
    2011-4X4 Sport
    Weather Tec Mats,Access Limited cover. OME Lift: 885 Coils with LR Control Arms and Dakar leaf pack.
    When or where did you have the vibration? Was it on take off only, or was it at a steady cruise all the time?
  13. Jan 9, 2015 at 6:02 PM
    mattmxracer454
    South Carolina
    GTR!!
    Vibrations were at a take off and around 60mph. Thought about getting a one piece and then I put the shim in and made a huge difference
  14. Jan 10, 2015 at 4:32 PM
    NEW YORK T100
    Augie
    Hudson Valley, N.Y.
    2011-4X4 Sport
    Glad to see you made progress with your vibration issue! I'm learning more n more each day about these darn vibes. I did the OME 885 coils with Dakar leafs and put the 3* shims in right off the bat, very happy but here's what happened to me. No more of the 25 mph vibe that it had from the factory, No highway vibration, but now a take off vibe. I think I'll try the combination of cb drop along with the shims like you did and see if that combo works!!
    Smash8ight likes this.
  15. Jan 12, 2015 at 4:19 AM
    mattmxracer454
    South Carolina
    GTR!!
    Update:
    I played around with the carrier bearing yesterday and it seems to work better without the carrier bearing. Maybe its just me but it seems silky smooth without the cb drop and just the 3 degree axle shims
  16. Jan 12, 2015 at 1:03 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    ruffstuff is what i use for all of my u bolt needs. They run the same price as ones that i found at the part store.
  17. Jan 12, 2015 at 4:47 PM
    mattmxracer454
    South Carolina
    GTR!!
    I got 9 inch ones at O'Reillys. They had really nice quality built ones
  18. Jan 12, 2015 at 6:22 PM
    taco211
    taco211 Well-Known Member
    socal
    Are these 3* shims only needed for 4x4 applications? or does this work for pre runners with a rear end lift too?
  19. Jan 12, 2015 at 6:23 PM
    OZ-T
    Peter North
    British Columbia
    Works for either
  20. Jan 12, 2015 at 6:28 PM
    taco211
    socal
    without doing all of the calculations on angles from the other threads, would it be a good idea to try these 3* shims from a pre runner with TSB+Toytec 1.5 AAL (vibes around 25-30mph)? Isn't there 1.5* as well? pics or thread on how to correctly orient them?
