Amazing what a 3 degree shim can do
Discussion in 'Suspension' started by mattmxracer454, Jan 4, 2015.
  1. Jan 12, 2015 at 6:30 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Axles shims are a way to fix driveline angles and you really won't know if you need them , or if you do , what degree you need until after you've installed your leaf pack
  2. Jan 12, 2015 at 9:49 PM
    taco211
    taco211 Well-Known Member
    socal
    Thanks. Im considering taking the plunge and trying these out to see if it fixes some of the slight vibrations I'm getting. Just looking for more insight.
  3. Jan 13, 2015 at 3:48 AM
    mattmxracer454
    mattmxracer454 [OP] Well-Known Member
    South Carolina
    GTR!!
    Icon Suspension, Deaver Leafs, 285/70/17 Duratracs, SCS Stealth Wheels, ALL Pro bumper, ATO H/C rear bumper
    pic for installing
    TacoPandaTRD and Marcmtb1 like this.
  4. Jan 13, 2015 at 8:57 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I thought you sold the truck & got a sports car Matt? :confused:
  5. Jan 13, 2015 at 9:07 AM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    I noticed truck had a slightly weird stance and saw mine cracked in half and some how fell out while wheeling.
  6. Jan 13, 2015 at 9:17 AM
    mattmxracer454
    South Carolina
    GTR!!
    shit can change quick on the internet :p
  7. Jan 14, 2015 at 8:08 PM
    woodyc
    woodyc Well-Known Member
    Craig
    Oceanside, CA
    2014 Access Cab 4x4 TRD
    Sway Away 2.5 " Coilovers Sway Away rear shocks Dakar rear leafs (3rd leaf removed) Snug Top Sport Highliner Shell Thule Racks Toyota Bed Mat Weather Tech Floor Liners
    So I just purchased the Dakars for my 14 AC TRD OR 4x4. The Axle shims from Toytek come in 2.0, 2.5, 3.0, 3.5, and 4 deg angles. I think I'm just installing the Dakars as they come and not removing any leafs. I have a shell on the back and the truck sits level now w/ stock OR suspension. How do I determine what degree shims I should buy? I'm adding Sway Away coil overs and shocks also. shooting for around 2.0 - 2.5 lift in front and 2.5 or a little more in rear
  8. Jan 16, 2015 at 9:56 AM
    SilverComa
    SilverComa Active Member
    Austin, TX
    2012 Silver Tacoma Pre
    Would this be a fix for the stock setup driveline vibration as well? Since I've had my truck (about 3 weeks) I notice there is a vibration right around 20mph. There's also another one around 60mph but I assumed that was the tires needing balancing as it feels a little different than the rear vibration at 20 mph. ?
  9. Jan 17, 2015 at 3:30 AM
    mattmxracer454
    South Carolina
    GTR!!
    Read this http://www.tacomaworld.com/forum/2nd-gen-tacomas/244535-drive-shaft-vibrations-solved-step-step.html
    Honestly I didnt do this^. From reading what people have I tried to do it blind and it worked. I have an acces cab with dakars and a add a leaf which provided me with about 3 1/4 inch in the back. Others running this setup have all gotten 3 degree shims. Do not go with a 4 degree shim. Those are more for 6 inch lifted trucks. If I was you I would get 2.5 degree or the 3 degree based on your rig.
    I have heard of people adding a leaf to the pack to help the vibration and I have also heard of people doing axle shims. Every truck is different. Check the tires first and then if its not it purchase a carrier bearing drop and then go to shims.
  10. Jan 17, 2015 at 3:52 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    When you get shims - try to find STEAL shims. They'll be a better choice than alluminum. Nothing wrong with aluminum.....
    I ran with aluminum 3 degree shims on my 96 for years without any problems.
    However - I've heard that some other folks who have run aluminum shims......because aluminum is soft, the shims tend to 'deform' over time. When they deform, the ubolts will loosen up....
    Just something to be aware of.....
  11. Jan 21, 2015 at 9:57 AM
    SilverComa
    Austin, TX
    Thanks for the advice.
  12. Jan 21, 2015 at 11:40 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Amazing what lying to people can do.
  13. Jan 21, 2015 at 11:48 AM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    what happened there?
    Back on topic.
    I want to do my OME set-up in summer, should I just go ahead and order the 3* with it or try it without first?
  14. Mar 4, 2015 at 5:34 PM
    Alfred
    Alfred Well-Known Member
    Alfred
    California
    14 TRD Sport 4X4 DCSB
    I was driving without shims and a a shudder at take off now my truck is vibrating even more with the 3 degree shims.
  15. Mar 4, 2015 at 6:10 PM
    #35
    Alfred
    Alfred
    California
    Here's some pics. I believe they had installed them wrong. the skinny end is toward the rear.
  16. Mar 4, 2015 at 6:28 PM
    #36
    Hartford
    Hartford Well-Known Member
    Maine
    2011 Acc Cab 5spd
    Yeah that's wrong. Skinny end toward the front. Rotates the front of the axle up countering what the lift does.
  17. Mar 4, 2015 at 6:37 PM
    #37
    Big Tea
    Big Tea WOOOOOOO!!!
    Chesterfield, VA
    08 TRD Sport DCSB 4x4
    Not sure if anyone else has ever seen this (I posted the video in another thread but I think it's a bit inactive).
    Anyhow, this video teaches all about measuring driveline pinion angles and how to determine what size shims you may or may not need. It's long but informative.
    http://youtu.be/f1m-Fh5kiRU
  18. Mar 6, 2015 at 9:13 PM
    #38
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Excellent! Thanks. WOOOOOO! :)
  19. Mar 6, 2015 at 10:25 PM
    #39
    OZ-T
    Peter North
    British Columbia
    That is a great video
  20. Mar 7, 2015 at 6:29 AM
    #40
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Lots of thanks for this! I've read all the various drive shaft docs but this video gives a much better high level understanding a lot faster. And that's saying something coming from me, I tend to hate videos and prefer text.
